Hi there,
I'm using the product specification of the nRF52840 to program the SAADC in continuous mode using its internal timer. I'm not able to use your SDK. Unfortunately, I'm having difficulty in getting a repeated sampling to occur. I can get one-shot sampling working very well.
I'm doing everything per https://infocenter.nordicsemi.com/topic/ps_nrf52840/saadc.html?cp=4_0_0_5_22_3#saadc_easydma and Figure 4, sans firing the SAMPLE task. My expectation is that the SAMPLE task is fired by the internal timer of the SAADC. I see the STARTED event but then nothing else. I then read https://devzone.nordicsemi.com/f/nordic-q-a/73186/nrf52840-saadc-continuous-sampling-not-started-with-task_start and saw that a SAMPLE task should be issued after the first START task to kick things off (there being an omission in the product specification). When I do issue an initial SAMPLE task, I see the STARTED event and then an END event with samples... At this point, I issue another START task (as per Figure 4), but I don't see any more END events.
Here's the logging of events with the initial SAMPLE task included:
0 INFO Started
1 INFO Done
2 INFO Result done
3 INFO Done
4 INFO Result done
5 INFO Ended
6 INFO sample len=500
7 INFO Started
I'm logging Stopped events also, but not seeing them (which is good).
My sample rate is specified as 1600 and I also set TIMER mode. I'm using double-buffering, each buffer sized for 500 samples, and swap buffers on processing the Started event. There is just one channel configured.
Thanks for any help or guidance.
Christopher
