nrf52832 saadc multi channel reading
hello,
I tried to read adc sampling value from (NRF_SAADC_INPUT_AIN0~NRF_SAADC_INPUT_AIN4) with pip mode.
Here are my code as followings
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_gpio.h"
#include "nrf_nvmc.h"
#include "nrf_drv_gpiote.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SAMPLES_IN_BUFFER 5
#define ADC_CHANNEL_COUNT 5
volatile uint8_t state = 1;
// definition for GPIO
#define VIN_SENS            NRF_SAADC_INPUT_AIN0                                                  /**< LED1 GPIO */
#define CURR_CHG            NRF_SAADC_INPUT_AIN1                                                  /**< LED2 GPIO */
#define BAT_SENS            NRF_SAADC_INPUT_AIN2                                                  /**< HEATER CONTROL GPIO */
#define CURR_DCHG           NRF_SAADC_INPUT_AIN3                                                  /**< EMERGENCY CONTROL GPIO */
#define BAT_TEMP            NRF_SAADC_INPUT_AIN4                                                  /**< EMERGENCY CONTROL #2 GPIO */
#define ACC_ON              29
#define CHG_OFF             31
#define B_BOX_OFF           12
#define BMS_LED1            25                                                 /**< LED1 GPIO */
#define BMS_LED2            26                                                  /**< LED2 GPIO */
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static nrf_saadc_value_t     m_buffer_pool[10][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
static uint32_t              m_adc_evt_counter;
int16_t vin_sens_val=0, curr_chg_val=0, bat_sens_val=0, curr_dchg_val=0, bat_temp_val=0;
void box_gpio_init(void)
  ret_code_t err_code;
  nrf_gpio_cfg_output(BMS_LED1);
  nrf_gpio_cfg_output(BMS_LED2);
  nrf_gpio_cfg_output(CHG_OFF);
  nrf_gpio_cfg_output(B_BOX_OFF);
  nrf_gpio_cfg_input(ACC_ON,NRF_GPIO_PIN_PULLUP);
  nrf_gpio_pin_set(BMS_LED1);
  nrf_gpio_pin_set(BMS_LED2);
  nrf_gpio_pin_set(CHG_OFF);
  nrf_gpio_pin_clear(CHG_OFF);
  nrf_gpio_pin_set(B_BOX_OFF);
  nrf_gpio_pin_clear(B_BOX_OFF);
void timer_handler(nrf_timer_event_t event_type, void * p_context)
    /* setup m_timer for compare event every 400ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 250);
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        int i;
        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        for (i = 0; i < SAMPLES_IN_BUFFER; i++)
            //NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
            switch(i%5)
              case 0:
                vin_sens_val = p_event->data.done.p_buffer[i];
              case 1:
                curr_chg_val = p_event->data.done.p_buffer[i];
              case 2:
                bat_sens_val = p_event->data.done.p_buffer[i];
              case 3:
                curr_dchg_val = p_event->data.done.p_buffer[i];
              case 4:
                bat_temp_val = p_event->data.done.p_buffer[i];
              default: break;
        m_adc_evt_counter++;
        NRF_LOG_INFO("%d %d %d %d %d", vin_sens_val, curr_chg_val, bat_sens_val, curr_dchg_val, bat_temp_val);
        nrf_gpio_pin_toggle(CHG_OFF);
void saadc_init(void)
    nrf_saadc_channel_config_t channel_config_vin_sens =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(VIN_SENS);
    channel_config_vin_sens.mode       = NRF_SAADC_MODE_SINGLE_ENDED;
    channel_config_vin_sens.acq_time = NRF_SAADC_ACQTIME_20US;
    nrf_saadc_channel_config_t channel_config_curr_chg =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(CURR_CHG);
    channel_config_curr_chg.mode       = NRF_SAADC_MODE_SINGLE_ENDED;
    channel_config_curr_chg.acq_time = NRF_SAADC_ACQTIME_20US;
    nrf_saadc_channel_config_t channel_config_bat_sens =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(BAT_SENS);
    channel_config_bat_sens.acq_time = NRF_SAADC_ACQTIME_20US;
    channel_config_bat_sens.mode       = NRF_SAADC_MODE_SINGLE_ENDED;
    nrf_saadc_channel_config_t channel_config_curr_dchg =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(CURR_DCHG);
    channel_config_curr_dchg.acq_time = NRF_SAADC_ACQTIME_20US;
    channel_config_curr_dchg.mode       = NRF_SAADC_MODE_SINGLE_ENDED;
    nrf_saadc_channel_config_t channel_config_bat_temp =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(BAT_TEMP);
    channel_config_bat_temp.acq_time = NRF_SAADC_ACQTIME_20US;
    channel_config_bat_temp.mode       = NRF_SAADC_MODE_SINGLE_ENDED;
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config_vin_sens);
    err_code = nrf_drv_saadc_channel_init(1, &channel_config_curr_chg);
    err_code = nrf_drv_saadc_channel_init(2, &channel_config_bat_sens);
    err_code = nrf_drv_saadc_channel_init(3, &channel_config_curr_dchg);
    err_code = nrf_drv_saadc_channel_init(4, &channel_config_bat_temp);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
    box_gpio_init();
    uint32_t err_code = NRF_LOG_INIT(NULL);
    ret_code_t ret_code = nrf_pwr_mgmt_init();
    APP_ERROR_CHECK(ret_code);
    saadc_init();
    saadc_sampling_event_init();
    NRF_LOG_INFO("SAADC HAL simple example started.");
    while (1)
        nrf_pwr_mgmt_run();
        NRF_LOG_FLUSH();
If I have no any voltage into adc input channel, I had a result as following
<info> app: 80 80 81 71 85
If I have only voltage into ch0 as adc input channel, I had a result as following
<info> app: 670 266 152 101 102
If I have only voltage into ch1 as adc input channel, I had a result as following
<info> app: 80 673 255 133 111
If I have only voltage into ch2 as adc input channel, I had a result as following
<info> app: 67 72 668 256 145
If I have only voltage into ch3 as adc input channel, I had a result as following
<info> app: 70 73 74 671 281
If I have only voltage into ch4 as adc input channel, I had a result as following
<info> app: 90 89 86 78 669
It seems to be effected to other channel.
How can I solve this problem?
