nRF9160 Sleep and Idle power consumption
Can you please tell us what is the power consumption in Idle State with DRX = 1.28s and Sleep State with DRX = 1.28s? And an estimate with eDRX at 5.12 s?
We are asking because in our solution the user can control the device and we need small delays. This means we cannot have the device sleep without checking for received messages for too many seconds. We will maybe use eDRX with 5.12 s but unlikely to use higher sleep values.
What is the power consumption in this case?
Thanks
    Have you tried our power calculator?
    https://devzone.nordicsemi.com/nordic/power
    In your case, if you disable PSM, then enter those intervals as drx interval, you should get an approximation.
    We also have some scenarios mentioned in our specification:
    https://infocenter.nordicsemi.com/topic/ps_nrf9160/_tmp/alta.nRF9160/autodita/CURRENT/parameters.id_current_modem.html?cp=2_0_0_4_1_0_14
    Every calculator is an approximation, and is highly likely to vary from actual use-cases. To get the actual current consumption for your scenario, the best scenario is to measure this when you're connected to your local network.
    Håkon
    Thanks for the link for the power calculator, it's really useful!
    It seems most IoT applications allow larger sleep times and our usecase in which the user controlls the device and expects up to 2-3 seconds of delay is not the standard. I would appreciate if you confirm that my understanding is correct:
    - We can set the 1.28 or 2.56 iDRX interval. This is basically using standard DRX sleep mechanism.
    - eDRX is an extended DRX and we can set it to 5.12 and this would allow a longer idle time and less checks for received messages. This is as long as the network also allows the 5.12s eDRX interval.
    Is my understanding corect?
    And again, just to be 100% sure, the nRF9160 modem supports the above settings, right?
    If so, i will order a development kit and see how it goes from there!
    Thanks
    Yes, you're right. You can disable both eDRX and PSM, in which you're in a higher level of sleep (connected DRX), with lower latency and higher current consumption.
    Yes, we support eDRX. 5.12 s is the lowest you can set/get with this power mode, provided that the network gives you this timing:
    https://infocenter.nordicsemi.com/topic/ref_at_commands/REF/at_commands/nw_service/cedrxrdp_set.html?cp=2_1_7_4_0
    Håkon
