NRF_LOG_INFO() and printf() doesn't print
Hi, I'm using nRF52805.
In my code, I used BLE to transmit I2C and ADC data to the mobile app nRF Connect correctly and continuously.
I tried to use NRF_LOG_INFO() and printf() to print some information on either PuTTY or RTT Viewer (only use 1 Hyperterminal at one time). However, nothing is printed.
Here are my seetings:
1) NRF_LOG_PROCESS() or NRF_LOG_FLUSH() is called regularly.
2) Both NRF_LOG_INIT() and the NRF_LOG_DEFAULT_BACKENDS_INIT() macro are placed at the beginning of main.
3) NRF_LOG_ENABLED  = 1
4) Added breakpoint in debug mode, the NRF_LOG_INFO() and printf()  are reached.
My SDK is provided SDK.txt
Does anyone have any clue? Thanks.
    Thank you for providing the sdk_config.h file.
    Since you're using the RTT backend for the logger the logs will only be visible in an RTT monitor, like RTT Viewer or the debug terminal in SES - PuTTY should however show printf statements, since you have RETARGET enabled in your sdk_config.h. Are you not seeing any of the printf statements in PuTTY either?
    I'm using nRF52805
    Could you elaborate on this - are you using the nRF52805 on a custom board, or emulated on a DK?
    If you are using a custom board, how are you programming / connecting a debugger to your board?
    Could you elaborate on how often NRF_LOG_PROCESS is called, and have you verified that the program actually makes it to the NRF_LOG_PROCESS call?
    Since you are using the deferred logging option no logs will be processed until NRF_LOG_PROCESS is called. This is a common reason for logs not showing.
    Could you try to disable the deferred logging option, and see if you then see logs appear as your calls to NRF_LOG_INFO happens?
    Karl
  • Thanks, Karl.
    I solved the problem. Here are my correct SDK settings:
    NRF_LOG_ENABLED  = 1
    NRF_LOG_BACKEND_RTT_ENABLED 1
    NRF_LOG_DEFERRED = 0
    Now, I can use NRF_LOG_INFO(""); to see the loggings in RTT Viewer.
    Plz refer to this link to see logger config
  • Thanks, Karl.
    Great, I am happy to hear that you were able to resolve the issue!
    If logs are showing now that you do not have the DEFERRED option set this likely means that NRF_LOG_PROCESS is not being called as often as you had though initially, which might be worthwhile to take a look at.
    Leaving DEFERRED disabled will mean that log processing happens in-place, which could slow down your program, or otherwise increase the execution time of functions that contain a lot of logging, so please also keep this in mind.
    Karl
