always automatic wakeup after entering SYSTEM OFF mode
Hi everyone,
I wanna implement the wakeup from SYSTEM OFF by button. The project is based on the ble_app_uart example. After receiving a command from BLE, nrf will go to SYSTEM OFF , the code is here:
 case 29:  // SYSTEM OFF mode
                                  nrf_delay_ms(500);
                                  sprintf(bletext,"SYSTEM OFF......\r\n"); BLE_TEXT(bletext);
                                  nrf_delay_ms(500);
                                  err_code = bsp_wakeup_button_enable(BUTTON_5);
                                  nrf_delay_ms(500);
                                  /*err_code = sd_power_system_off();
                                  APP_ERROR_CHECK(err_code);*/
                                  NRF_POWER->SYSTEMOFF = 1;
Every time it goes to OFF mode, it will automatically restart booting after about 1-2 seconds
I used the sd_power_reset_reason_get() and it shows that it's reset from soft reset detected (SREQ)
I read several post about this topic and it looks like sd_power_system_off() doesn't work in debugging mode. I don't know how to check if I'm in debug mode or not, so I used both sd_power_system_off() and NRF_POWER->SYSTEMOFF = 1, same problem, no difference. And I tried both connect our pcb to the nRF52DK and pcb runs separately communicating with nRF52DK through BLE, same problem.
Can anyone help with this? Thanks in advance
  • Actually automatic restart after 4-5 seconds. I'm not sure if anything else (timers etc.)wakes it up, but the RESETREAS register always shows reset by soft reset. Did I set it to OFF mode correctly or is there anything else I need to set other than sd_power_system_off() or NRF_POWER->SYSTEMOFF = 1?  If it really entered the OFF mode, what can trigger a soft reset?
  • The system will stay in OFF mode if I comment out
    We use a custom PCB and there's no bsp_buttons on it, but we have a button connected to P0.24, and I added it in pca10040.h and sdk_config.h as following:
    // in pca10040.h
    #define BUTTONS_NUMBER 5   //4------>5
    #define BUTTON_5  NRF_GPIO_PIN_MAP(0,24)
    #define BUTTONS_LIST { BUTTON_1, BUTTON_2, BUTTON_3, BUTTON_4, BUTTON_5 }
    // in sdk_config.h
    #define GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS 5   //4--->5
    And in main bsp_event_handler, we do enter the case BSP_EVENT_KEY_4 when the button is pressed, so I guess it should work the same as those buttons on the DK. But after I set that button for wakeup as "bsp_wakeup_button_enable(BUTTON_5);", it will automatically wakeup without being pressed, what might be wrong?
  • Which pin does BUTTON_5 map to in your code? And how is this pin connected on your HW? When you configure that as an input and as a wakeup source, a change on the state of that pin can wake up the device. If that is controlled by something else and/or is floating, you will not have any control over what happens. Generally it is essential to have control over your inputs and to ensure that you hever have floating digital inputs.
  • It's connected to PIN29 (p0.24) using #define BUTTON_5  NRF_GPIO_PIN_MAP(0,24). On HW it connects PIN29 and GND (already pullup in bsp.c, and active_state = 0)
    I have a bsp event for that button and I only enter that event when I press the button, is that enough to prove that it's not floating
    Thanks for your help
    Is it so that pin 29 is connected to ground when pushed, and that you do not have a pull-up? If so it will be floating when the button is not pressed, so yes, you need a pull-up. Note that there are internal pull resistors for every GPIO, so there is no need for an external pull-up - just enable the internal pull-up.
