bug: lte_link_control: Cell-ID check leads to false UNKNOWN event (#5353)
Hello Slight smile
I found a possible bug in NCS 1.7.0 which was introduced in PR #5353.
1) False UNKNOWN event when disconnecting
The "invalid cell id" check leads to an false UNKNOWN event when you disconnect the modem.
The disconnect itself will emit a cell id update with an "invalid" (read: valid in the case of disconnection) cell id.
Since there is no further DISCONNECT event this leads the application to an error state instead of a graceful disconnect.
2) Modem Event Manipulation
Furthermore I didn't expect the library to actually change the registration status from the modem.
This is also what the library documentation says ("maps directly").
Markus
