How to use the trigger library to program the nRF52840 dongle
Sorry but I find the documentation useless. I don't even know where to start. It could be I have not found the correct documentation which is not surprising.
The best I have is this: https://devzone.nordicsemi.com/f/nordic-q-a/77254/nrf52840-dongle-pca10059-dfu-trigger-library/332347#332347
but I have no idea how this even started.
Right now the project works. I can use the reset button to flash the dongle and it works. Its a BTLE peripheral that a cycle power client connects to at which time the device starts a scanner and gets data from an unconnectable advertisement from a bike and notifies the data to the client. The USB is used only as a source of power. The project uses SoftDevice for BTLE and flash writes and not the SDK.
Now I want to add the overhead to be able program the dongle without touching the reset button. I don't know where to start. It's clear I have to add lots of h-files and c-files to the project. However, where do I find the steps that document how one adds this functionality to an existing project?
  • What methods do I need to call and when?
  • What configuration parameters do I need to set outside of sdk_config.h?
  • What configuration parameters do I need to set in sdk_config.h?
  • Where are these methods and h-files located so I can pull/configure my project?
One final question, how much overhead does this add? Will it greatly increase the size of my executable project?
When and if this ever gets completed, would that mean I can flash the dongle directly from Keil or Segger or do I still need nRF_Connect that I use now where I have to press the reset button?
