nrf52840, with zephyr, running button example, can't find my board
hello Nordic
i am working with nrf52840, with zephyr (i am new to zephyr)
i have an issue with not responding pin interrupt so i try to run zephyr example to see how it works there but when trying to build with my board i get an error that the file is not found and it is looking in boards/arc instead of boards/arm, i could not find how to change this search path
any ideas will be appreciated
best regards
Ziv
  • Hello Ziv,
    which Zephyr sample are you trying to build? Could you please provide me with a full build log so that I can see where the compiler stops?
    Thanks and regards,
    Markus
  • which Zephyr sample are you trying to build? Could you please provide me with a full build log so that I can see where the compiler stops?
    the basic -> button sample
    the log :
    button git:(fa70572d1d) west build -b canary_proto_rev_3 -- -DBOARD_ROOT=/home/zhershkovitch/workspace/canary_ep -DARCH=arm
    Including boilerplate (Zephyr base): /home/zhershkovitch/workspace/ncs/zephyr/cmake/app/boilerplate.cmake
    CMake Deprecation Warning at /home/zhershkovitch/workspace/ncs/zephyr/cmake/app/boilerplate.cmake:37 (cmake_policy):
      The OLD behavior for policy CMP0079 will be removed from a future version
      of CMake.
      The cmake-policies(7) manual explains that the OLD behaviors of all
      policies are deprecated and that a policy should be set to OLD only under
      specific short-term circumstances.  Projects should be ported to the NEW
      behavior and not rely on setting a policy to OLD.
      /home/zhershkovitch/workspace/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
      /home/zhershkovitch/workspace/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
      CMakeLists.txt:4 (find_package)
    -- Application: /home/zhershkovitch/workspace/ncs/zephyr/samples/basic/button
    -- Zephyr version: 2.4.99 (/home/zhershkovitch/workspace/ncs/zephyr)
    -- Found Python3: /usr/bin/python3.9 (found suitable exact version "3.9.7") found components: Interpreter
    -- Found west (found suitable version "0.10.1", minimum required is "0.7.1")
    -- Board: canary_proto_rev_3
    No board named 'canary_proto_rev_3' found.
    Please choose one of the following boards:
      File "/home/zhershkovitch/workspace/ncs/zephyr/scripts/list_boards.py", line 113, in <module>
        dump_boards(find_arch2boards(parse_args()))
      File "/home/zhershkovitch/workspace/ncs/zephyr/scripts/list_boards.py", line 32, in find_arch2boards
        arch2board_set = find_arch2board_set(args)
      File "/home/zhershkovitch/workspace/ncs/zephyr/scripts/list_boards.py", line 45, in find_arch2board_set
        for arch, boards in find_arch2board_set_in(root, arches).items():
      File "/home/zhershkovitch/workspace/ncs/zephyr/scripts/list_boards.py", line 78, in find_arch2board_set_in
        for maybe_board in (boards / arch).iterdir():
      File "/usr/lib/python3.9/pathlib.py", line 1160, in iterdir
        for name in self._accessor.listdir(self):
    FileNotFoundError: [Errno 2] No such file or directory: '/home/zhershkovitch/workspace/canary_ep/boards/arc'
    CMake Error at /home/zhershkovitch/workspace/ncs/zephyr/cmake/app/boilerplate.cmake:383 (message):
      Invalid BOARD; see above.
    FATAL ERROR: command exited with status 1: /usr/bin/cmake -DWEST_PYTHON=/usr/bin/python -B/home/zhershkovitch/workspace/ncs/zephyr/samples/basic/button/build -S/home/zhershkovitch/workspace/ncs/zephyr/samples/basic/button -GNinja -DBOARD=canary_proto_rev_3 -DBOARD_ROOT=/home/zhershkovitch/workspace/canary_ep -DARCH=arm
    ➜  button git:(fa70572d1d)
    the log :
    Thank you, Ziv!
    So you already have tried to place your board files here, without the compiler finding them?
    Markus
  • So you already have tried to place your board files here, without the compiler finding them?
    i gave a path to the boards/arm in my project
    Normally, if you are placing the board files in this location you do not have to specify its path as the compiler will find it himself. Could you test this?
    Markus
