Mesh Light Switch Sample
Hello all,
I am trying to compile the Light Switch sample here https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/bluetooth/mesh/light_switch/README.html
I imported it through the nRF Connect SDK Project and tried building it and I get the following error:
Building ‘C:/v1.7.0/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
Building ‘C:/v1.7.0/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/misc/generated/syscalls.json’
Building ‘zephyr/misc/generated/struct_tags.json’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/driver-validation.h’
Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/kobj-types-enum.h’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/otype-to-size.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘zephyr/include/generated/syscall_list.h’
Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘offsets.c’
    arch.h
    cpu.h
    kernel_includes.h
    kernel.h
    offsets_aarch32.c
    offsets.c
    In function 'arch_irq_lock':
    'DT_N_S_soc_S_interrupt_controller_e000e100_P' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_interrupt_controller_e000e100_ORD'?
    in definition of macro 'DT_CAT'
    in expansion of macro 'DT_PROP'
    in expansion of macro 'DT_N_INST_0_arm_v8m_nvic'
    in expansion of macro 'UTIL_PRIMITIVE_CAT'
    in expansion of macro 'UTIL_CAT'
    in expansion of macro 'DT_INST'
    in expansion of macro 'NVIC_NODEID'
    in expansion of macro 'NUM_IRQ_PRIO_BITS'
    in expansion of macro 'Z_EXC_PRIO'
    in expansion of macro '_EXC_IRQ_DEFAULT_PRIO'
    each undeclared identifier is reported only once for each function it appears in
    arm_mpu_v8m.h
    arm_mpu.h
    arch.h
    cpu.h
    kernel_includes.h
    kernel.h
    offsets_aarch32.c
    offsets.c
    At top level:
    #error "NUM_IRQ_PRIO_BITS and __NVIC_PRIO_BITS are not set to the same value"
Build failed
I am using Windows 10, SEGGER Embedded Studios v5.60, nRF Connect SDK 1.7 and have bluetooth mesh enabled in prj.conf. Also using the nRF 5340 DK and targeting the application core.
Are there any other configurations I'm missing? Or other solutions to get the sample to compile?
Thanks
