问题描述:在使用NCS 在52840上面开发中,在调试功耗一直为540ua,目前我们不能使用深度睡眠,配置文件为
CONFIG_PM=y
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_IDLE=y
有需要注意的什么配置吗,或者关于idle降低功耗的例程吗,我目前在DK板上面调试
当我运行以下例程的时候,功耗依然为5百多ua
zephyr\samples\subsys\power\device_pm
What else are you doing in your application?
Are you perhaps using a peripheral like PPI or UART that's constantly on in the background even though the CPU is in SYSTEM_ON sleep?
If so, such a peripheral could be keeping your HFCLK active, causing an increased power consumption in the SYSTEM_ON sleep. If this is the case, you will have to weight the benefit of uniniting and re-initing the peripheral every time you'd like to use it against the decreased power consumption during sleep.
Could you show a more complete version of your prj.conf?
Karl
