unable to program nrf53 dk zephyr properly [fatal error in building clean example]
Hey all
Trying to understand how to properly build a basic bluetooth example without errors using zephyr between the 2 cores
Error: manually cleaning and flashing
Microsoft Windows [Version 10.0.19041.1237]
(c) Microsoft Corporation. All rights reserved.
C:\Users\andre>cd C:\Users\andre\ncs\v1.6.1\nrf\samples\bluetooth\peripheral_lbs
C:\Users\andre\ncs\v1.6.1\nrf\samples\bluetooth\peripheral_lbs>west build -b nrf5340dk_nrf5340_cpunet && west flash --recover
WARNING: ZEPHYR_BASE=C:\Users\andre\ncs\zephyr; in the calling environment will be used,
but the zephyr.base config option in C:\Users\andre\ncs\v1.6.1 is "zephyr"
which implies a different ZEPHYR_BASE=C:\Users\andre\ncs\v1.6.1\zephyr
To disable this warning in the future, execute 'west config --global zephyr.base-prefer env'
Including boilerplate (Zephyr base): C:/Users/andre/ncs/zephyr/cmake/app/boilerplate.cmake
CMake Deprecation Warning at C:/Users/andre/ncs/zephyr/cmake/app/boilerplate.cmake:37 (cmake_policy):
  The OLD behavior for policy CMP0079 will be removed from a future version
  of CMake.
  The cmake-policies(7) manual explains that the OLD behaviors of all
  policies are deprecated and that a policy should be set to OLD only under
  specific short-term circumstances.  Projects should be ported to the NEW
  behavior and not rely on setting a policy to OLD.
  C:/Users/andre/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
  C:/Users/andre/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
  CMakeLists.txt:8 (find_package)
-- Application: C:/Users/andre/ncs/v1.6.1/nrf/samples/bluetooth/peripheral_lbs
-- Using NCS Toolchain 1.6.0 for building. (C:/Users/andre/ncs/v1.6.0/toolchain/cmake)
-- Zephyr version: 2.6.0-rc1 (C:/Users/andre/ncs/zephyr), build: v2.6.0-rc1-ncs1
-- Found Python3: C:/Users/andre/ncs/v1.6.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.11.0", minimum required is "0.7.1")
-- Board: nrf5340dk_nrf5340_cpunet
-- Cache files will be written to: C:/Users/andre/ncs/zephyr/.cache
-- Found dtc: C:/Users/andre/ncs/v1.6.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/Users/andre/ncs/v1.6.0/toolchain/opt)
-- Found BOARD.dts: C:/Users/andre/ncs/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts
-- Generated zephyr.dts: C:/Users/andre/ncs/v1.6.1/nrf/samples/bluetooth/peripheral_lbs/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/andre/ncs/v1.6.1/nrf/samples/bluetooth/peripheral_lbs/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/andre/ncs/v1.6.1/nrf/samples/bluetooth/peripheral_lbs/build/zephyr/include/generated/device_extern.h
C:/Users/andre/ncs/v1.6.1/nrf/samples/bluetooth/peripheral_lbs/prj.conf:6: warning: attempt to assign the value 'y' to the undefined symbol NCS_SAMPLES_DEFAULTS
C:/Users/andre/ncs/v1.6.1/nrf/samples/bluetooth/peripheral_lbs/prj.conf:13: warning: attempt to assign the value 'y' to the undefined symbol BT_LBS
C:/Users/andre/ncs/v1.6.1/nrf/samples/bluetooth/peripheral_lbs/prj.conf:14: warning: attempt to assign the value 'y' to the undefined symbol BT_LBS_POLL_BUTTON
C:/Users/andre/ncs/v1.6.1/nrf/samples/bluetooth/peripheral_lbs/prj.conf:15: warning: attempt to assign the value 'y' to the undefined symbol DK_LIBRARY
warning: HAS_NORDIC_DRIVERS (defined at modules\hal_nordic\Kconfig:7) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols:
 - SOC_SERIES_NRF53X (defined at soc/arm/nordic_nrf\nrf53\Kconfig.series:6), with value y, direct dependencies <choice> (value: y), and select condition <choice> (value: y)
warning: HAS_NRFX (defined at modules\hal_Parsing C:/Users/andre/ncs/v1.6.1/nrf/samples/bluetooth/peripheral_lbs/Kconfig
Loaded configuration 'C:/Users/andre/ncs/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet_defconfig'
Merged configuration 'C:/Users/andre/ncs/v1.6.1/nrf/samples/bluetooth/peripheral_lbs/prj.conf'
nordic\nrfx/Kconfig:4) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols:
warning: NRFX_CLOCK (defined at modules\hal_nordic\nrfx/Kconfig:14) has direct dependencies HAS_HW_NRF_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - CLOCK_CONTROL_NRF (defined at drivers/clock_control/Kconfig.nrf:13), with value y, direct dependencies SOC_COMPATIBLE_NRF && CLOCK_CONTROL (value: y), and select condition !CLOCK_CONTROL_NRF_FORCE_ALT && SOC_COMPATIBLE_NRF && CLOCK_CONTROL (value: y)
warning: NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED (defined at modules\hal_nordic\nrfx/Kconfig:18) has direct dependencies NRFX_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - CLOCK_CONTROL_NRF_K32SRC_XTAL (defined at drivers/clock_control/Kconfig.nrf:36), with value y, direct dependencies <choice CLOCK_CONTROL_NRF_SOURCE> (value: y), and select condition !SOC_SERIES_BSIM_NRFXX && !CLOCK_CONTROL_NRF_FORCE_ALT && <choice CLOCK_CONTROL_NRF_SOURCE> (value: y)
warning: NRFX_DPPI (defined at modules\hal_nordic\nrfx/Kconfig:26, drivers/serial/Kconfig.nrfx:375) has direct dependencies (HAS_HW_NRF_DPPIC && HAS_NRFX && 0) || (HAS_HW_NRF_DPPIC && (UART_0_NRF_HW_ASYNC || UART_1_NRF_HW_ASYNC || UART_2_NRF_HW_ASYNC || UART_3_NRF_HW_ASYNC) && UART_NRFX && SERIAL) with value n, but is currently being y-selected by the following symbols:
 - UART_ENHANCED_POLL_OUT (defined at drivers/serial/Kconfig.nrfx:388), with value y, direct dependencies (UART_0_ENHANCED_POLL_OUT || UART_1_ENHANCED_POLL_OUT || UART_2_ENHANCED_POLL_OUT || UART_3_ENHANCED_POLL_OUT) && UART_NRFX && SERIAL (value: y), and select condition HAS_HW_NRF_DPPIC && (UART_0_ENHANCED_POLL_OUT || UART_1_ENHANCED_POLL_OUT || UART_2_ENHANCED_POLL_OUT || UART_3_ENHANCED_POLL_OUT) && UART_NRFX && SERIAL (value: y)
warning: NRFX_GPIOTE (defined at modules\hal_nordic\nrfx/Kconfig:65) has direct dependencies HAS_HW_NRF_GPIOTE && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - GPIO_NRFX (defined at drivers/gpio/Kconfig.nrfx:4), with value y, direct dependencies SOC_FAMILY_NRF && GPIO (value: y), and select condition SOC_FAMILY_NRF && GPIO (value: y)
warning: NRFX_NVMC (defined at modules\hal_nordic\nrfx/Kconfig:87) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols:
 - SOC_FLASH_NRF (defined at drivers/flash/Kconfig.nrf:10), with value y, direct dependencies SOC_FAMILY_NRF && !FLASH_NRF_FORCE_ALT && FLASH (value: y), and select condition SOC_FAMILY_NRF && !FLASH_NRF_FORCE_ALT && FLASH (value: y)
error: Aborting due to Kconfig warnings
CMake Error at C:/Users/andre/ncs/zephyr/cmake/kconfig.cmake:264 (message):
  command failed with return code: 1
  C:/Users/andre/ncs/zephyr/cmake/app/boilerplate.cmake:555 (include)
FATAL ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' '-DWEST_PYTHON=c:\users\andre\appdata\local\programs\python\python39\python.exe' '-BC:\Users\andre\ncs\v1.6.1\nrf\samples\bluetooth\peripheral_lbs\build' '-SC:\Users\andre\ncs\v1.6.1\nrf\samples\bluetooth\peripheral_lbs' -GNinja -DBOARD=nrf5340dk_nrf5340_cpunet
reading the error completely confused me on what to do to remedy it.
Regarding the zephyr & 53 setup whats the process to flash both network and application core for the same project ?
it seems like my merged hex (to my understanding is both) is triggering something it shouldnt or im forgetting something to do prior to flashing.
Errors on build:
Connecting ‘J-Link’ using ‘USB’
  Connecting to target using SWD
    Loaded C:/Users/andre/ncs/v1.6.1/toolchain/segger_embedded_studio/bin/JLink_x64.dll
    Firmware Version: J-Link OB-K22-NordicSemi compiled Jul  2 2021 10:44:28
    DLL Version: 7.22b
    Hardware Version: V1.00
    Target Voltage: 3.300
  Device "NRF5340_XXAA_NET" selected.
  ConfigTargetSettings() start
  ConfigTargetSettings() end
  InitTarget() start
  InitTarget() end
  Found SW-DP with ID 0x6BA02477
  DPIDR: 0x6BA02477
  AP map detection skipped. Manually configured AP map found.
  AP[0]: AHB-AP (IDR: Not set)
  AP[1]: AHB-AP (IDR: Not set)
  AP[2]: MEM-AP (IDR: Not set)
  AP[3]: MEM-AP (IDR: Not set)
  AP[1]: Core found
  AP[1]: AHB-AP ROM base: 0xE00FE000
  CPUID register: 0x410FD214. Implementer code: 0x41 (ARM)
  Found Cortex-M33 r0p4, Little endian.
  FPUnit: 8 code (BP) slots and 0 literal slots
  Security extension: not implemented
  CoreSight components:
  ROMTbl[0] @ E00FE000
  ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB4C9 ROM Table
  ROMTbl[1] @ E00FF000
  ROMTbl[1][0]: E000E000, CID: B105900D, PID: 000BBD21 Cortex-M33
  ROMTbl[1][1]: E0001000, CID: B105900D, PID: 000BBD21 DWT
  ROMTbl[1][2]: E0002000, CID: B105900D, PID: 000BBD21 FPB
  ROMTbl[1][6]: E0042000, CID: B105900D, PID: 000BBD21 CSS600-CTI
Preparing target for download
  Executing Reset script TargetInterface.resetAndStop()
  ResetTarget() start
  ResetTarget() end
Downloading ‘zephyr.elf’ to J-Link
  Programming 190.4 KB of addresses 01000000 — 0102f9df
  Programming 2.1 KB of addresses 0102f9e0 — 01030263
  T-bit of XPSR is 0 but should be 1. Changed to 1.
  Timeout while preparing target, RAMCode did not respond in time. (PC = 0x00000000, CPSR = 0x00000000, LR = 0x61000003)!
  Failed to prepare RAMCode using RAM
  Failed to download application.
  Generic error.
  Please check J-Link and target connection.
Target connection has been lost
    DLL Version: 7.22b
  InitTarget() start
  InitTarget() end
  DPIDR: 0x6BA02477
  AP[1]: Core found
  ResetTarget() start
  ResetTarget() end
  J-Link: Flash download: Bank 1 @ 0x01000000: 1 range affected (198656 bytes)
  J-Link: Flash download: Total: 10.154s (Prepare: 0.136s, Compare: 0.042s, Erase: 8.400s, Program & Verify: 1.500s, Restore: 0.074s)
  J-Link: Flash download: Program & Verify speed: 129 KiB/s
Illegal value 0x210052E8 written to register 66 (MSP_NS) ignored
    DLL Version: 7.22b
  InitTarget() start
  InitTarget() end
  DPIDR: 0x6BA02477
  AP[1]: Core found
  ResetTarget() start
  ResetTarget() end
Downloading ‘zephyr_prebuilt.elf’ to J-Link
  Programming 0.1 KB of .intList addresses 21010000 — 21010097
  Timeout while preparing target, RAMCode did not respond in time. (PC = 0x00000000, CPSR = 0x21005B74, LR = 0x01000003)!
  Failed to write memory.
    DLL Version: 7.22b
  Device "NRF5340_XXAA_APP" selected.
  InitTarget() start
  InitTarget() end
  DPIDR: 0x6BA02477
  AP[0]: Core found
  AP[0]: AHB-AP ROM base: 0xE00FE000
  Security extension: implemented
  Secure debug: enabled
  ROMTbl[1][3]: E0000000, CID: B105900D, PID: 000BBD21 ITM
  ROMTbl[1][5]: E0041000, CID: B105900D, PID: 002BBD21 ETM
  ROMTbl[0][1]: E0040000, CID: B105900D, PID: 000BBD21 Cortex-M33
  Reset: ARMv8M core with Security Extension enabled detected.
  Reset: Halt core after reset via DEMCR.VC_CORERESET.
  Reset: Reset device via AIRCR.SYSRESETREQ.
Downloading ‘merged.hex’ to J-Link
  Programming 129.5 KB of addresses 00000000 — 0002060f
  J-Link: Flash download: Bank 1 @ 0x00000000: 1 range affected (135168 bytes)
  J-Link: Flash download: Total: 1.444s (Prepare: 0.135s, Compare: 0.032s, Erase: 0.173s, Program & Verify: 1.027s, Restore: 0.075s)
  J-Link: Flash download: Program & Verify speed: 128 KiB/s
    DLL Version: 7.22b
  InitTarget() start
  InitTarget() end
  DPIDR: 0x6BA02477
  AP[0]: Core found
  Programming 127.3 KB of addresses 00000000 — 0001fd7f
  Programming 2.1 KB of addresses 0001fd80 — 0002060f
  Programming 0.0 KB of .intList addresses 20070000 — 20070057
  J-Link: Flash download: Bank 1 @ 0x00000000: 3 ranges affected (12288 bytes)
  J-Link: Flash download: Total: 0.675s (Prepare: 0.134s, Compare: 0.101s, Erase: 0.264s, Program & Verify: 0.100s, Restore: 0.075s)
  J-Link: Flash download: Program & Verify speed: 119 KiB/s
    DLL Version: 7.22b
  InitTarget() start
  InitTarget() end
  DPIDR: 0x6BA02477
  AP[1]: Core found
  ResetTarget() start
  ResetTarget() end
  J-Link: Flash download: Total: 1.950s (Prepare: 0.138s, Compare: 0.056s, Erase: 0.175s, Program & Verify: 1.505s, Restore: 0.074s)
    DLL Version: 7.22b
  InitTarget() start
  InitTarget() end
  DPIDR: 0x6BA02477
  AP[1]: Core found
  ResetTarget() start
  ResetTarget() end
  Generic error.
    DLL Version: 7.22b
  InitTarget() start
  CTRL-AP indicates that the device is secured.
  For debugger connection the device needs to be unsecured.
  Note: Unsecuring will trigger a mass erase of the internal flash, SRAM and UICR of both the application and the network core.
  Executing default behavior previously saved in the registry.
  Device will be unsecured now.
  InitTarget() end
  DPIDR: 0x6BA02477
  AP[1]: Core found
  ResetTarget() start
  ResetTarget() end
  J-Link: Flash download: Total: 1.841s (Prepare: 0.220s, Compare: 0.044s, Erase: 0.000s, Program & Verify: 1.501s, Restore: 0.074s)
