PStorage handler only called when compiled under DEBUG (eclipse gcc)
I have a pstorage Clear and Store that I use just before calling bootloader_app_start() in my DFU bootloader code. Everything was working great testing/compiling (GCC) under debug. But when I compile a release, the pstorage_raw_clear() and pstorage_raw_store() calls never prompt the handler callback function. I've tested over and over to verify.
I used a while loop to wait until the callback handler clears a variable: while (pstorage_wait_flag) { sd_app_evt_wait(); }
But this seems to never return under a release compile. I've never had an issue like this before so I've very confused as to how to go about solving.
I am using SDK 6.1 S110 7.1. I am using raw mode and clearing One pg of Flash (1024b) and Storing One pg of Flash (1024b). I also have a One pg global static Ram buffer. Thank in advance for the assistance guys.
DC
  • Any assert()s in your code which are getting entirely compiled out under NDEBUG? Looking at the preprocessed output sometimes helps that.
    compiler know that pstorage_wait_flag is volatile and not optimising it away? These days I often build optimised code still with full debug symbols, doesn't make the actual code different or slower or larger, and the debugs do bounce around a bit, but it sometimes gives some clues down at the assembler level what's been optimized out.
  • I mean do you have any code which looks like this
    assert( some_important_function_call() == SUCCESS_VALUE );
    instead of
    uint32_t return_code = some_important_function_call();
    assert( return_code == SUCCESS_VALUE );
    That's a surprisingly easy way to break release builds.
    And why not also try setting the flag to volatile so the compiler knows not to optimise out the loop.
    instead of
