USB CDC doesn't appear as COM in Release. It's visible only in Debug mode.
I wanted to merge two example projects: "ble_central/ble_app_uart_c" so I have central client application, and a "peripheral/ble_usbd_ble_uart" so I have working USB CDC. I need such a combination so I could port it to Dongle with PCA10059 that's gonna be Receiver in my communications system (but first I'm gonna test it on DK that has debugger).
The problem is: when I "Build and Run", USB doesn't appear as a COM in my Windows. Restart button doesn't help. It appears only when I "Build and Debug" and let the program work without step-by-step debugging procedure - "Continue Execution" button in debug perspective of SES. The "peripheral/ble_usbd_ble_uart" example works pretty fine.
I'm under impression it might be some power management problem, but I'm too rookie to figure out. I compared the "sdk_config.h" and "main.c" files and I'm under impression it might work, but it doesn't, so I'm wrong somehow. Maybe that's the lack of some .h or .c files.
In Debug mode, the application catches Hard Fault, I think, because whenever I Pause the Continues Execution, it's stuck there:
And the RealTerm freezes once I open VCOM for USB CDC.
In normal Run, it doesn't catch it, I think, becasue I uncommented one of printf() that send received data via regular J-Link UART, and it works pretty fine, but USB VCOM is not visible.
  • Ok, yes I am able to reproduce that. Doesn't seem to have anything to do with debug vs release. Moving app_usbd_power_events_enable() to be after all the init functions, like it is in usbd_ble_uart, makes the COM port show up in release, but doesn't fix the underlying issue of nrf_sdh_enable_request() failing due to an invalid state.
    There is a lot going on here, almost like you are trying to merge the examples in one go. That's bound to cause headaches. I would start over with one of the examples, slowly integrate functions from the other example, and identify and fix issues along the way. Then you can easily point to a single, smaller change which causes issues.
  • Well, I solved the issue myself. There was a problem with such many things. I brainstormed myself for half a day and solved the issue. Thanks for yoiur good wish anyway!
