i have nrf52832 sdk vr 17.0.2. i want to set transmission power of advertising packet. pls assist
static void advertising_init(){
ret_code_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.srdata.uuids_more_available.uuid_cnt=sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.srdata.uuids_more_available.p_uuids =m_adv_uuids;
init.config.ble_adv_whitelist_enabled = false;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
uint32_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, 4);
is it how shall it work?? i have added
pls chek
Yes, thought you do not need to have the type declaration there since you've already declared it at the beginning of your function.
Are you not seeing an increase in the RSSI when you've added this line?
Karl
yes, i found that increasing power in adv increases the RSSI.
Kindly tell by default what is the power used if i dont add the sd_ble_gap_tx_power_set().
Also, what is the default PHY used
Ridhi said:yes, i found that increasing power in adv increases the RSSI.
Great, I'm happy to hear that it worked as expected.
Ridhi said:Kindly tell by default what is the power used if i dont add the sd_ble_gap_tx_power_set().
The default txpower is +0, and the BLE advertising library default to using 1M PHY if no other phy is specified for the advertising mode, this happens in the following section of ble_advertising_start
// Use 1MBIT as primary phy if no phy was selected.
if (phy_is_valid(&p_advertising->adv_modes_config.ble_adv_primary_phy))
p_advertising->adv_params.primary_phy = p_advertising->adv_modes_config.ble_adv_primary_phy;
p_advertising->adv_params.primary_phy = BLE_GAP_PHY_1MBPS;
..thnku Karl,
wud like to know that min how much time an advertising event takes. Like adv interval can range from 20 ms to 10.24s. i want to know min an event take how much time
