9160 anamoly SICA rev 1
Question about errata workarounds for 9160 rev 1 (BO) SICA.
I see these in the errata which are relevant for our project:
[15] REGULATORS: Supply regulators default to LDO mode after reset
https://infocenter.nordicsemi.com/index.jsp?topic=%2Ferrata_nRF9160_Rev1%2FERR%2FnRF9160%2FRev1%2Flatest%2Fanomaly_160_15.html&cp=2_0_1_1_1_6
[31] LFXO: LFXO startup fails
https://infocenter.nordicsemi.com/index.jsp?topic=%2Ferrata_nRF9160_Rev1%2FERR%2FnRF9160%2FRev1%2Flatest%2Fanomaly_160_31.html&cp=2_0_1_1_1_15
I check under fixed issues:
14 REGULATORS Supply regulators default to LDO mode after reset
So 14 ==> 15 seems fixed in the B0 rev 1 SICA revision if I read this correct.
The [31] anamoly is still an issue to be code corrected at boot up.
I did in main() put the code for it:
*((volatile uint32_t *)0x5000470Cul) = 0x0;
*((volatile uint32_t *)0x50004710ul) = 0x1;
What happens then, is when running these instructions, the chip resets and reboots.
So it becomes a reset cycle.
Advice?
