modem shell : connects but fails to send traffic
I was using the AWS-IOT example and all was working until it wasnt. In troubleshooting this, I loaded the modem shell example, to see if it was a network/connection issue and although it connects (I get an IP), I am unable to ping google.com (by name or IP).
I looked at nrfcloud.com and the sim appears to have enough data left, Used 2.79MB of the 10MB .  Its iBasis sim that came with the board.
Details of the ping are below, I was wondering who to contact for this?  Nordic or iBasis ?
Output:
*** Booting Zephyr OS build v2.6.0-rc1-ncs1  ***
MOSH version:       v1.6.0
MOSH build id:      custom
MOSH build variant: dev
Initializing modemlib...
mosh:~$ Initialized modemlib
Network registration status: searching
LTE cell changed: Cell ID: 136926477, Tracking area: 12306
Currently active system mode: LTE-M
RRC mode: Connected
PDN event: PDP context 0 activated
Network registration status: Connected - roaming
PSM parameter update: TAU: -1, Active time: -1 seconds
Modem config for system mode: LTE-M
Modem config for LTE preference: No preference, automatically selected by the modem
Modem FW version:      mfw_nrf9160_1.2.3
Operator PLMN:        "50501"
Current cell id:       136926477 (0x0829550D)
Current band:          28
Current rsrp:          40: -101dBm
Current snr:           31: 6dB
Mobile network time and date: 21/10/02,05:33:39+40
PDP context info 1:
  CID:                    0
  PDN ID:                 0
  PDP context active:     yes
  PDP type:               IP
  APN:                    ibasis.iot
  IPv4 MTU:               1430
  IPv4 address:           10.155.149.218
  IPv6 address:           ::
  IPv4 DNS address:       62.93.146.209, 216.168.184.184
  IPv6 DNS address:       ::, ::
ping -d www.google.com
Initiating ping to: www.google.com
RRC mode: Connected
getaddrinfo(dest) error: -11
Cannot resolve remote host
RRC mode: Idle
mosh:~$ ping 142.25
mosh:~$
mosh:~$ ping -d 142.250.66.228
Initiating ping to: 142.250.66.228
Source IP addr: 10.155.149.218
Destination IP addr: 142.250.66.228
RRC mode: Connected
Pinging 142.250.66.228 results: no response in given timeout 3000 msec
Ping statistics for 142.250.66.228:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
Pinging DONE
regards
-brett
  • Hi Brett,
    It looks everything is fine before you start to use ping commands.
    I am not sure if this is an issue due to the local LTE network or just related to a specific sim card or hardware. Do you have several nRF9160DK boards to test with? Are you able to update Modem firmware to the latest and test with the latest NCS v1.7.0?
    Charlie
  • Hi Charlie,
    This has been working fine for months, so I dont think its the local network.
    I only have 1 x 9160DK - (I have a thingy 91 that I could try and swap the sim into), I also have a new sim coming from iBasis to replace the one from the thingy 91 (it expired).
    I will upgrade the modem firmware to the latest and try that.
    I was more curious how to troubleshoot where the problem might be and if there is any other way to identify if its, sim, network, board etc...
    cheers
    -brett
  • Hi Charlie,
    Modem Upgraded to 1.3.0, still same issue, and whats more strange, I cant even ping the DNS that was allocated.
    Tried to:
    * Ping google.com - failed
    * ping Ip of google - failed
    * ping DNS - failed
    * increased timeout to 10 seconds, just in case.
    I will install the 1.7.0 SDK and see how that goes. As mentioned earlier, I am more confused as to why all was working with the current environment, and all of the sudden it stopped working.
    Q: If the SIM was expired, or something wrong with it, would you expect to still get connections and an IP ?
    Ping:
    ping -t 10000 -d 62.93.146.209
    Initiating ping to: 62.93.146.209
    Source IP addr: 10.155.196.172
    Destination IP addr: 62.93.146.209
    RRC mode: Connected
    Pinging 62.93.146.209 results: no response in given timeout 10000 msec
    RRC mode: Idle
    RRC mode: Connected
    RRC mode: Idle
    RRC mode: Connected
    Ping statistics for 62.93.146.209:
    Pinging DONE
    RRC mode: Idle
    Boot Details:
    RRC mode: Connected
    Modem FW version:      mfw_nrf9160_1.3.0
    Current band:          28
    Current rsrp:          41: -100dBm
    Current snr:           26: 1dB
    Mobile network time and date: 21/10/04,11:57:39+44
    PDP context info 1:
      CID:                    0
      PDN ID:                 0
      PDP type:               IP
      APN:                    ibasis.iot
      IPv4 MTU:               1430
      IPv4 address:           10.155.196.172
      IPv6 address:           ::
    RRC mode: Idle
    cheers
    -brett
  • Hi Charlie,
    Sorry for the spam :) dont know why I didnt think of this earlier....
    I used the sim from my phone, and it all worked fine - so I gather its an issue with iBasis ?
    RRC mode: Connected
    Network registration status: Connected - home network
    PDN event: PDP context 0 IPv6 up
    Operator full name:   "Telstra #LetsVaxx"
    Operator short name:  "Telstra@"
    Current band:          28
    Current rsrp:          44: -97dBm
    Current snr:           29: 4dB
    Mobile network time and date: 21/10/04,12:26:15+44
    PDP context info 1:
      CID:                    0
      PDN ID:                 0
      PDP type:               IPV4V6
      APN:                    telstra.internet
      IPv4 MTU:               1500
      IPv4 address:           10.115.220.233
      IPv6 address:           2001:8004:2748:f59:801a:b250:e5fa:8ad0
      IPv4 DNS address:       101.168.244.100, 10.4.58.204
      IPv6 DNS address:       2001:8004:2d43:900::, 2001:8004:0:100:7:e1c0:0:14
    mosh:~$
    mosh:~$ ping -d www.google.com
    Source IP addr: 10.115.220.233
    Destination IP addr: 142.250.70.164
    Pinging www.google.com results: time=0.079secs, payload sent: 0, payload received 0
    Pinging www.google.com results: time=0.092secs, payload sent: 0, payload received 0
    Pinging www.google.com results: time=0.098secs, payload sent: 0, payload received 0
    Ping statistics for www.google.com:
        Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
    Approximate round trip times in milli-seconds:
        Minimum = 79ms, Maximum = 98ms, Average = 91ms
    Pinging DONE
    RRC mode: Idle
    mosh:~$
  • Hi Brett,
    You can enable mode trace recording to get more details. nRF Connect for Desktop -> Trace Collector V2 Preview allows the developer to review the modem trace RCAP data directly with Wirehark.
    Looking forward to seeing the result of your further experiments.
    Best regard,
    Charlie
