ANT on PCA10056 and custom board ?
Dear Members,
I want to run ANT+ code in my custom board,
It works well on PCA10056, I can upload softdevice and the code to custom board board,
but I didn't get any responses,
I have tried with code without softdevice, the custom board works well
Any ideas ?
Thanks
  • without APP_ERROR_CHECK :
    nfo> app_timer: RTC: initialized.
    fo> app: Rixtronix LAB. SP_BUTTON_ACTION_PUSH
    fo> app: utils_setup
    fo> app: softdevice_setup main
    and stopped
  • stopped at this function :
    ret_code_t err_code = nrf_sdh_enable_request();
    How can I check my 32KHz crystal running ?
  • No matter I used 0, 1 or 2
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 1
    it's still stopped on
    Which APP_ERROR_CHECK? The one after nrf_sdh_enable_request()? Also, os nrf_sdh_enable_request() called from ble_stack_init() as well, or only from softdevice_setup()?
    If you have selected the crystal, then it will be running once the nrf_sdh_enable_request() function has returned  with NRF_SUCCESS.
  • Hi Vidar, thanks for the reply
    Yes, The one after nrf_sdh_enable_request(),
    The running softdevice_setup is
    /**@brief Function for ANT stack initialization.
     * @details Initializes the SoftDevice and the ANT event interrupt.
    static void softdevice_setup(void)
          NRF_LOG_INFO("softdevice_setup main\r\n");
        ASSERT(nrf_sdh_is_enabled());
        err_code = nrf_sdh_ant_enable();
          NRF_LOG_INFO("softdevice_setup sdh_enable\r\n");
        err_code = ant_plus_key_set(ANTPLUS_NETWORK_NUM);
          NRF_LOG_INFO("ant_plus_key\r\n");
    Debug out :
    fo> app: log_init.
    fo> nrf_sdh: nrf_sdh_enable_request
    fo> nrf_sdh: CRITICAL_REGION_ENTER
    Stop until this line :
     CRITICAL_REGION_ENTER();
             NRF_LOG_INFO("CRITICAL_REGION_ENTER\r\n");
    at Line 211
    E:\nRF5_SDK_17.0.2_d674dde\components\softdevice\common\nrf_sdh.c
    is it possible that my XL1 and XL2 pad on 32KHz not soldered properly, causing this error ?
    How can I use RC oscillator for running softdevice in debug mode ?
    it ended up in this line :
    /** @addtogroup NRF_SDM_FUNCTIONS Functions
    /**@brief Enables the SoftDevice and by extension the protocol stack.
     * @note Some care must be taken if a low frequency clock source is already running when calling this function:
     *       If the LF clock has a different source then the one currently running, it will be stopped. Then, the new
     *       clock source will be started.
     * @note This function has no effect when returning with an error.
     * @post If return code is ::NRF_SUCCESS
     *       - SoC library and protocol stack APIs are made available.
     *       - A portion of RAM will be unavailable (see relevant SDS documentation).
     *       - Some peripherals will be unavailable or available only through the SoC API (see relevant SDS documentation).
     *       - Interrupts will not arrive from protected peripherals or interrupts.
     *       - nrf_nvic_ functions must be used instead of CMSIS NVIC_ functions for reliable usage of the SoftDevice.
     *       - Interrupt latency may be affected by the SoftDevice  (see relevant SDS documentation).
     *       - Chosen low frequency clock source will be running.
     * @param p_clock_lf_cfg Low frequency clock source and accuracy.
                             If NULL the clock will be configured as an RC source with rc_ctiv = 16 and .rc_temp_ctiv = 2
                             In the case of XTAL source, the PPM accuracy of the chosen clock source must be greater than or equal to the actual characteristics of your XTAL clock.
     * @param fault_handler Callback to be invoked in case of fault, cannot be NULL.
     * @param p_license_key License key for ANT based softdevices. NULL can be used for BLE only softdevices. See ANT_LICENSE_KEY define for more detail.
     * @retval ::NRF_SUCCESS
     * @retval ::NRF_ERROR_INVALID_ADDR  Invalid or NULL pointer supplied.
     * @retval ::NRF_ERROR_INVALID_STATE SoftDevice is already enabled, and the clock source and fault handler cannot be updated.
     * @retval ::NRF_ERROR_SDM_INCORRECT_INTERRUPT_CONFIGURATION SoftDevice interrupt is already enabled, or an enabled interrupt has an illegal priority level.
     * @retval ::NRF_ERROR_SDM_LFCLK_SOURCE_UNKNOWN Unknown low frequency clock source selected.
     * @retval ::NRF_ERROR_INVALID_LICENSE_KEY Incorrect ANT license key. See ANT_LICENSE_KEY define for more detail.
     * @retval ::NRF_ERROR_INVALID_PARAM Invalid clock source configuration supplied in p_clock_lf_cfg.
    SVCALL(SD_SOFTDEVICE_ENABLE, uint32_t, sd_softdevice_enable(nrf_clock_lf_cfg_t const * p_clock_lf_cfg, nrf_fault_handler_t fault_handler, const char* p_license_key));
    E:\nRF5_SDK_17.0.2_d674dde\components\softdevice\SoftDevice\headers\include\nrf_sdm.h Line 337
    How can I debug it (in which line) I put breakpoint ?
    Await for your reply, thanks.
