NCS, nRF52811, and peripheral_hr_coded sample
Greetings,
What are the settings to allow an nRF52811 to use CODED PHY with the NCS peripheral_hr_coded sample?
  • NCS v1.7.0
  • board = ubx_bmd360eval_nrf52811 (effectively a PCA10040 with a nRF52811 in place of the nRF52832)
Failing that, are there any other NCS examples that enable CODED PHY on an nRF52811 (peripheral only)?
Thanks
Bob
  • Hello Bob,
    You should be able to configure to use CODED PHY on your nRF52811 just as demonstrated in the peripheral_hr_coded sample. Are you getting any warnings or errors when you attempt this?
    Failing that
    Could you elaborate on how the example fails? What are you using for your central device? In the case of a phone, please make sure that the phone supports coded PHY - not all phones do this.
    Karl
  • Hi Karl,
    When I select the the board ubx_bmd360eval_nrf52811, the linker indicates there is not enough RAM, overflow by 4417 bytes.
    When I select the board nrf52840_nrf52811, I see the same error, except the RAM overflow is bit smaller at 3137 bytes.
    Bob
  • Hello again, Bob
    Thank you for your patience with this.
    I just built the example myself for the nRF52840 and it comes out at requiring 34 kB RAM in its unmodified state, while the nRF52811 has only got 24 kB RAM.
    You could try removing any unnecessary parts (BAT and HRS service, logging, etc) to create a minimal example, and then build it up from there, to see if you will fit your entire application onto the nRF52811 SoC.
    Could you detail what else your application will be doing?
    Unfortunately, the hrs_coded_phy example is the only coded phy example currently available in ncs - but you could read through this ticket where my colleague Simon and another user modified the UART example to use coded phy (they also discuss some other, irrelevant issues throughout, but the coded phy part is the main interest).
    This board configuration is meant for when you are using a nrf52840 SoC to emulate a nRF52811 SoC for development - so it assumes a nRF52840 baseline when building.
    Karl
  • Thanks Karl.
    I was hoping for a little guidance on which parts could be removed without breaking the sample code. Seems HRS would be needed for a heart rate example ;-).
    I'm only trying to demonstrate a Coded PHY connection with an nRF52811, so there's no final target application. I'd use a nRF52840 for the central running the central_hr_coded sample.
    I've been pulled into another project, so I might not be able to get back to this for a bit.
    Bob
  • Hello again Bob,
    Thank you for your continued patience with this.
    Oh, I understand - my mistake. I only thought you wanted the Coded PHY connection and not necessarily the rest of the example's contents.
    Aha, then I understand why you'd like to have as much of the hrs application intact. We might be able to achieve a smaller footprint without Zephyr. I will give it a try next week and see what comes of it.
    No worries - I'll dig around and see if I cant come up with an example of this, I'll update you if I find something! :)
    Karl
  • Hello again, Bob
    Thank you for your patience with this!
    I have been unsuccessfully in tracking down an example that achieves this, so I gave this a try myself with the nRF5 SDK v15.2.0 and the SoftDevice S140 v6.1.0 emulated on the nRF52840 DK, modifying the BLE UART example, but I was unfortunately only able to get it to ~29 kB RAM usage - so it is still too large for the nRF52811.
    You might be able to shave off a few kB off the RAM usage if you scrutinize it line by line, but I think it is unlikely that you may get it to 24 kB total with the functionality intact, unfortunately.
    Karl
  • Hello again, Bob
    Karl
