hi,In SAADC sampling, the upper limit and lower limit of sampling results are set. Interrupt events are generated only when they are less than the lower limit or greater than the upper limit. But in my code, as long as the sampling ends, it will generate an interrupt event. What's the problem?
17.0.2sdk,52833
The general functions are as follows:
1. ADC sampling result > = 500, generates upper limit interrupt event and wakes up;
2. ADC sampling result < = 300, generates lower limit interrupt event and wakes up;
3.300 < ADC sampling result < 500, sleep;
ret_code_t ret;
NRF_UICR->NFCPINS = 0;
gpio_output_voltage_setup_3v3();
UART_Init();
log_init();
printf("\r\n***************************************************\r\n");
ret = nrf_drv_clock_init();
APP_ERROR_CHECK(ret);
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
advertising_start();
saadc__limit_init();
#define BAT_ADC_POWER_PIN NRF_GPIO_PIN_MAP(0,23)
nrf_gpio_cfg_output(BAT_ADC_POWER_PIN);
nrf_gpio_pin_set(BAT_ADC_POWER_PIN);
for (;;)
nrf_delay_ms(500);
nrfx_saadc_sample();
printf("into idle state\n");
nrf_delay_ms(10);
idle_state_handle();
#define SAMPLES_BUFFER_LEN 1
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_BUFFER_LEN];
static uint32_t m_adc_evt_counter;
void saadc_callback(nrfx_saadc_evt_t const * p_event)
float val;
if (p_event->type == NRFX_SAADC_EVT_DONE)
ret_code_t err_code;
err_code = nrfx_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_BUFFER_LEN);
int i;
printf("\r\nADC event number: %d\r\n", (int)m_adc_evt_counter);
for (i = 0; i < SAMPLES_BUFFER_LEN; i++)
printf("Sample value: %d ", p_event->data.done.p_buffer[i]);
val = p_event->data.done.p_buffer[i] * 3.6 /1024;
printf("Voltage = %.3fV\r\n", val);
m_adc_evt_counter++;
if(p_event->type == NRF_DRV_SAADC_EVT_LIMIT)
printf("Limit Event\r\n");
void saadc__limit_init(void)
nrf_saadc_channel_config_t channel_config =
NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
nrfx_saadc_limits_set(0,300,500);
nrfx_saadc_config_t saadc_config = NRFX_SAADC_DEFAULT_CONFIG;
saadc_config.resolution = NRF_SAADC_RESOLUTION_10BIT;
saadc_config.oversample = NRF_SAADC_OVERSAMPLE_DISABLED;
saadc_config.low_power_mode = false;
saadc_config.interrupt_priority = 6;
err_code = nrfx_saadc_init(&saadc_config, saadc_callback);
err_code = nrfx_saadc_channel_init(0, &channel_config);
err_code = nrfx_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_BUFFER_LEN);
err_code = nrfx_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_BUFFER_LEN);
In nrfx_ In the SAADC. C document, I have enabled the [nrf_saadc_int_ch3limit nrf_saadc_int_ch3limit] interrupt,see the #if ,
nrfx_err_t nrfx_saadc_init(nrfx_saadc_config_t const * p_config,
nrfx_saadc_event_handler_t event_handler)
NRFX_ASSERT(p_config);
NRFX_ASSERT(event_handler);
nrfx_err_t err_code;
if (m_cb.state != NRFX_DRV_STATE_UNINITIALIZED)
err_code = NRFX_ERROR_INVALID_STATE;
NRFX_LOG_WARNING("Function: %s, error code: %s.",
__func__,
NRFX_LOG_ERROR_STRING_GET(err_code));
return err_code;
m_cb.event_handler = event_handler;
nrf_saadc_resolution_set(p_config->resolution);
nrf_saadc_oversample_set(p_config->oversample);
m_cb.low_power_mode = p_config->low_power_mode;
m_cb.state = NRFX_DRV_STATE_INITIALIZED;
m_cb.adc_state = NRF_SAADC_STATE_IDLE;
m_cb.active_channels = 0;
m_cb.limits_enabled_flags = 0;
m_cb.conversions_end = false;
nrf_saadc_int_disable(NRF_SAADC_INT_ALL);
nrf_saadc_event_clear(NRF_SAADC_EVENT_END);
nrf_saadc_event_clear(NRF_SAADC_EVENT_STARTED);
nrf_saadc_event_clear(NRF_SAADC_EVENT_STOPPED);
#if 1
nrf_saadc_event_clear(NRF_SAADC_EVENT_CH3_LIMITH);
nrf_saadc_event_clear(NRF_SAADC_EVENT_CH3_LIMITL);
NRFX_IRQ_PRIORITY_SET(SAADC_IRQn, p_config->interrupt_priority);
NRFX_IRQ_ENABLE(SAADC_IRQn);
#if 1
nrf_saadc_int_enable(NRF_SAADC_INT_CH3LIMITH|NRF_SAADC_INT_CH3LIMITL);
#else
nrf_saadc_int_enable(NRF_SAADC_INT_END);
if (m_cb.low_power_mode)
nrf_saadc_int_enable(NRF_SAADC_INT_STARTED);
nrf_saadc_enable();
err_code = NRFX_SUCCESS;
NRFX_LOG_INFO("Function: %s, error code: %s.", __func__, NRFX_LOG_ERROR_STRING_GET(err_code));
return err_code;
thanks
