watchdog timer
Hello Zephyr experts,
I am having problem with the function wdt_disable(const struct device *dev);
There is no problem in setup and feed the watchdog.
wdt = device_get_binding(WDT);     // watchdog device binding succesfully
wdt_channel_id = wdt_install_timeout(wdt, &wdt_config);    // installed watchdog timer successfully
wdt_setup(wdt, WDT_OPT_PAUSE_HALTED_BY_DBG);     // set up and start the watchdog. successfully
for(;;)
     /* Able to feed the dog with no timeout and reset */
     wdt_feed(wdt, wdt_channel_id);   // feed the dog periodically
     sleep_second(5);                          // sleep 5 seconds
    /* if user wants to disable the watchdog, wdt_disable() return an error = -1 */
    if ( user_command == "disable watchdog") {
         rc = wdt_disable(wdt);      // disable watchdog, but it failed with error code -1.     <--------  What went wrong ??????
This is what I found from
zephyr/misc/generated/syscalls_links/include/drivers/watchdog.h
 * @brief Disable watchdog instance.
 * This function disables the watchdog instance and automatically uninstalls all
 * timeouts. To set up a new watchdog, install timeouts and call wdt_setup()
 * again. Not all watchdogs can be restarted after they are disabled.
 * @param dev Pointer to the device structure for the driver instance.
 * @retval 0 If successful.
 * @retval -EFAULT If watchdog instance is not enabled.
 * @retval -EPERM If watchdog can not be disabled directly by application code.
__syscall int wdt_disable(const struct device *dev);
static inline int z_impl_wdt_disable(const struct device *dev)
        const struct wdt_driver_api *api =
                (const struct wdt_driver_api *)dev->api;
        return api->disable(dev);
