use ppi and set usb sof as rtc1 source
To the kind attention of Nordic support team,
I have got a freertos project and usb is enabled (usb enumeration is done and usb interrupts are correctly working before even starting the scheduler).
In FreeRTOSConfig.h other than having:
#define FREERTOS_USE_RTC 0 and #define FREERTOS_USE_SYSTICK 1
I'd like to add a third custom option:
#define FREERTOS_USE_USB_SOF 2
and change vPortSetupTimerInterrupt initialization (in case FREERTOS_USE_USB_SOF is set), so that usb sof event is triggering rtc1 overflow interrupt
(RTC1_IRQHandler == xPortSysTickHandler).
I was trying to modify like this, but something is missing it seems doesn't work. Could you please give me a hand if is not too much trouble, at least in how should theoretically be? (I'll update
if I have any news):
void vPortSetupTimerInterrupt( void )
nrf_drv_clock_lfclk_request(NULL); // assume that usb sof is triggering 0x00FFFFF0, then lfck is needed to do the actual overflow?
nrf_rtc_prescaler_set(portNRF_RTC_REG, portNRF_RTC_PRESCALER);
nrf_rtc_int_enable (portNRF_RTC_REG, RTC_INTENSET_OVRFLW_Msk); // enable overflow interrupt
nrf_rtc_task_trigger (portNRF_RTC_REG, NRF_RTC_TASK_CLEAR); //
// ppi re routing events_sof ---> tasks_trigovrflw
NRF_PPI->CH[0].EEP = (uint32_t)&NRF_USBD->EVENTS_SOF;
NRF_PPI->CH[0].TEP = (uint32_t)&NRF_RTC1->TASKS_TRIGOVRFLW;
NRF_PPI->CHENSET = (1 << 0);
NRF_RTC1->EVTEN = 2;
NRF_RTC1->TASKS_START = 1; // to enable counting
NVIC_SetPriority(portNRF_RTC_IRQn, configKERNEL_INTERRUPT_PRIORITY);
NVIC_EnableIRQ(portNRF_RTC_IRQn);
working code
nrf_rtc_int_enable (portNRF_RTC_REG, RTC_INTENSET_TICK_Msk);
nrf_rtc_task_trigger (portNRF_RTC_REG, NRF_RTC_TASK_START);
nrf_rtc_event_enable(portNRF_RTC_REG, RTC_EVTEN_OVRFLW_Msk);
NVIC_EnableIRQ(portNRF_RTC_IRQn);*/
  • Maybe the theoretical problem here is that overflow is writing 0x00FFFFF0, not actually forcing an immediate overflow interrupt in rtc1. so if rtc1 frequency is not higher than usb one, this doesn't work. I'd rather use a mechanism that is forcing an immediate rtc1 interrupt if possible. How would be a cool way using PPI to have a timer and usb in sync in your opinion? Thank you
  • Not sure if I understand what you want to achieve here, but why not just use the timer in counter mode, and connect SOF event to the COUNTER task of the timer?
    Kenneth
  • Hi Kenneth, yes you got my meaning, thank you. Latest question, what you are suggesting wouldn't be possible for rtc1, thought, would it? I mean it seems not to have a counter mode, or am I wrong. Should be the case we should use another hardware timer, that is ok for us, as we don't have power issue, in this particular project. Thank you
  • Sounds good. You are right, you will need to use a timer yes.
    Kenneth
