Hello everyone,
I am having an odd problem. I am using an SoC based on the nRF52832 (the ISP1507-AX). I am using ncs v1.7.0 for development. I am trying out a few things and right now, I have a sensor that needs to advertise every 50ms. I've noticed a strange bug however. When connected to the device and moving away quickly from it, a GATT TIMEOUT ERROR (0x08) happens. The sensor/device seems to reboot completely.
I have no idea where it comes from, I did change the peripheral preferred max/min connection interval to be around half of 50ms but this error still happens.
Would anyone have any idea about what is going on ?
Attached you'll find all files.timeout_range_pblm.zip
Here is the main.c:
/* Standard and Zephyr libraries */
#include <zephyr.h>
#include <stdio.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <soc.h>
#include <sys/byteorder.h>
#include <sys/util.h>
#include <device.h>
#include <devicetree.h>
#include <drivers/sensor.h>
/* Bluetooth Stack Libraries */
#include <bluetooth/bluetooth.h>
#include <bluetooth/hci.h>
#include <bluetooth/conn.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/services/bas.h>
#include <bluetooth/services/dis.h>
#include <bluetooth/services/hrs.h>
/* Settings librairy for DIS */
#include <settings/settings.h>
/* Logging module */
#include <logging/log.h>
LOG_MODULE_REGISTER(main, LOG_LEVEL_INF);
* DECLARATIONS
void sensor_stop(void);
void sensor_start(void);
* BLUETOOTH FUNCTIONS
/** Device Name as defined in the prj.conf */
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
/** device name length */
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA_BYTES(BT_DATA_UUID16_ALL,
BT_UUID_16_ENCODE(BT_UUID_HRS_VAL),
BT_UUID_16_ENCODE(BT_UUID_BAS_VAL),
BT_UUID_16_ENCODE(BT_UUID_DIS_VAL))
static void connected(struct bt_conn *conn, uint8_t err)
if (err) {
LOG_ERR("Connection failed (err 0x%02x)", err);
} else {
LOG_INF("Connected\n");
sensor_start();
LOG_INF("Disconnected (reason 0x%02x)", reason);
sensor_stop();
static struct bt_conn_cb conn_callbacks = {
.connected = connected,
.disconnected = disconnected,
static void bt_ready(void)
int err;
LOG_INF("Bluetooth initialized");
err = bt_le_adv_start(BT_LE_ADV_CONN_NAME, ad, ARRAY_SIZE(ad), NULL, 0);
if (err) {
LOG_ERR("Advertising failed to start (err %d)", err);
return;
LOG_INF("Advertising successfully started");
static void bas_notify(void)
uint8_t battery_level = bt_bas_get_battery_level();
battery_level--;
if (!battery_level) {
battery_level = 100U;
bt_bas_set_battery_level(battery_level);
static void hrs_notify(uint8_t heartrate)
bt_hrs_notify(heartrate);
static void ble_init(void)
int err;
err = bt_enable(NULL);
if (err) {
LOG_ERR("Bluetooth init failed (err %d)", err);
return;
bt_ready();
bt_conn_cb_register(&conn_callbacks);
* UPDATE VALUES FUNCTIONS
#define START_DELAY_MS 5000
#define SENSOR_SAMPLING_TIME_MS 50
static K_SEM_DEFINE(sensor_ok, 0, 1);
static K_SEM_DEFINE(sensor_init_ok, 0, 1);
static void sensor_timer_handler(struct k_timer *dummy)
k_sem_give(&sensor_ok);
K_TIMER_DEFINE(sensor_timer, sensor_timer_handler, NULL);
int sensor_init(void)
int status = 0;
/* Indicate to the processing thread that initialization is finished */
k_sem_give(&sensor_init_ok);
return status;
k_timer_stop(&sensor_timer);
LOG_INF("Sensor stopped.\n");
/* start periodic timer that expires once every "samplingTime" */
k_timer_start(&sensor_timer, K_MSEC(START_DELAY_MS),
K_MSEC(SENSOR_SAMPLING_TIME_MS));
LOG_INF("Sensor started.\n");
void sensor_process_thread(void)
/* Wait for the sensor to be initialized before starting the thread loop. */
k_sem_take(&sensor_init_ok, K_FOREVER);
static uint8_t sensor_data = 90;
while (1)
/* Semaphore is available every sampling time */
k_sem_take(&sensor_ok, K_FOREVER);
/* Notify new sensor value */
sensor_data++;
if (sensor_data == 160U) {
sensor_data = 90U;
hrs_notify(sensor_data);
/* Defines the processor thread with its stacksize and priority. */
K_THREAD_DEFINE(sensor_producer_thread_id, 1024,
sensor_process_thread, NULL, NULL,
NULL, 5, 0, 0);
* MAIN
void main(void)
sensor_init();
ble_init();
while(1)
bas_notify();
k_sleep(K_MSEC(5000));
Here is the prj.conf:
# Deactivate DEBUG/LOG for production builds CONFIG_DEBUG=y CONFIG_SERIAL=y # Logging CONFIG_LOG=y # segger RTT console CONFIG_USE_SEGGER_RTT=y CONFIG_RTT_CONSOLE=y CONFIG_UART_CONSOLE=n # Unused Peripherals CONFIG_SPI=n # Activate the BLE layer, set as peripheral CONFIG_BT=y CONFIG_BT_DEBUG_LOG=y CONFIG_BT_DEBUG_SERVICE=y CONFIG_BT_SMP=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_CTLR=y CONFIG_BT_CTLR_PHY_2M=y CONFIG_BT_GATT_CLIENT=y # Set up the Services CONFIG_BT_DIS=y CONFIG_BT_DIS_PNP=n CONFIG_BT_BAS=y CONFIG_BT_HRS=y # Decrease connection interval to accomodate 50ms Respiration sampling rate # Min = 17.5ms, Max = 22.5ms CONFIG_BT_PERIPHERAL_PREF_MIN_INT=14 CONFIG_BT_PERIPHERAL_PREF_MAX_INT=18 # Set up device appearance # Appearance 833 is Heart Rate Belt CONFIG_BT_DEVICE_APPEARANCE=833
Here is the CMakeLists.txt:
cmake_minimum_required(VERSION 3.13.1)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(peripheral_hr)
FILE(GLOB app_sources src/*.c)
target_sources(app PRIVATE
${app_sources}
zephyr_library_include_directories(${ZEPHYR_BASE}/samples/bluetooth)
Thank you very much in advance for any help.
