saadc
Hello everybody,
I wonder if somebody could give me an example of an easy way to use saadc without using any adc_event_handler for sdk 15.
I'm trying to do it myself from the saadc example but I'm still not getting out of it.
I just need to reed a voltage value from AIN0.
Thanks for your support.
Greetings from Switzerland
Ale
  • I found  a solution on youtube:
    www.youtube.com/watch
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    /* Create an empty handler and pass this handler in the saadc initialization function
    > Normally this handler deals with the adc events but we are using blocking mode
    > In blocking mode the functions are called and the processor waits for the adc to finish taking samples from the respective channels
    > Event handler will not be called in this method
    void saadc_callback_handler(nrf_drv_saadc_evt_t const * p_event)
    // Empty handler function
    // Create a function which configures the adc input pins and channels as well as the mode of operation of adc
    void saadc_init(void)
    // A variable to hold the error code
    ret_code_t err_code;
    // Create a config struct and assign it default values along with the Pin number for ADC Input
    // Configure the input as Single Ended(One Pin Reading)
    // Make sure you allocate the right pin.
    nrf_saadc_channel_config_t channel_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
    // Initialize the saadc
    // first parameter is for configuring the adc resolution and other features, we will see in future tutorial
    //on how to work with it. right now just pass a simple null value
    err_code = nrf_drv_saadc_init(NULL, saadc_callback_handler);
    // Initialize the Channel which will be connected to that specific pin.
    err_code = nrfx_saadc_channel_init(0, &channel_config);
    // A function which will initialize the Log module for us
    void log_init(void)
    // check if any error occurred during its initialization
    // Initialize the log backends module
    // call the log initialization function
    log_init();
    // call the saadc initialization function created above
    saadc_init();
    // a struct to hold 16-bit value, create a variable of this type because our input resolution may vary from 8 bit to 14 bits depending on our configurations
    // this variable holds the adc sample value
    nrf_saadc_value_t adc_val;
    // Print a simple msg that everything started without any error
    NRF_LOG_INFO("Application Started!!!");
    NRF_LOG_FLUSH();
    // Inifinite loop
    while (1)
    // a blocking function which will be called and the processor waits until the value is read
    // the sample value read is in 2's complement and is automatically converted once retrieved
    // first parameter is for the adc input channel
    // second parameter is to pass the address of the variable in which we store our adc sample value
    nrfx_saadc_sample_convert(0, &adc_val);
    // print this value using nrf log : here %d represents the integer value
    NRF_LOG_INFO("Sample value Read: %d", adc_val);
    // use nrf log and float marker to show the floating point values on the log
    // calculate the voltage by this: input_sample * 3.6 / 2^n (where n = 8 or 10 or 12 or 14 depending on our configuration for resolution in bits)
    NRF_LOG_INFO("Volts: " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(adc_val * 3.6 / 512));
    NRF_LOG_FLUSH();
    // give 500ms delay
    nrf_delay_ms(500);
  • I had already started on putting together a small example for you, but you beat me to it Slight smile Anyway. Here is what I made: 1565.saadc.zip
    Looks like it's quite similar to the one you found.
    The driver documentation can be found here: SAADC in case you have not seen it already.
  • Hi Vidar,
    ahh what a coincidence ahah anyways thank you very much for your time and work.
    Greetings
    Ale Slight smile
