Manually Building Without West And Mis-Named "sdk-nrf" Repository.
The issue lies in the "Kconfig" for the "sdk-*" repositories.
When you clone them, the folder name is "sdk-*" (eg. "sdk-nrf").
But the Kconfig contains 'source "${ZEPHYR_BASE}/../nrf/subsys/fw_info/Kconfig.template.fw_info_ext_api"'. Note the "/nrf/" path != "sdk-nrf".
So if I:
$ git clone https://github.com/nrfconnect/sdk-zephyr.git
$ git clone https://github.com/nrfconnect/sdk-nrf.git
$ cd ./sdk-zephyr
$ cmake -B build -DCROSS_COMPILE=/usr/bin/arm-none-eabi- -DBOARD=nrf52840dongle_nrf52840 -DCMAKE_PREFIX_PATH=<pathTo>/sdk-zephyr -DZEPHYR_MODULES="<pathTo>/sdk-nrf/" samples/hello_world/
I get:
-- Including generated dts.cmake file: <pathTo>/sdk-zephyr/build/zephyr/dts.cmake
warning: HAS_NORDIC_DRIVERS (defined at modules/hal_nordic/Kconfig:7) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols:
- SOC_SERIES_NRF52X (defined at soc/arm/nordic_nrf/nrf52/Kconfig.series:6), with value y, direct dependencies <choice> (value: y), and select condition <choice> (value: y)
When I rename that "sdk-nrf" folder to "nrf", I get past that issue, and on to another one:
warning: the hex symbol NRF_MODEM_LIB_SHMEM_CTRL_SIZE (defined at <pathTo>/nrf/lib/nrf_modem_lib/Kconfig:109) has a non-hex default NRF_MODEM_SHMEM_CTRL_SIZE (undefined)
Since I see that value exists in sdk-nrfxlib, I rename that folder and at it to DZEPHYR_MODULES which then results in:
-- Zephyr version: 2.6.99 (<pathTo>/sdk-zephyr), build: e0448d102b8e
CMake Error at <pathTo>/sdk-zephyr/cmake/zephyr_module.cmake:61 (message):
 Unmet or cyclic dependencies in modules:
 <pathTo>/nrfxlib/ depends on: ['hal_nordic']
So, before, "NRF_MODEM_SHMEM_CTRL_SIZE" was "undefined". And then when I add the module that defines it, it then complains about circle-dependency?
That does not appear to be related to https://devzone.nordicsemi.com/f/nordic-q-a/77751/sdk-v-1-6-project-creation-issue/321288#321288, as I had tested it by putting it all in /wtf/.
I guess as another heads-up (not yet an issue?):
Including boilerplate (Zephyr base (cached)): <pathTo>/sdk-zephyr/cmake/app/boilerplate.cmake
CMake Deprecation Warning at <pathTo>/sdk-zephyr/cmake/app/boilerplate.cmake:37
(cmake_policy):
 The OLD behavior for policy CMP0079 will be removed from a future version of CMake.
 The cmake-policies(7) manual explains that the OLD behaviors of all
 policies are deprecated and that a policy should be set to OLD only under
 specific short-term circumstances.  Projects should be ported to the NEW
 behavior and not rely on setting a policy to OLD.
<pathTo>/sdk-zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
<pathTo>/sdk-zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
 CMakeLists.txt:5 (find_package)
    When installing manually, please follow this guide:
    http://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.7.0/nrf/gs_installing.html
    The reason why you're seeing errors is because you do not have depending repositories (nrfxlib, hal_nordic etc)
    Håkon
  • Yeah, I know about that link.
    In my previous post, I had mentioned about how I wanted to do things manually, particularly without "west".
    I'm coming from having started with my ST as my first device, where the build/debug process is quite different. I've also got an espressif device coming and taking a look at their docs, nordic and espressif seem to have a very similar build process.
    With ST, I've got the build down in vscode to manually selecting required code files to boot, compiling with arm-none-eabi-* which archlinux provides and using the cortex-debug vscode extension to flash/debug. Very few requirements compared to nordic and espressif.
    I did have sdk-nrfxlib mentioned added in my OP, but you were right about sdk-hal_nordic and "memfault-firmware-sdk", which I added after encountering that new "memfault" warning.
    But now with: sdk-zephyr, nrf (originally named sdk-nrf), nrfxlib, hal_nordic, memfault-firmware-sdk, I'm somehow back to my original warning:
    which came from my updated command:
    cmake -B build -DCMAKE_PREFIX_PATH=/wtf/sdk-zephyr -DCROSS_COMPILE=/usr/bin/arm-none-eabi- -DBOARD=nrf52840dongle_nrf52840 -DZEPHYR_MODULES="/wtf/nrf/;/wtf/nrfxlib/;/wtf/hal_nordic/;/wtf/memfault-firmware-sdk/" samples/hello_world/
    I also neglected to mention the actual Kconfig file in the non sdk-nrf path: sdk-nrf/subsys/bootloader/bl_crypto/Kconfig:129 'source "${ZEPHYR_BASE}/../nrf/subsys/fw_info/Kconfig.template.fw_info_ext_api"'. That was only one of them.
    I'm going to assume that if "west" works, it must be doing something to account for the cloned names where the "sdk-" prefix is removed.
    EDIT0:
    I forgot to add something new I saw, but not sure if it was also there in previous build attempts:
    -- Found BOARD.dts: /wtf/sdk-zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840.dts
    nrf52840dongle_nrf52840.dts.pre.tmp:15.39-20.5: Warning (interrupt_provider): /soc/interrupt-controller@e000e100: Missing #address-cells in interrupt provider
    also defined at nrf52840dongle_nrf52840.dts.pre.tmp:370.7-372.3
    We only support using west to fix these dependencies.
    Is there a reason why you cannot use west to initialize and clone the depending repositories?
    Håkon
  • I actually went ahead and installed it several hours ago (just to see how it's doing it) and am still trying to get the sample to build.
    Previously it was failing and the cmake error log was showing it was because of "_exit" which I've encountered before and had to set "--specs=nosys.specs".
    But the problem here is that adding that "set" to the flags in "cmake/toolchain/gnuarmemb/generic.cmake" made no difference to it actually being added in "CMakeCache.txt".
    When I edited that cache file manually setting those flags and running "configure" for it, it STILL failed, telling me to look at the "CMakeError.log"... except there was no longer that file.
    This is really torquing me off good. I'm going to download the "nr" toolchain, but this just simply is no good that nothing is working (not referring just to the build process). At least I'm getting more intimate with zephyr as I go through all of this.
    $ ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb GNUARMEMB_TOOLCHAIN_PATH=/usr/ west --verbose build -b nrf52840dongle_nrf52840 --target=usage --pristine=always zephyr/samples/hello_world
    EDIT0: So, I went ahead and installed "zephyr-toolchain-arm-0.13.1-linux-x86_64-setup.run" and replaced the toolchain variables in the above command with "ZEPHYR_TOOLCHAIN_VARIANT=zephyr" and "ZEPHYR_SDK_INSTALL_DIR=<pathToToolchain>", and the command finally worked.
    Again, I feel this is a problem where the zephyr docs state you can use 3rd party toolchains, but that fails to be true.
    I'm pretty much at the same point. I want to use the newest GCC and thus, did not installed the large package of compilers from whom I will use only one, but tried to setup a Zephyr project using a preinstall GCC (arm-none-eabi-gcc). Have you figured out, what the problem was?
