Hi, For our current application we are using NRF51822, SDK 6.1, Soft device s110 ver 7.1.0. In our application nRF is configured as SPI Slave and another controller as SPI master. For this implementation I have considered example project “spi_slave”. As per implementation, whenever nRF is ready with data to transfer to controller, it first fills the DMA buffers and makes a GPIO pin High to interrupts the controller. SPI master (controller) will read the data from SPI port in ISR routine. I have observed that sometimes controller is reading default character clocked out from NRF. Here I am giving more explanation.
When nrf is ready with data, it fills the DMA Buffer.
error_code = spi_slave_buffers_set(m_tx_buf, m_rx_buf,(unp_updated_len+1), UNP_PACKET_MAX_SIZE);
semaphore_status = acquired;
in the spi interrupt routine I am enabling the GPIO pin high to give the interrupt to the controller
void SPI1_TWI1_IRQHandler(void)
// @note: as multiple events can be pending for processing, the correct event processing order
// is as follows:
// - SPI semaphore acquired event.
// - SPI transaction complete event.
// Check for CPU semaphore acquired event.
if (NRF_SPIS1->EVENTS_ACQUIRED != 0)
NRF_SPIS1->EVENTS_ACQUIRED = 0;
//semaphore_status = acquired;
/** SPI is not ready to receive and transmit data */
NRF_SPIS1->DEF = NRF51_STATE_BUSY;
switch (m_spi_state)
case SPI_BUFFER_RESOURCE_REQUESTED:
NRF_SPIS1->TXDPTR = (uint32_t)mp_spi_tx_buf;
NRF_SPIS1->RXDPTR = (uint32_t)mp_spi_rx_buf;
NRF_SPIS1->MAXRX = m_spi_rx_buf_size;
NRF_SPIS1->MAXTX = m_spi_tx_buf_size;
NRF_SPIS1->TASKS_RELEASE = 1u;
if(semaphore_status == acquired)
semaphore_status = released;
nrf_gpio_pin_set(INTERRUPT_TO_STM);
//NRF_SPIS1->DEF = NRF51_STATE_RXDATA_AVAIL;
NRF_SPIS1->DEF =NRF51_STATE_BUSY;
/* release STM Interrupt */
sm_state_change(SPI_BUFFER_RESOURCE_CONFIGURED);
// No implementation required.
// Check for SPI transaction complete event.
if (NRF_SPIS1->EVENTS_END != 0)
NRF_SPIS1->EVENTS_END = 0;
/* Clear STM32 interrupt */
//NRF_SPIS1->DEF = NRF51_STATE_TXDATA_ONLY;
case SPI_BUFFER_RESOURCE_CONFIGURED:
sm_state_change(SPI_XFER_COMPLETED);
num_bytes_received= NRF_SPIS1->AMOUNTRX;
I am ensuring that by the time GPIO high (interrupt to the controller) hardware semaphore was released by CPU , and semaphore is available with SPI slave. Sometimes I am always reading the default character from slave. Could please comment on my implementation, if something is wrong. Regards, Raju
