Changing softdevice from S140 to S340
In continuation to the ticket: https://devzone.nordicsemi.com/f/nordic-q-a/70795/replacing-s140-with-s340-softdevice
I'm trying to switch between S140 and S340 bases apps.
When I try to reverse change the SD and App. from S340 to S140.
I created the BL+SD+APP for the S140, the same way as for S340 as explained in above link.
I am able to reverse the firmware from S340 to S140.
So here is what I have achieved till now:
1. I erase all firmware from a device + upload SD(S140)+BL. Then upload the firmware (APP) with same S140 settings.
2. I am able change from the firmware with S140 (BLE only) to the firmware with S340 (BLE+ANT) -successful
3. Change from the firmware with S340 (BLE+ANT) to the firmware with S140 (BLE only) - successful
4. Again, change from the firmware with S140 (BLE only) to the firmware with S340 (BLE+ANT) - FAILED
Step#4 is where the problems arrives, here it gives following error:
I repeated this many times but it stops at this step.
The behavior is consistent and I cannot understand why it's successful first time but not the second time.
It always gives error on step#4, never has any issue on step #2
My goal is that the end user should be able to switch b/w S140 and S340 based files any time.
Thanks
