SPI & Bluetooth best practices
Hi All,
I'm a little rusty on my embedded C and was wondering if I could get a few broad pointers on the best way to organize this research system I'm putting together.
The system is basic: I have an NRF52840 that talks to a custom IC via SPI and then sends whatever it reads out to an NRF52 dongle via bluetooth. If this was one way then it would be especially straight forward but unfortunately, the NRF52840 can also receive commands from the dongle (over bluetooth) that may or may not trigger specific SPI transactions. It seems to me that the best way to organize the NRF52840 (that's talking to the custom IC) as the peripheral and the dongle as the central device. This way the peripheral can use an interrupt to query the IC and then notify the central device with a new packet.
I'm having a little more trouble with the other main function though (dongle sending commands to the peripheral) though since it's really important that this bluetooth connection runs as fast as possible without dropping any packets.
Is it fair to have a main while loop on all my devices that spins (just checking if there's been an incoming command) when they're in their main interrupt-driven operating mode. Then if there has been a command, they break out of their interrupt-driven mode and work on whatever the command is? I worry that this constant spinning may burn unnecessary power and also may slow down the main BLE operation (which needs to run as fast as possible!). Are there other alternatives that may allow the bluetooth and spi to operate as fast as possible in parallel?
Thanks so much for any advice/help. If anything was unclear please let me know and I can clarify. I tried to distill everything to not be too confusing but I may have distilled too much.
- Ryan
  • Hello Ryan,
    Thank you for your patience with this.
    Fortunately, it does not have to be complicated just because it is two way! :)
    The BLE protocol is lossless, so you can be certain that no packets will be lost in the link. The only way packets may be lost is if they are not handled correctly when queued to be transferred by the SoftDevice on one side (such as if the queue command returns an error, and the program proceeds as though nothing had happened - dropping the packet that failed to be queued), or if the packet is discarded after reception on the central side.
    You will also not have to worry about bogging down the speed of your BLE transfers with your application, since the SoftDevice takes priority over any application-layer task. This way, the SoftDevice will always be guaranteed to meet its BLE timing-critical deadlines, since it knows that it can control the CPU whenever it needs to.
    So you may configure your connection parameters to whatever you would like, and the SoftDevice will make sure it is met - it is rather the application that must adjust to the possibility that the SoftDevice will take control of the CPU at any time in the program.
    Are you here referring to an incoming BLE event, or SPI transaction containing some command? I assume the former, and in this case you will not need to have a spinning while loop that checks for received commands, since the SoftDevice will take control of the CPU (even wake it if in SYSTEM_ON sleep) to meet the connection event and receive the command.
    This also happens as part of the ble_evt_handler or specific service event handler you've implemented. When the SoftDevice has completed a connection event it will forward the data received (like a write to a command characteristic) to the the appropriate event handler in the application layer. Provided that the particular event handler has a high enough priority it can then be executed right away.
    You can see how this in done in most of the BLE peripheral examples. To be specific, you could take a look at the BLE UART peripheral example where the NUS events are forwarded to the nus event handler and processed immediately upon the application resuming control over the CPU.
    As mentioned the BLE operation will happen at the configured rate regardless of what the application is doing. The CPU might very well be in the low power SYSTEM_ON sleep state for most of the time, ready to receive BLE commands in the next connection event. All of our BLE peripheral examples demonstrate this - the idle_state_handler which is running in the main while loop places the CPU in SYSTEM_ON sleep whenever there is nothing else that needs doing. The CPU will then be ready to quickly wake up as soon as there is an event generated.
    Yes, this is a good question - how to proceed in order to operate the SPI when the CPU might be claimed by the SoftDevice at any time.
    The answer to this is to make use of the nRF52840's easyDMA feature through using the SPIM peripheral (rather than the SPI), since this utilizes easyDMA.
    easyDMA lets a peripheral access RAM without needing CPU intervention. You could therefore both receive or send (if queued in advanced) data while the CPU is busy with the SoftDevice. To achieve this totally without CPU intervention you would need to also make use of the PPI peripheral, which lets you connect an event to a task trigger - i.e that when a specific event occurs, you would have it trigger a task (such as TASKS_START) without needing to involve the CPU.
    You could see the PPI peripheral demonstrated in the SAADC peripheral example where it is used to connect a TIMER CC event to the SAADC's TASKS_SAMPLE - enabling the SAADC to sample periodically without concern that the CPU might not be available at the particular time the sampling should happen.
    Please do not hesitate to ask if any part of this should be unclear, or if you encounter any other issues or questions!
    Karl
  • Hi Karl,
    This was incredibly helpful! I'll play with the SPIM peripheral/drivers and take a look at the SAADC example!
    I have one more question regarding best practices - this time with my 'main mode of operation'. Eventually, I will have a timer triggering a SPI transaction every 500us. The resulting data from this SPI transaction will then be beamed via bluetooth.
    To make things simpler for now, I am leaving the SPI out and just using my 500us timer to increment a counter. I then have an if statement in my main while loop that sends the updated counter to another device over bluetooth. Is this the best way to organize fast transactions through bluetooth? I must be doing something wrong because I'm losing a lot of data (I suspect the bluetooth transactions are taking too long - or the cpu is getting halted for too long so the counter increments more than once between bluetooth transfers. I tried putting the ble_nus_data_send() command in my timer's interrupt handler but that just caused nrf52840 to hang and become unresponsive.
    I'm currently building off of the ble_app_uart examples.
    Thanks again for all of your help!
    Ryan
    No problem at all, Ryan - I am happy to hear that you found my comment helpful!
    In general, the best way to do this is to handle it as part of an event handler, rather than having it happen in the main loop. This way you can easily control its priority, and compartmentalize the code better (not have everything running in the main loop).
    Additionally, for power saving, you should only have the SYSTEM_ON sleep (idle_state_handler function in the BLE Peripheral examples) happen in the main loop, since this will make your system go to SYSTEM_ON sleep whenever there are no other work to be done.
    I would therefore recommend that you either have the transfers happens as the handler to a TIMER CC event, or similar.
    Could you possibly show some code of how you are doing this? Are you getting any error codes returned from your call to queue the data for sending? You could see the likely returned error codes in the sd_ble_gatts_hvx API reference documentation.
    Since data is never lost in the link it is likely that you are dropping the data in the case that it fails to queue - for example if the HVN queue is already full. This could happen if you are queueing notifications faster than you are sending them, or if your hvn queue is not big enough to accommodate all the notifications generated between each connection event.
    What connection parameters are you using for your application, and how big is your BLE_GATTS_HVN_TX_QUEUE_SIZE_DEFAULT?
    Karl
  • Karl!
    Hi Karl,
    I've been able to get something to work but it still can't run at max speed. Per your suggestion, I've set up the Bluetooth transfer inside the timer's interrupt handler. I fixed one problem - I had a 'while (ble_ready == success)' gating the ble_nus_data_send - removing that helped things a little. I figure this is okay because I'm under the assumption the timer will always leave enough time for the ble_nus_data_send to do its thing. My timer's interrupt handler is below:
    static void trx_timer_handler(void * p_context)
      // fire off a SPI transaction
      // For now, just send an incrementing counter over BLE
      if (test_counter == 15) {
        test_counter = 0;
      } else {
        test_counter = test_counter + 1;
      //app_fifo_put(&EE_rx_fifo, test_counter);
      if ((ble_ready == NRF_SUCCESS)) { // & (app_fifo_get(&EE_rx_fifo, EE_transfer_buffer) == NRF_SUCCESS)){
        // uint16_t size2 = sprintf(m_tx_buffer, "%d \r\n", *EE_transfer_buffer);
        uint16_t size2 = sprintf(m_tx_buffer, "%d \r\n", test_counter);
        ble_ready = ble_nus_data_send(&m_nus, (uint8_t *) m_tx_buffer, &size2, m_conn_handle);
    This works if I slow the timer down - if it triggers once every 3ms I don't drop any packets. Unfortunately, when I speed the timer up to trigger every 500us (which is my target), I start "dropping" packets. I suspect this is because I'm effectively trying to queue notifications faster than I can send them.
    I'm using most of the default connection parameters from the ble_app_uart example! The only ones I changed were the min and max_conn_interval:
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    Are there any other connection parameters you think I should update to speed up the bluetooth speed? I can't find any BLE_GATTS_HVN_TX_QUEUE_SIZE_DEFAULT in the project or ble_gatt.h. Is this something I need to implement? Is there an example that implements this? I'm currently using NRF5 sdk 17 with the nrf52840 DK.
    As always, Karl, thank you so much for your help.
  • Hello again,
    It is no problem at all, Ryan, I am happy to help!
    The ble_nus_data_send function does not actually send the data directly, but it queues the notification for sending (placing it in the hvn queue). The queue is FIFO, and the notification will be sent as soon as there is room for it in an upcoming connection event.
    - This is why it is important that your queue size is at minimum large enough to hold all notifications you intend to generate over the span of your connection interval. I say at minimum because you also need to account for possible retransmission due to corrupted packets or otherwise lost packets (data is never lost in the link since the un-acknowledged packet will be retransmitted).
    The ble_nus_data_send call could also happen as part of the SPI event handler, so that you do not have to wait in the timer interrupt for the SPI transaction to complete before you can queue the data for transfer, for instance.
    This is indeed how you change the connection interval preferences of the peripheral - but keep in mind that it is always the central that actually determines what connection parameters will be used. The peripheral may only send connection parameter update requests in order to ask the central to change to parameters within its preferences, but the central is free to reject these requests.
    If the central rejects the peripheral can either accept the parameters used by the central, or terminate the link. Many applications such as nRF Connect for smartphone etc. will accommodate any preferences, but some native applications might not in order to save power on the central device. Certain phone OS's especially limit this, in order to avoid excess power consumption.
    Does it not exist in your sdk_config.h file? The sdk_config is used to set all these types of defines and configurations for your project in the nRF5 SDK.
    You could take a look at the SoftDevice's throughput documentation for this - it details the parameters used to achieve the highest connection throughput. Have you calculated what throughput you will need for your application? Is there a constraint on the latency of the transfers?
    Karl
