Dear nRF,
My questions are related to high voltage mode of nRF52840 and SWD. My target is to design as high performance solution as possible and current consumption will not be an issue.
I have been following Reference Circuit #2 (QIAA), found from this link.
Input voltage is 5V1 for the nRF, supplied from switching regulator and equipped with decent amount of ferrites and bypass caps.
I appreciate if you can answer to the following questions:
- Will I need to configure the firmware of nRF to enable internal LDOs or is the powering selection automatic?
- How do I choose correct voltage settings provided that the nRF52840 ICs are shipped empty ones, with no FW inside? Is there any documentation about this?
- Which are the benefits to use low voltage mode or high voltage mode? In HV mode, buck regulators are not needed and I assume there will not be problems with spurious (interferers) ?
- SWD with high voltage mode, should I connect the VDD_nRF from external nRF52840-dk to the my custom board net VDD_nRF at pin W1 via pin header in order to maintain correct voltage level for SWD operations? I assume my 5V1 power supply should be disconnected when doing this operation.
