ANT on PCA10056 and custom board ?
Dear Members,
I want to run ANT+ code in my custom board,
It works well on PCA10056, I can upload softdevice and the code to custom board board,
but I didn't get any responses,
I have tried with code without softdevice, the custom board works well
Any ideas ?
Thanks
  • Debug and breakpoint screen shot :
    Any clues ?
    LFCLK Not Running
  • The program will not return from nrf_sdh_enable_request() unless the crystal oscillator has started, and you said earlier it did return. So it should not be an issue with the crystal not starting up. However, if you still suspect the 32KHz crystal to be the culprit, then you try to select the NRF_CLOCK_LF_SRC_SYNTH  source.
    Can you print out the return value from nrf_sdh_enable_request()?
  • Can you print out the return value from nrf_sdh_enable_request()?
    No I can not get the printout :
      ret_code_t err_code = nrf_sdh_enable_request();
    it stopped at
      CRITICAL_REGION_ENTER();
             NRF_LOG_INFO("CRITICAL_REGION_ENTER\r\n");
    Have you seen my screen shot ?
    LFCLKSTAT = 0
    I have tried
     NRF_CLOCK_LF_SRC_SYNTH  source,
    it's not responding as well...
    What could have been wrong ?
    Thanks
    it stopped at
    LFCLKSTAT = 0
    I have tried
    Thanks
  • The log :
    nfo> app: log_init.
    nfo> app_timer: RTC: initialized.
    fo> app: Rixtronix LAB. SP_BUTTON_ACTION_PUSH
    fo> app: utils_setup
    fo> app: softdevice_setup main
    fo> nrf_sdh: nrf_sdh_enable_request
    fo> nrf_sdh: CRITICAL_REGION_ENTER
