How to transfer data through UART
I used nrf51822- EK board.
GATT - s110 6.2.1 softdevice
I transfer data through UART for nrf51822-EK(PCA10001).
But this time. I used nrf51822 smart beacon kit(PCA20006).
PCA20006 is received data through UART.
But PCA20006 is not transfer data through UART.
PCA20006 UART
rx ------------------------- tx (OK)
tx ------------------------- rx (XX)<-- this problem...
I guess NRF_UART0->EVENTS_TXDRDY not set 1.
So. How to solve this problem ?
  • How are you handling your simple_uart_put and simple_uart_get? is the UART on smart beacon connected to something? start your application in debugger and i would suspect that your are either stuck in one of these two functions.
  • /* Copyright (c) 2009 Nordic Semiconductor. All Rights Reserved. * * The information contained herein is property of Nordic Semiconductor ASA. * Terms and conditions of usage are described in detail in NORDIC * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT. * * Licensees are granted free, non-transferable use of the information. NO * WARRANTY of ANY KIND is provided. This heading must NOT be removed from * the file. * */
    #include <stdint.h>
    #include "nrf.h"
    #include "simple_uart.h"
    #include "nrf_delay.h"
    #include "nrf_gpio.h"
    uint8_t simple_uart_get(void)
      while (NRF_UART0->EVENTS_RXDRDY != 1)
        // Wait for RXD data to be received
      NRF_UART0->EVENTS_RXDRDY = 0;
      return (uint8_t)NRF_UART0->RXD;
    bool simple_uart_get_with_timeout(int32_t timeout_ms, uint8_t *rx_data)
      bool ret = true;
        if (timeout_ms-- >= 0)
          // wait in 1ms chunk before checking for status
          nrf_delay_us(1000);
          ret = false;
      }  // Wait for RXD data to be received
      if (timeout_ms >= 0)
        // clear the event and set rx_data with received byte
          *rx_data = (uint8_t)NRF_UART0->RXD;
      return ret;
    void simple_uart_put(uint8_t cr)
      NRF_UART0->TXD = (uint8_t)cr;
      while (NRF_UART0->EVENTS_TXDRDY!=1)
        // Wait for TXD data to be sent
      NRF_UART0->EVENTS_TXDRDY=0;
    void simple_uart_putstring(const uint8_t *str)
      uint_fast8_t i = 0;
      uint8_t ch = str[i++];
      while (ch != '\0')
        simple_uart_put(ch);
        ch = str[i++];
    void simple_uart_config(  uint8_t rts_pin_number,
                              uint8_t txd_pin_number,
                              uint8_t cts_pin_number,
                              uint8_t rxd_pin_number,
                              bool    hwfc)
    /** @snippet [Configure UART RX and TX pin] */
      nrf_gpio_cfg_output(txd_pin_number);
    	nrf_gpio_pin_set(txd_pin_number);
      nrf_gpio_cfg_input(rxd_pin_number, NRF_GPIO_PIN_NOPULL);
      NRF_UART0->PSELTXD = txd_pin_number;
      NRF_UART0->PSELRXD = rxd_pin_number;
      if (hwfc)
        nrf_gpio_cfg_output(rts_pin_number);
        nrf_gpio_cfg_input(cts_pin_number, NRF_GPIO_PIN_NOPULL);
        NRF_UART0->PSELCTS = cts_pin_number;
        NRF_UART0->PSELRTS = rts_pin_number;
        NRF_UART0->CONFIG  = (UART_CONFIG_HWFC_Enabled << UART_CONFIG_HWFC_Pos);
      NRF_UART0->BAUDRATE         = (UART_BAUDRATE_BAUDRATE_Baud9600 << UART_BAUDRATE_BAUDRATE_Pos);
      NRF_UART0->ENABLE           = (UART_ENABLE_ENABLE_Enabled << UART_ENABLE_ENABLE_Pos);
      NRF_UART0->TASKS_STARTTX    = 1;
      NRF_UART0->TASKS_STARTRX    = 1;
  • you did not mention if you have connected your beacon to PC or somthing? does does it get RX characters and where does uart put TX charaters? Also I do not understand what this below means
    PCA20006 UART
    you might as well try to disable flow control and see if that works
