did someone made Altium footprint for J-Link Needle Adapter or managed to find it?
www.segger.com/.../J-Link_Needle_Adapter.pdf
I am planning to make PCB using this adapter, and this element could save me a lot of time.
Cheers, Jernej
Cheers, Jernej
I don't know if this will help but Nordic makes a Beacon Reference design that uses the 6 pin Tag-Connect scheme. You can download the gerbers here: infocenter.nordicsemi.com/.../beacon_kit.html
You may need a MY PAGE account and a Product Key to unlock the file set. You can contact your local Nordic FAE or leave a message in the Support portal and someone will send you the Product Key.
If that does not help you or you need a different pin count "connector" then I suggest contacting Tag-Connect in the Bay Area. They may be able to help you.
Hope this helped.
Jay
Here are some of the files you may find of interest ... www.tag-connect.com/tag-connect-downloads
Hello Jay,
thanks for answer and it will help me, there is a footprint for degub connector but it's for 6 pin debug. I am looking for 10 pin connector . Cheers, Jernej
This adapter is used on the nRF51 DK, which you can find hardware files for here. Note that we do not use the version with a clip on header, if you want this you need to make the holes yourself, however those are well described in the physical descriptions you linked to yourself.
Øyvind
Hi Øyvind,
this is what I was loking for. Many thanks.
Cheers, hribo
