I'm using TWI to control accemeter(MMA452).When I used TWI SENSOR to read my sensor, it didn't work normally.
* Copyright (c) 2015 - 2017, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup tw_sensor_example main.c
* @ingroup nrf_twi_example
* @brief TWI Sensor Example main file.
* This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
/* Common addresses definition for temperature sensor. */
#define LM75B_ADDR (0x90U >> 1)
#define LM75B_REG_TEMP 0x00U
#define LM75B_REG_CONF 0x01U
#define LM75B_REG_THYST 0x02U
#define LM75B_REG_TOS 0x03U
/* Mode for LM75B. */
#define NORMAL_MODE 0U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
uint8_t rx_buff=0xEE;
* @brief Function for setting active mode on MMA7660 accelerometer.
void LM75B_set_mode(void)
ret_code_t err_code;
// /* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
// uint8_t reg[2] = {LM75B_REG_CONF, NORMAL_MODE};
// err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, sizeof(reg), false);
// APP_ERROR_CHECK(err_code);
// while (m_xfer_done == false);
// /* Writing to pointer byte. */
// reg[0] = LM75B_REG_TEMP;
// m_xfer_done = false;
// err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, 1, false);
uint8_t reg = 0x0D;
err_code = nrf_drv_twi_tx(&m_twi, 0x38, ®, 1, false);
err_code = nrf_drv_twi_rx(&m_twi, 0x39, &rx_buff, 1);
* @brief Function for handling data from temperature sensor.
* @param[in] temp Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp)
NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
* @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
switch (p_event->type)
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
data_handler(m_sample);
m_xfer_done = true;
* @brief UART initialization.
void twi_init (void)
const nrf_drv_twi_config_t twi_lm75b_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_twi);
* @brief Function for reading data from temperature sensor.
static void read_sensor_data()
/* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
ret_code_t err_code = nrf_drv_twi_rx(&m_twi, LM75B_ADDR, &m_sample, sizeof(m_sample));
NRF_LOG_INFO("\r\nTWI sensor example");
NRF_LOG_FLUSH();
twi_init();
LM75B_set_mode();
while (true)
nrf_delay_ms(500);
do
__WFE();
}while (m_xfer_done == false);
read_sensor_data();
NRF_LOG_FLUSH();
The address of MMA8452 is 0x1C,so i want to read the value of 0x0D register.When I use nrf_drv_twi_tx(), m_xfer_done is always false.
I have used nrf_drv_twi_tx(&m_twi, 0x38, ®, 1, false) or nrf_drv_twi_tx(&m_twi, 0x1C, ®, 1, false), it seems the same.
