I am trying to develop a peripheral targeted for mobile devices that can either behave as a touchscreen (several simultaneous contact points, useful for performing gestures, and no visible pointer) or a regular mouse (pointer showing) depending on certain circumstances. If I use the HID descriptor of one or the other, it works fine but if I combine them into a single descriptor only one of them works and the reports for the other are ignored by the OS. I tried creating a composite device by using independent BLE_HID instances for the mouse and touchscreen but only the first created instance works. When bonding with the host, I get a BLE_ERROR_GATTS_SYS_ATTR_MISSING whenever I try to use the second instance. After that, if I power cycle the peripheral, the error changes to NRF_ERROR_INVALID_STATE when using the second instance. What am I missing or what am I doing wrong? My current setup is PCA10040, SD132, nrf5 SDK 17.0.2. I also attach my source code
* Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_app_hids_mouse_main main.c
* @ingroup ble_sdk_app_hids_mouse
* @brief HID Mouse Sample Application main file.
* This file contains is the source code for a sample application using the HID, Battery and Device
* Information Service for implementing a simple mouse functionality. This application uses the
* @ref app_scheduler.
* Also it would accept pairing requests from any peer device. This implementation of the
* application will not know whether a connected central is a known device or not.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_hids.h"
#include "ble_bas.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "bsp_btn_ble.h"
#include "app_scheduler.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "ble_advertising.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "peer_manager_handler.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#define DEVICE_NAME "composite17" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(2000) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL 81 /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL 100 /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT 1 /**< Increment between each simulated battery level measurement. */
#define PNP_ID_VENDOR_ID_SOURCE 0x02 /**< Vendor ID Source. */
#define PNP_ID_VENDOR_ID 0x1915 /**< Vendor ID. */
#define PNP_ID_PRODUCT_ID 0xEEEE /**< Product ID. */
#define PNP_ID_PRODUCT_VERSION 0x0001 /**< Product Version. */
/*lint -emacro(524, MIN_CONN_INTERVAL) // Loss of precision */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Minimum connection interval (7.5 ms). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS) /**< Maximum connection interval (15 ms). */
#define SLAVE_LATENCY 20 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(3000, UNIT_10_MS) /**< Connection supervisory timeout (3000 ms). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAM_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define SWIFT_PAIR_SUPPORTED 1 /**< Swift Pair feature is supported. */
#if SWIFT_PAIR_SUPPORTED == 1
#define MICROSOFT_VENDOR_ID 0x0006 /**< Microsoft Vendor ID.*/
#define MICROSOFT_BEACON_ID 0x03 /**< Microsoft Beacon ID, used to indicate that Swift Pair feature is supported. */
#define MICROSOFT_BEACON_SUB_SCENARIO 0x00 /**< Microsoft Beacon Sub Scenario, used to indicate how the peripheral will pair using Swift Pair feature. */
#define RESERVED_RSSI_BYTE 0x80 /**< Reserved RSSI byte, used to maintain forwards and backwards compatibility. */
#define MOVEMENT_SPEED 5 /**< Number of pixels by which the cursor is moved each time a button is pushed. */
#define MOUSE_INPUT_REPORT_COUNT 3 /**< Number of input reports in this application. */
#define INPUT_REP_BUTTONS_LEN 3 /**< Length of Mouse Input Report containing button data. */
#define INPUT_REP_MOVEMENT_LEN 3 /**< Length of Mouse Input Report containing movement data. */
#define INPUT_REP_MEDIA_PLAYER_LEN 1 /**< Length of Mouse Input Report containing media player data. */
#define INPUT_REP_BUTTONS_INDEX 0 /**< Index of Mouse Input Report containing button data. */
#define INPUT_REP_MOVEMENT_INDEX 1 /**< Index of Mouse Input Report containing movement data. */
#define INPUT_REP_MPLAYER_INDEX 2 /**< Index of Mouse Input Report containing media player data. */
#define INPUT_REP_REF_BUTTONS_ID 1 /**< Id of reference to Mouse Input Report containing button data. */
#define INPUT_REP_REF_MOVEMENT_ID 2 /**< Id of reference to Mouse Input Report containing movement data. */
#define INPUT_REP_REF_MPLAYER_ID 3 /**< Id of reference to Mouse Input Report containing media player data. */
#define TOUCH_INPUT_REPORT_COUNT 1
#define INPUT_REP_TOUCH_LEN 13
#define INPUT_REP_TOUCH_INDEX 0
#define INPUT_REP_TOUCH_REF_ID 4
#define FEATURE_REPORT_COUNT 1
#define FEATURE_REP_SELF_LEN 1
#define FEATURE_REP_SELF_INDEX 0
#define FEATURE_REP_SELF_REF_ID 4
#define BASE_USB_HID_SPEC_VERSION 0x0200 /**< Version number of base USB HID Specification implemented by this application. */
#define SCHED_MAX_EVENT_DATA_SIZE APP_TIMER_SCHED_EVENT_DATA_SIZE /**< Maximum size of scheduler events. */
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SCHED_QUEUE_SIZE 200 /**< Maximum number of events in the scheduler queue. More is needed in case of Serialization. */
#else
#define SCHED_QUEUE_SIZE 100 /**< Maximum number of events in the scheduler queue. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define APP_ADV_FAST_INTERVAL 0x0028 /**< Fast advertising interval (in units of 0.625 ms. This value corresponds to 25 ms.). */
#define APP_ADV_SLOW_INTERVAL 0x00A0 /**< Slow advertising interval (in units of 0.625 ms. This value corresponds to 100 ms.). */
#define APP_ADV_FAST_DURATION 3000 /**< The advertising duration of fast advertising in units of 10 milliseconds. */
#define APP_ADV_SLOW_DURATION 18000 /**< The advertising duration of slow advertising in units of 10 milliseconds. */
APP_TIMER_DEF(m_battery_timer_id); /**< Battery timer. */
BLE_BAS_DEF(m_bas); /**< Battery service instance. */
BLE_HIDS_DEF(mouse_hids, /**< HID service instance. */
NRF_SDH_BLE_TOTAL_LINK_COUNT,
INPUT_REP_BUTTONS_LEN,
INPUT_REP_MOVEMENT_LEN,
INPUT_REP_MEDIA_PLAYER_LEN);
BLE_HIDS_DEF(touch_hids, NRF_SDH_BLE_TOTAL_LINK_COUNT, INPUT_REP_TOUCH_LEN);
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static bool m_in_boot_mode = false; /**< Current protocol mode. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static pm_peer_id_t m_peer_id; /**< Device reference handle to the current bonded central. */
static sensorsim_cfg_t m_battery_sim_cfg; /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state; /**< Battery Level sensor simulator state. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{BLE_UUID_HUMAN_INTERFACE_DEVICE_SERVICE, BLE_UUID_TYPE_BLE}
static uint8_t m_sp_payload[] = /**< Payload of advertising data structure for Microsoft Swift Pair feature. */
MICROSOFT_BEACON_ID,
MICROSOFT_BEACON_SUB_SCENARIO,
RESERVED_RSSI_BYTE
static ble_advdata_manuf_data_t m_sp_manuf_advdata = /**< Advertising data structure for Microsoft Swift Pair feature. */
.company_identifier = MICROSOFT_VENDOR_ID,
.data =
.size = sizeof(m_sp_payload),
.p_data = &m_sp_payload[0]
static ble_advdata_t m_sp_advdata;
static void on_hids_evt(ble_hids_t * p_hids, ble_hids_evt_t * p_evt);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for setting filtered whitelist.
* @param[in] skip Filter passed to @ref pm_peer_id_list.
static void whitelist_set(pm_peer_id_list_skip_t skip)
pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
uint32_t peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
NRF_LOG_INFO("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
peer_id_count + 1,
BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
err_code = pm_whitelist_set(peer_ids, peer_id_count);
/**@brief Function for setting filtered device identities.
static void identities_set(pm_peer_id_list_skip_t skip)
pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
uint32_t peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
ret_code_t err_code;
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
static void advertising_start(bool erase_bonds)
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
APP_ERROR_CHECK(ret);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
case PM_EVT_CONN_SEC_SUCCEEDED:
m_peer_id = p_evt->peer_id;
advertising_start(false);
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
if ( p_evt->params.peer_data_update_succeeded.flash_changed
&& (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
// Note: You should check on what kind of white list policy your application should use.
/**@brief Function for handling Service errors.
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
static void service_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling advertising errors.
static void ble_advertising_error_handler(uint32_t nrf_error)
/**@brief Function for performing a battery measurement, and update the Battery Level characteristic in the Battery Service.
static void battery_level_update(void)
uint8_t battery_level;
battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != NRF_ERROR_FORBIDDEN) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
battery_level_update();
/**@brief Function for the Timer initialization.
* @details Initializes the timer module.
static void timers_init(void)
err_code = app_timer_init();
// Create battery timer.
err_code = app_timer_create(&m_battery_timer_id,
APP_TIMER_MODE_REPEATED,
battery_level_meas_timeout_handler);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(960);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
/**@brief Function for initializing the Queued Write Module.
static void qwr_init(void)
nrf_ble_qwr_init_t qwr_init_obj = {0};
qwr_init_obj.error_handler = nrf_qwr_error_handler;
err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
/**@brief Function for initializing Device Information Service.
static void dis_init(void)
ble_dis_init_t dis_init_obj;
ble_dis_pnp_id_t pnp_id;
pnp_id.vendor_id_source = PNP_ID_VENDOR_ID_SOURCE;
pnp_id.vendor_id = PNP_ID_VENDOR_ID;
pnp_id.product_id = PNP_ID_PRODUCT_ID;
pnp_id.product_version = PNP_ID_PRODUCT_VERSION;
memset(&dis_init_obj, 0, sizeof(dis_init_obj));
ble_srv_ascii_to_utf8(&dis_init_obj.manufact_name_str, MANUFACTURER_NAME);
dis_init_obj.p_pnp_id = &pnp_id;
dis_init_obj.dis_char_rd_sec = SEC_JUST_WORKS;
err_code = ble_dis_init(&dis_init_obj);
/**@brief Function for initializing Battery Service.
static void bas_init(void)
ble_bas_init_t bas_init_obj;
memset(&bas_init_obj, 0, sizeof(bas_init_obj));
bas_init_obj.evt_handler = NULL;
bas_init_obj.support_notification = true;
bas_init_obj.p_report_ref = NULL;
bas_init_obj.initial_batt_level = 100;
bas_init_obj.bl_rd_sec = SEC_JUST_WORKS;
bas_init_obj.bl_cccd_wr_sec = SEC_JUST_WORKS;
bas_init_obj.bl_report_rd_sec = SEC_JUST_WORKS;
err_code = ble_bas_init(&m_bas, &bas_init_obj);
/**@brief Function for initializing HID Service.
static void hids_init(void)
ble_hids_init_t mouse_hids_init_obj;
ble_hids_inp_rep_init_t *p_mouse_input_report;
uint8_t hid_info_flags;
static ble_hids_inp_rep_init_t mouse_inp_rep_array[MOUSE_INPUT_REPORT_COUNT];
ble_hids_init_t touch_hids_init_obj;
ble_hids_inp_rep_init_t *p_touch_input_report;
static ble_hids_inp_rep_init_t touch_inp_rep_array[TOUCH_INPUT_REPORT_COUNT];
static uint8_t mouse_rep_map_data[] =
0x05, 0x01, // Usage Page (Generic Desktop)
0x09, 0x02, // Usage (Mouse)
0xA1, 0x01, // Collection (Application)
// Report ID 1: Mouse buttons + scroll/pan
0x85, 0x01, // Report Id 1
0x09, 0x01, // Usage (Pointer)
0xA1, 0x00, // Collection (Physical)
0x95, 0x05, // Report Count (3)
0x75, 0x01, // Report Size (1)
0x05, 0x09, // Usage Page (Buttons)
0x19, 0x01, // Usage Minimum (01)
0x29, 0x05, // Usage Maximum (05)
0x15, 0x00, // Logical Minimum (0)
0x25, 0x01, // Logical Maximum (1)
0x81, 0x02, // Input (Data, Variable, Absolute)
0x95, 0x01, // Report Count (1)
0x75, 0x03, // Report Size (3)
0x81, 0x01, // Input (Constant) for padding
0x75, 0x08, // Report Size (8)
0x09, 0x38, // Usage (Wheel)
0x15, 0x81, // Logical Minimum (-127)
0x25, 0x7F, // Logical Maximum (127)
0x81, 0x06, // Input (Data, Variable, Relative)
0x05, 0x0C, // Usage Page (Consumer)
0x0A, 0x38, 0x02, // Usage (AC Pan)
0x81, 0x06, // Input (Data,Value,Relative,Bit Field)
0xC0, // End Collection (Physical)
// Report ID 2: Mouse motion
0x85, 0x02, // Report Id 2
0x75, 0x0C, // Report Size (12)
0x95, 0x02, // Report Count (2)
0x09, 0x30, // Usage (X)
0x09, 0x31, // Usage (Y)
0x16, 0x01, 0xF8, // Logical maximum (2047)
0x26, 0xFF, 0x07, // Logical minimum (-2047)
0xC0, // End Collection (Application)
// Report ID 3: Advanced buttons
0x09, 0x01, // Usage (Consumer Control)
0x85, 0x03, // Report Id (3)
0x15, 0x00, // Logical minimum (0)
0x25, 0x01, // Logical maximum (1)
0x09, 0xCD, // Usage (Play/Pause)
0x0A, 0x83, 0x01, // Usage (AL Consumer Control Configuration)
0x09, 0xB5, // Usage (Scan Next Track)
0x09, 0xB6, // Usage (Scan Previous Track)
0x09, 0xEA, // Usage (Volume Down)
0x09, 0xE9, // Usage (Volume Up)
0x0A, 0x25, 0x02, // Usage (AC Forward)
0x0A, 0x24, 0x02, // Usage (AC Back)
0xC0 // End Collection
memset(mouse_inp_rep_array, 0, sizeof(mouse_inp_rep_array));
// Initialize HID Service.
p_mouse_input_report = &mouse_inp_rep_array[INPUT_REP_BUTTONS_INDEX];
p_mouse_input_report->max_len = INPUT_REP_BUTTONS_LEN;
p_mouse_input_report->rep_ref.report_id = INPUT_REP_REF_BUTTONS_ID;
p_mouse_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
p_mouse_input_report->sec.cccd_wr = SEC_JUST_WORKS;
p_mouse_input_report->sec.wr = SEC_JUST_WORKS;
p_mouse_input_report->sec.rd = SEC_JUST_WORKS;
p_mouse_input_report = &mouse_inp_rep_array[INPUT_REP_MOVEMENT_INDEX];
p_mouse_input_report->max_len = INPUT_REP_MOVEMENT_LEN;
p_mouse_input_report->rep_ref.report_id = INPUT_REP_REF_MOVEMENT_ID;
p_mouse_input_report = &mouse_inp_rep_array[INPUT_REP_MPLAYER_INDEX];
p_mouse_input_report->max_len = INPUT_REP_MEDIA_PLAYER_LEN;
p_mouse_input_report->rep_ref.report_id = INPUT_REP_REF_MPLAYER_ID;
hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
memset(&mouse_hids_init_obj, 0, sizeof(mouse_hids_init_obj));
mouse_hids_init_obj.evt_handler = on_hids_evt;
mouse_hids_init_obj.error_handler = service_error_handler;
mouse_hids_init_obj.is_kb = false;
mouse_hids_init_obj.is_mouse = true;
mouse_hids_init_obj.inp_rep_count = MOUSE_INPUT_REPORT_COUNT;
mouse_hids_init_obj.p_inp_rep_array = mouse_inp_rep_array;
mouse_hids_init_obj.outp_rep_count = 0;
mouse_hids_init_obj.p_outp_rep_array = NULL;
mouse_hids_init_obj.feature_rep_count = 0;
mouse_hids_init_obj.p_feature_rep_array = NULL;
mouse_hids_init_obj.rep_map.data_len = sizeof(mouse_rep_map_data);
mouse_hids_init_obj.rep_map.p_data = mouse_rep_map_data;
mouse_hids_init_obj.hid_information.bcd_hid = BASE_USB_HID_SPEC_VERSION;
mouse_hids_init_obj.hid_information.b_country_code = 0;
mouse_hids_init_obj.hid_information.flags = hid_info_flags;
mouse_hids_init_obj.included_services_count = 0;
mouse_hids_init_obj.p_included_services_array = NULL;
mouse_hids_init_obj.rep_map.rd_sec = SEC_JUST_WORKS;
mouse_hids_init_obj.hid_information.rd_sec = SEC_JUST_WORKS;
mouse_hids_init_obj.boot_mouse_inp_rep_sec.cccd_wr = SEC_JUST_WORKS;
mouse_hids_init_obj.boot_mouse_inp_rep_sec.wr = SEC_JUST_WORKS;
mouse_hids_init_obj.boot_mouse_inp_rep_sec.rd = SEC_JUST_WORKS;
mouse_hids_init_obj.protocol_mode_rd_sec = SEC_JUST_WORKS;
mouse_hids_init_obj.protocol_mode_wr_sec = SEC_JUST_WORKS;
mouse_hids_init_obj.ctrl_point_wr_sec = SEC_JUST_WORKS;
err_code = ble_hids_init(&mouse_hids, &mouse_hids_init_obj);
static uint8_t touch_rep_map_data[] = {
0x05,0x0d, // Usage_Page(Digitizer_Page_ID),
0x09,0x04, // Usage(Touchscreen_ID),
0xa1,0x01, // Collection(Clc_Application),
0x85,INPUT_REP_TOUCH_REF_ID, // Report_ID(4),
0x09,0x22, // Usage(Finger_ID),
0xa1,0x02, // Collection(Clc_Logical),
0x09,0x42, // Usage(Tip_Switch_ID),
0x15,0x00, // Logical_Minimum(0),
0x25,0x01, // Logical_Maximum(1),
0x75,0x01, // Report_Size(1),
0x95,0x01, // Report_Count(1),
0x81,0x02, // Input(IOF_Variable),
0x09,0x32, // Usage(In_Range_ID),
0x09,0x47, // Usage(Valid_Touch_ID),
0x95,0x05, // Report_Count(5),
0x81,0x03, // Input(IOF_ConstVar),
0x75,0x08, // Report_Size(8),
0x09,0x51, // Usage(Contact_Identifier_ID),
0xa1,0x00, // Collection(Clc_Physical),
0x05,0x01, // Usage_Page(Generic_Desktop_ID),
0x15,0x01, // Logical_Minimum(1),
0x26,0xe8,0x03, // Logical_Maximum(1000),
0x75,0x10, // Report_Size(16),
0x55,0x0e, // Unit_Exponent(-2),
0x65,0x33, // Unit(Eng_Lin_Dist_power3),
0x09,0x30, // Usage(X_ID),
0x35,0x01, // Physical_Minimum(1),
0x46,0xe8,0x03, // Physical_Maximum(1000),
0x09,0x31, // Usage(Y_ID),
0xc0, // End_Collection(),
0x09,0x54, // Usage(Contact_Count_ID),
0x25,0x08, // Logical_Maximum(8),
0x09,0x55, // Usage(Contact_Count_Max_ID),
0xb1,0x02, // Feature(IOF_Variable),
memset(touch_inp_rep_array, 0, sizeof(touch_inp_rep_array));
p_touch_input_report = &touch_inp_rep_array[INPUT_REP_TOUCH_INDEX];
p_touch_input_report->max_len = INPUT_REP_TOUCH_LEN;
p_touch_input_report->rep_ref.report_id = INPUT_REP_TOUCH_REF_ID;
p_touch_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
p_touch_input_report->sec.cccd_wr = SEC_JUST_WORKS;
p_touch_input_report->sec.wr = SEC_JUST_WORKS;
p_touch_input_report->sec.rd = SEC_JUST_WORKS;
memset(&touch_hids_init_obj, 0, sizeof(touch_hids_init_obj));
touch_hids_init_obj.evt_handler = on_hids_evt;
touch_hids_init_obj.error_handler = service_error_handler;
touch_hids_init_obj.is_kb = false;
touch_hids_init_obj.is_mouse = true;
touch_hids_init_obj.inp_rep_count = TOUCH_INPUT_REPORT_COUNT;
touch_hids_init_obj.p_inp_rep_array = touch_inp_rep_array;
touch_hids_init_obj.outp_rep_count = 0;
touch_hids_init_obj.p_outp_rep_array = NULL;
touch_hids_init_obj.feature_rep_count = 0;
touch_hids_init_obj.p_feature_rep_array = NULL;
touch_hids_init_obj.rep_map.data_len = sizeof(touch_rep_map_data);
touch_hids_init_obj.rep_map.p_data = touch_rep_map_data;
touch_hids_init_obj.hid_information.bcd_hid = BASE_USB_HID_SPEC_VERSION;
touch_hids_init_obj.hid_information.b_country_code = 0;
touch_hids_init_obj.hid_information.flags = hid_info_flags;
touch_hids_init_obj.included_services_count = 0;
touch_hids_init_obj.p_included_services_array = NULL;
touch_hids_init_obj.rep_map.rd_sec = SEC_JUST_WORKS;
touch_hids_init_obj.hid_information.rd_sec = SEC_JUST_WORKS;
touch_hids_init_obj.boot_mouse_inp_rep_sec.cccd_wr = SEC_JUST_WORKS;
touch_hids_init_obj.boot_mouse_inp_rep_sec.wr = SEC_JUST_WORKS;
touch_hids_init_obj.boot_mouse_inp_rep_sec.rd = SEC_JUST_WORKS;
touch_hids_init_obj.protocol_mode_rd_sec = SEC_JUST_WORKS;
touch_hids_init_obj.protocol_mode_wr_sec = SEC_JUST_WORKS;
touch_hids_init_obj.ctrl_point_wr_sec = SEC_JUST_WORKS;
err_code = ble_hids_init(&touch_hids, &touch_hids_init_obj);
qwr_init();
dis_init();
bas_init();
hids_init();
/**@brief Function for initializing the battery sensor simulator.
static void sensor_simulator_init(void)
m_battery_sim_cfg.min = MIN_BATTERY_LEVEL;
m_battery_sim_cfg.max = MAX_BATTERY_LEVEL;
m_battery_sim_cfg.incr = BATTERY_LEVEL_INCREMENT;
m_battery_sim_cfg.start_at_max = true;
sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAM_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = NULL;
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for starting timers.
static void timers_start(void)
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
// Prepare wakeup buttons.
/**@brief Function for handling HID events.
* @details This function will be called for all HID events which are passed to the application.
* @param[in] p_hids HID service structure.
* @param[in] p_evt Event received from the HID service.
switch (p_evt->evt_type)
case BLE_HIDS_EVT_BOOT_MODE_ENTERED:
m_in_boot_mode = true;
case BLE_HIDS_EVT_REPORT_MODE_ENTERED:
case BLE_HIDS_EVT_NOTIF_ENABLED:
// No implementation needed.
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_DIRECTED_HIGH_DUTY:
NRF_LOG_INFO("Directed advertising.");
err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_DIRECTED);
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_SLOW:
NRF_LOG_INFO("Slow advertising.");
m_sp_advdata.p_manuf_specific_data = NULL;
err_code = ble_advertising_advdata_update(&m_advertising, &m_sp_advdata, NULL);
err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
case BLE_ADV_EVT_FAST_WHITELIST:
NRF_LOG_INFO("Fast advertising with whitelist.");
err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
case BLE_ADV_EVT_SLOW_WHITELIST:
NRF_LOG_INFO("Slow advertising with whitelist.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
case BLE_ADV_EVT_WHITELIST_REQUEST:
ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
ble_gap_irk_t whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
uint32_t addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
uint32_t irk_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
whitelist_irks, &irk_cnt);
NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
addr_cnt,
irk_cnt);
// Set the correct identities list (no excluding peers with no Central Address Resolution).
identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
// Apply the whitelist.
err_code = ble_advertising_whitelist_reply(&m_advertising,
whitelist_addrs,
addr_cnt,
whitelist_irks,
irk_cnt);
case BLE_ADV_EVT_PEER_ADDR_REQUEST:
pm_peer_data_bonding_t peer_bonding_data;
// Only Give peer address if we have a handle to the bonded peer.
if (m_peer_id != PM_PEER_ID_INVALID)
err_code = pm_peer_data_bonding_load(m_peer_id, &peer_bonding_data);
if (err_code != NRF_ERROR_NOT_FOUND)
// Manipulate identities to exclude peers with no Central Address Resolution.
identities_set(PM_PEER_ID_LIST_SKIP_ALL);
ble_gap_addr_t * p_peer_addr = &(peer_bonding_data.peer_ble_id.id_addr_info);
err_code = ble_advertising_peer_addr_reply(&m_advertising, p_peer_addr);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
NRF_LOG_INFO("Disconnected");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
uint8_t adv_flags;
ble_advertising_init_t init;
adv_flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = adv_flags;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.advdata.p_manuf_specific_data = &m_sp_manuf_advdata;
memcpy(&m_sp_advdata, &init.advdata, sizeof(m_sp_advdata));
init.config.ble_adv_whitelist_enabled = true;
init.config.ble_adv_directed_high_duty_enabled = true;
init.config.ble_adv_directed_enabled = false;
init.config.ble_adv_directed_interval = 0;
init.config.ble_adv_directed_timeout = 0;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_interval = APP_ADV_FAST_INTERVAL;
init.config.ble_adv_fast_timeout = APP_ADV_FAST_DURATION;
init.config.ble_adv_slow_enabled = true;
init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
init.config.ble_adv_slow_timeout = APP_ADV_SLOW_DURATION;
init.error_handler = ble_advertising_error_handler;
/**@brief Function for the Event Scheduler initialization.
static void scheduler_init(void)
APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
static void detect_error(ret_code_t error_code){
if ((error_code != NRF_SUCCESS) &&
(error_code != NRF_ERROR_INVALID_STATE) &&
(error_code != NRF_ERROR_RESOURCES) &&
(error_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(error_code);
else if(error_code == NRF_ERROR_INVALID_STATE){
NRF_LOG_INFO("NRF_ERROR_INVALID_STATE");
else if(error_code == NRF_ERROR_RESOURCES){
NRF_LOG_INFO("NRF_ERROR_RESOURCES");
else if(error_code == BLE_ERROR_GATTS_SYS_ATTR_MISSING){
NRF_LOG_INFO("BLE_ERROR_GATTS_SYS_ATTR_MISSING");
/**@brief Function for sending a Mouse Movement.
* @param[in] x_delta Horizontal movement.
* @param[in] y_delta Vertical movement.
static void mouse_movement_send(int16_t x_delta, int16_t y_delta)
if (m_in_boot_mode)
x_delta = MIN(x_delta, 0x00ff);
y_delta = MIN(y_delta, 0x00ff);
err_code = ble_hids_boot_mouse_inp_rep_send(&mouse_hids,
0x00,
(int8_t)x_delta,
(int8_t)y_delta,
0,
NULL,
m_conn_handle);
uint8_t buffer[INPUT_REP_MOVEMENT_LEN];
APP_ERROR_CHECK_BOOL(INPUT_REP_MOVEMENT_LEN == 3);
x_delta = MIN(x_delta, 0x0fff);
y_delta = MIN(y_delta, 0x0fff);
buffer[0] = x_delta & 0x00ff;
buffer[1] = ((y_delta & 0x000f) << 4) | ((x_delta & 0x0f00) >> 8);
buffer[2] = (y_delta & 0x0ff0) >> 4;
err_code = ble_hids_inp_rep_send(&mouse_hids,
INPUT_REP_MOVEMENT_INDEX,
buffer,
m_conn_handle);
detect_error(err_code);
static void mouseSquare(void){
mouse_movement_send(-100,0);
nrf_delay_ms(100);
mouse_movement_send(0,-100);
nrf_delay_ms(100);
mouse_movement_send(100,0);
nrf_delay_ms(100);
mouse_movement_send(0,100);
@brief Function for simulating finger action
@param[in] fingerNumber Zero-based index of the finger to simulate
@param[in] posX Unsigned X coordinate
@param[in] posY Unsigned Y coordinate
@param[in] release Whether this is a release action
static void fingerAction(uint16_t posX1, uint16_t posY1, bool release1,
uint16_t posX2, uint16_t posY2, bool release2) {
ret_code_t error_code;
uint8_t buffer[INPUT_REP_TOUCH_LEN];
memset(&buffer, 0, sizeof(buffer));
// Touching
if(!release1) buffer[0] = 3;
if(!release2) buffer[6] = 3;
// Contact ID
buffer[1] = 1;
buffer[7] = 2;
// X coord
if(posX1 != 0){
buffer[2] = (uint8_t) (posX1 & 0xff);
buffer[3] = (uint8_t) (posX1 >> 8);
if(posX2 != 0){
buffer[8] = (uint8_t) (posX2 & 0xff);
buffer[9] = (uint8_t) (posX2 >> 8);
// Y coord
if(posX1 != 0){
buffer[4] = (uint8_t) (posY1 & 0xff);
buffer[5] = (uint8_t) (posY1 >> 8);
if(posX2 != 0){
buffer[10] = (uint8_t) (posY2 & 0xff);
buffer[11] = (uint8_t) (posY2 >> 8);
// Valid contact number
if(posX1)
buffer[12]++;
if(posX2)
buffer[12]++;
NRF_LOG_INFO("%d", buffer[12]);
NRF_LOG_INFO("Sending");
error_code = ble_hids_inp_rep_send(&touch_hids, INPUT_REP_TOUCH_INDEX, INPUT_REP_TOUCH_LEN, buffer, m_conn_handle);
detect_error(error_code);
static void releaseFingers(void){
NRF_LOG_INFO("Releasing");
fingerAction(0, 0, true, 0, 0, true);
static void zoom_in(void){
NRF_LOG_INFO("zoom in");
// First finger
fingerAction(400, 500, false, 0, 0, false);
nrf_delay_ms(50);
// Second finger
for(uint8_t i = 0; i <= 3;i++){
fingerAction(400 - (i*50), 500, false, 600 + (i*50), 500, false);
nrf_delay_ms(20);
// Release finger 1
fingerAction(250, 500, false, 750, 500, true);
nrf_delay_ms(10);
// Release finger 2
fingerAction(250, 500, true, 0, 0, true);
nrf_delay_ms(10);
//fingerAction(0, 0, true, 0, 0, true);
static void zoom_out(void){
NRF_LOG_INFO("zoom out");
// First finger
fingerAction(100, 0xf4, false, 0, 0, false);
nrf_delay_ms(50);
// Second finger
fingerAction(100 + (i*50), 0xf4, false, 900 - (i*50), 0xf4, false);
nrf_delay_ms(20);
// Release finger 2
fingerAction(250, 0xf4, false, 750, 0xf4, true);
nrf_delay_ms(10);
// Release finger 1
fingerAction(250, 0xf4, true, 0, 0, true);
nrf_delay_ms(10);
* @param[in] event Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle,
case BSP_EVENT_WHITELIST_OFF:
case BSP_EVENT_KEY_0:
if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
// mouse_movement_send(-MOVEMENT_SPEED, 0);
zoom_in();
case BSP_EVENT_KEY_1:
// mouse_movement_send(0, -MOVEMENT_SPEED);
releaseFingers();
case BSP_EVENT_KEY_2:
//mouse_movement_send(MOVEMENT_SPEED, 0);
mouseSquare();
case BSP_EVENT_KEY_3:
// mouse_movement_send(0, MOVEMENT_SPEED);
zoom_out();
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
app_sched_execute();
nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
scheduler_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
sensor_simulator_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("HID Mouse example started.");
timers_start();
advertising_start(erase_bonds);
// Enter main loop.
for (;;)
idle_state_handle();
