As I have already connected two peripherals at the same time, the central can automatically receive and display the data only for the first connection.
While I tried to receive the data from both two connections and displayed the data by UART.
I think it is mainly relevant to the ble_data_received function that writes the "tx" to the FIFO of "fifo_inc_ble_data" then read it when UART interrupts.
However, I actually don't know how to add anther tx linking with the second connection to write the second data to FIFO,
or should I give anther FIFO which gets the second data to the UART?
Hence, can you please tell me where should I modify or some configurations were missing?
#include <errno.h>
#include <zephyr.h>
#include <sys/byteorder.h>
#include <sys/printk.h>
#include <sys/util.h>
#include <string.h>
#include <usb/usb_device.h>
#include <drivers/uart.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/hci.h>
#include <bluetooth/conn.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/services/nus.h>
#include <bluetooth/services/nus_client.h>
#include <bluetooth/gatt_dm.h>
#include <bluetooth/scan.h>
#include <settings/settings.h>
#include <logging/log.h>
#include <device.h>
#include <devicetree.h>
#include <drivers/gpio.h>
#define LED0_NODE DT_ALIAS(led0)
#if DT_NODE_HAS_STATUS(LED0_NODE, okay)
#define LED0 DT_GPIO_LABEL(LED0_NODE, gpios)
#define PIN DT_GPIO_PIN(LED0_NODE, gpios)
#define FLAGS DT_GPIO_FLAGS(LED0_NODE, gpios)
#else
/* A build error here means your board isn't set up to blink an LED. */
#error "Unsupported board: led0 devicetree alias is not defined"
#define LED0 ""
#define PIN 0
#define FLAGS 0
#define LED1_NODE DT_ALIAS(led1)
#if DT_NODE_HAS_STATUS(LED1_NODE, okay)
#define LED1 DT_GPIO_LABEL(LED1_NODE, gpios)
#define PIN1 DT_GPIO_PIN(LED1_NODE, gpios)
#define FLAGS1 DT_GPIO_FLAGS(LED1_NODE, gpios)
#else
#define LED0 ""
#define PIN 0
#define FLAGS 0
#define LOG_MODULE_NAME central_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
/* UART payload buffer element size. */
#define UART_BUF_SIZE 100
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define NUS_WRITE_TIMEOUT K_MSEC(150)
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_RX_TIMEOUT 50
int counter;
int con_num = 0;
#define DEVICE_NAME "FF_22"
char device_name[5]="FF_22";
char *name = device_name;
static const struct device *uart;
static struct k_work_delayable uart_work;
K_SEM_DEFINE(nus_write_sem, 0, 1);
struct uart_data_t {
void *fifo_reserved;
uint8_t data[UART_BUF_SIZE];
uint16_t len;
static K_FIFO_DEFINE(fifo_inc_ble_data);
static K_FIFO_DEFINE(fifo_out_ble_data);
static struct bt_conn *default_conn;
static struct bt_nus_client nus_client;
const struct device *dev;
bool led_is_on = true;
bool led1_is_on = true;
int ret;
static void ble_data_sent(uint8_t err, const uint8_t *const data, uint16_t len)
LOG_INF("BLE data sent!");
struct uart_data_t *buf;
/* Retrieve buffer context. */
buf = CONTAINER_OF(data, struct uart_data_t, data);
k_free(buf);
// k_sem_give(&nus_write_sem);
if (err) {
LOG_WRN("ATT error code: 0x%02X", err);
static uint8_t ble_data_received(const uint8_t *const data, uint16_t len)
LOG_INF("BLE data arrived! length %d",len);
struct uart_data_t *tx = k_malloc(sizeof(*tx));
if(!tx){
LOG_INF("malloc failed!");
else{
tx->len = len;
memcpy(tx->data,data,len);
k_fifo_put(&fifo_inc_ble_data, tx);
uart_irq_tx_enable(uart); //display the received data
counter++;
if(counter == 50)
if (con_num == 1)
gpio_pin_set(dev, PIN1, false); //off LED2
gpio_pin_set(dev, PIN, (int)led_is_on);
led_is_on = !led_is_on;
else if(con_num == 2)
gpio_pin_set(dev, PIN, false); //off LED1
gpio_pin_set(dev, PIN1, (int)led1_is_on);
led1_is_on = !led1_is_on;
counter = 0;
return BT_GATT_ITER_CONTINUE;
static void uart_isr( void *dev)
uart_irq_update(dev);
if(uart_irq_rx_ready(dev))
LOG_INF("Data to read on RX");
struct uart_data_t *rx = k_malloc(sizeof(*rx));
if(!rx){
else{
uint8_t len = uart_fifo_read(dev,rx->data,UART_BUF_SIZE);
rx->len = len;
k_fifo_put(&fifo_out_ble_data, rx);
if(uart_irq_tx_ready(dev))
LOG_INF("SPACE IN UART FIFO FOR MORE");
if(!k_fifo_is_empty(&fifo_inc_ble_data))
struct uart_data_t *tx = k_fifo_get(&fifo_inc_ble_data, K_NO_WAIT);
LOG_INF("tx from queue is: %d",tx);
uart_fifo_fill(dev, tx->data, tx->len);
k_free(tx);
// else{
// LOG_INF("NO TX");
if(uart_irq_tx_complete)
LOG_INF("TX done.");
static int uart_init(void)
LOG_INF("Enabling UART");
int err;
uart = device_get_binding(CONFIG_UART_CONSOLE_ON_DEV_NAME);
if (!uart) {
LOG_ERR("UART binding failed");
return -ENXIO;
if (usb_enable(NULL)) {
return -1;
if (strlen(CONFIG_UART_CONSOLE_ON_DEV_NAME) !=
strlen("CDC_ACM_0") ||
strncmp(CONFIG_UART_CONSOLE_ON_DEV_NAME, "CDC_ACM_0",
strlen(CONFIG_UART_CONSOLE_ON_DEV_NAME))) {
printk("Error: Console device name is not USB ACM\n");
return -1;
uart_irq_callback_set(uart,uart_isr);
uart_irq_callback_user_data_set(uart,uart_isr,uart);
uart_irq_rx_enable(uart);
return 0;
static void discovery_complete(struct bt_gatt_dm *dm,
void *context)
struct bt_nus_client *nus = context;
LOG_INF("Service discovery completed");
bt_gatt_dm_data_print(dm);
bt_nus_handles_assign(dm, nus);
bt_nus_subscribe_receive(nus);
bt_gatt_dm_data_release(dm);
static void discovery_service_not_found(struct bt_conn *conn,
void *context)
LOG_INF("Service not found");
static void discovery_error(struct bt_conn *conn,
int err,
void *context)
LOG_WRN("Error while discovering GATT database: (%d)", err);
struct bt_gatt_dm_cb discovery_cb = {
.completed = discovery_complete,
.service_not_found = discovery_service_not_found,
.error_found = discovery_error,
static void gatt_discover(struct bt_conn *conn)
int err;
if (conn != default_conn) {
return;
err = bt_gatt_dm_start(conn,
BT_UUID_NUS_SERVICE,
&discovery_cb,
&nus_client);
if (err) {
LOG_ERR("could not start the discovery procedure, error "
"code: %d", err);
static void exchange_func(struct bt_conn *conn, uint8_t err, struct bt_gatt_exchange_params *params)
if (!err) {
LOG_INF("MTU exchange done: %d",bt_att_get_mtu(conn));
} else {
LOG_WRN("MTU exchange failed (err %" PRIu8 ")", err);
static void connected(struct bt_conn *conn, uint8_t conn_err)
int err;
if (conn_err) {
LOG_INF("Failed to connect to %s (%d)", log_strdup(addr),
conn_err);
if (default_conn == conn) {
bt_conn_unref(default_conn);
default_conn = NULL;
err = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
if (err) {
LOG_ERR("Scanning failed to start (err %d)",
err);
return;
LOG_INF("Connected: %s", log_strdup(addr));
static struct bt_gatt_exchange_params exchange_params;
exchange_params.func = exchange_func;
err = bt_gatt_exchange_mtu(conn, &exchange_params);
if (err) {
LOG_WRN("MTU exchange failed (err %d)", err);
err = bt_conn_set_security(conn, BT_SECURITY_L2);
if (err) {
LOG_WRN("Failed to set security: %d", err);
gatt_discover(conn);
if (err) {
LOG_ERR("Scanning failed to start (err %d)", err);
return;
LOG_INF("Scanning again");
int err;
LOG_INF("Disconnected: %s (reason %u)", log_strdup(addr),
reason);
con_num--;
if (con_num == 0)
if (default_conn != conn) {
return;
if (err) {
err);
static void security_changed(struct bt_conn *conn, bt_security_t level,
enum bt_security_err err)
if (!err) {
LOG_INF("Security changed: %s level %u", log_strdup(addr),
level);
} else {
LOG_WRN("Security failed: %s level %u err %d", log_strdup(addr),
level, err);
static struct bt_conn_cb conn_callbacks = {
.connected = connected,
.disconnected = disconnected,
.security_changed = security_changed
static void scan_filter_match(struct bt_scan_device_info *device_info,
struct bt_scan_filter_match *filter_match,
bool connectable)
bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
LOG_INF("Filters matched. Address: %s connectable: %d",
log_strdup(addr), connectable);
con_num++;
LOG_INF("Connection number: %d",con_num); //record the peripheral connection number
static void scan_connecting_error(struct bt_scan_device_info *device_info)
LOG_WRN("Connecting failed");
static void scan_connecting(struct bt_scan_device_info *device_info,
default_conn = bt_conn_ref(conn);
static int nus_client_init(void)
int err;
struct bt_nus_client_init_param init = {
.cb = {
.received = ble_data_received,
.sent = ble_data_sent,
err = bt_nus_client_init(&nus_client, &init);
if (err) {
LOG_ERR("NUS Client initialization failed (err %d)", err);
return err;
LOG_INF("NUS Client module initialized");
return err;
BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL,
scan_connecting_error, scan_connecting);
static int scan_init(void)
int err;
struct bt_scan_init_param scan_init = {
.connect_if_match = 1,
bt_scan_init(&scan_init);
bt_scan_cb_register(&scan_cb);
err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_NAME, DEVICE_NAME);
if (err) {
LOG_ERR("Scanning filters cannot be set (err %d)", err);
return err;
err = bt_scan_filter_enable(BT_SCAN_NAME_FILTER, false);
if (err) {
LOG_ERR("Filters cannot be turned on (err %d)", err);
return err;
LOG_INF("Scan module initialized");
return err;
static void auth_cancel(struct bt_conn *conn)
LOG_INF("Pairing cancelled: %s", log_strdup(addr));
static void pairing_confirm(struct bt_conn *conn)
bt_conn_auth_pairing_confirm(conn);
LOG_INF("Pairing confirmed: %s", log_strdup(addr));
static void pairing_complete(struct bt_conn *conn, bool bonded)
LOG_INF("Pairing completed: %s, bonded: %d", log_strdup(addr),
bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
LOG_WRN("Pairing failed conn: %s, reason %d", log_strdup(addr),
reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
.cancel = auth_cancel,
.pairing_confirm = pairing_confirm,
.pairing_complete = pairing_complete,
.pairing_failed = pairing_failed
void main(void)
int err;
dev = device_get_binding(LED0);
if (dev == NULL) {
return;
ret = gpio_pin_configure(dev, PIN, GPIO_OUTPUT_INACTIVE | FLAGS);
if (ret < 0) {
return;
dev = device_get_binding(LED1);
if (dev == NULL) {
return;
ret = gpio_pin_configure(dev, PIN1, GPIO_OUTPUT_INACTIVE | FLAGS1);
if (ret < 0) {
return;
err = bt_conn_auth_cb_register(&conn_auth_callbacks);
if (err) {
LOG_ERR("Failed to register authorization callbacks.");
return;
err = bt_enable(NULL);
if (err) {
LOG_ERR("Bluetooth init failed (err %d)", err);
return;
LOG_INF("Bluetooth initialized");
if (IS_ENABLED(CONFIG_SETTINGS)) {
settings_load();
bt_conn_cb_register(&conn_callbacks);
int (*module_init[])(void) = { uart_init, scan_init, nus_client_init};
for (size_t i = 0; i < ARRAY_SIZE(module_init); i++) {
err = (*module_init[i])();
if (err) {
return;
LOG_INF("Initialized done.");
printk("Starting Bluetooth Dongle\n");
if (err) {
return;
LOG_INF("Scanning successfully started");
for (;;) {
Thank you in advance for any suggestions here!
Best Regards
Ethan
