bug: lte_link_control: Cell-ID check leads to false UNKNOWN event (#5353)
Hello Slight smile
I found a possible bug in NCS 1.7.0 which was introduced in PR #5353.
1) False UNKNOWN event when disconnecting
The "invalid cell id" check leads to an false UNKNOWN event when you disconnect the modem.
The disconnect itself will emit a cell id update with an "invalid" (read: valid in the case of disconnection) cell id.
Since there is no further DISCONNECT event this leads the application to an error state instead of a graceful disconnect.
2) Modem Event Manipulation
Furthermore I didn't expect the library to actually change the registration status from the modem.
This is also what the library documentation says ("maps directly").
Markus
  • Hi Markus,
    Sorry for the late reply, I have submitted an internal bug report to our R&D team, but the code owner is on vacation now, so there might be some delay.
    You can also comment on the original pull request, so you can get feedback once there is some action to it.
    Thanks for your feedback!
    Charlie
  • Hi Markus,
    Please check if this fix addressed the issue you metioned. The commit moves the guard to only be called if the incoming registration status is either roaming or home.
    https://github.com/simensrostad/fw-nrfconnect-nrf/commit/0ca961b1a0eddd9bba6da392e54f32416bdfda3f
    Charlie
  • Hi Charlie,
    yes this fixes the issue for now. Is there a release date for this fix yet?
    But.. since I don't know how the modem handles its states internally and can't find any documentation about that, I have an upcoming question. Let's assume the following:
    - The modem has status HOME/ROAMING with invalid Cell-ID
    - Thus the applications gets the status UNKNOWN
    - The application thinks the modem is offline/disconnected
    - But the modem is still online/connected (which HOME/ROAMING literally says)
    So the modem is online and the application doesn't know that and (probably) will never request the modem to disconnect. Is this assumption right?
    Otherwise you should document somewhere that there is another state (UNKNOWN) in which the modem could be online/connected.
    Markus
  • Hi Markus,
    Here are the comments from our expert:
    AFAIK loosing the cell ID does not directly translate to being unregistered from the LTE network. However, from an application standpoint, attempting to send data while when the modem has returned an invalid cell ID does not work. Its possible that the modem still accepts data being sent to its internal TCP/IP buffers and that the data will be when sent when the modem obtains a valid cell, at a later point. This is not known. It will at least be strong indications that the UE is in quite poor network conditions.
    To simplify, the link controller simply checks if the cell ID is invalid and propagates the UNKNOWN event upon such an occurrence, giving the application more concrete control over whether to send data or not.
    This was reported to be an issue in several cases including https://devzone.nordicsemi.com/f/nordic-q-a/77155/asset-tracker-v2-failed_data-buffer-not-filling/323632#323632 and https://devzone.nordicsemi.com/f/nordic-q-a/63267/getting-cereg-5-fffe-ffffffff-while-disconnected-from-the-network
    If the modem at a later point succeeds in obtaining the Cell ID it will notify the application with its current registration status.
    This is not entirely true. If the link controller has configured and inited the modem it should not be necessary to take explicit action in the case of a disconnect. This will happen automatically, the modem will simply notify the application when a valid cell ID / registration status has been obtained. Which in turn will be propagated via the corresponding event in the link controller callback handler.
    Charlie
  • Hello Slight smile
    Thanks for this update, I understood.
    But, just to be sure, what exactly is the meaning of the event LTE_LC_NW_REG_UNKNOWN and when does this occur (except in case of an invalid cellid)?
    Or in other words, how exactly do we need to react to an UNKNOWN event in the application (e.g. treat as error)?
    Markus
