[nRF52811] two way UART connection
I am currently using the logger backend to send information via UART from the nRF52811 to a PC. This works well, but only for one way communication. I would like to send some instructions from the PC to the nRF52811, which means having a two way communication via UART. Is this even possible?
Thanks in advance.
David
    slid_daaviet said:
    Thanks for the tip, but that example is for UART over BLE, which is not exactly what I'm looking for.
    Yes, but the thing is that the example implements UART bridging over BLE (so both physical UART and NUS). If you ignore the BLE/NUS part, you are left with a simple example of using plain UART without the added complexity of the logger library. You can also refer to the UART example for something similar.
    slid_daaviet said:
    So, I am already receiving data from the nRF52811, but I would like to just send data through that serial port from the PC to the nRF52811.
    I see. The easiest way is to refer to one of the examples mentioned above, which implements bidirectional UART communication.
  • Thanks for the help. I have tried adapting this example to the nRF52811, without success so far. I think the problem is in the APP_UART_FIFO_INIT function, but can't even debug it correctly, because there is a call to the app_error_handler funcion and NRF_BREAKPOINT_COND is activated. It's probably a vague problem description, but that's what I know so far...
    There was a problem with the link to the example you are using. Can you post it again?
    I see. What did you do to debug? The APP_UART_FIFO_INIT() essentially created two static buffers, and then calls app_uart_init(). If there is an issue, that should return an error code.
    This is to aid debugging. It breaks on error, and then you can inspect with a debugger. What error code was returned from where? As you point to APP_UART_FIFO_INIT I assume you see it is from app_uart_init()? You may be interested in An introduction to error handling in nRF5 projects.
  • There was a problem with the link to the example you are using. Can you post it again?
    It's this UART example.
    If I am correct, it appears to occur when app_uart_get() is called. Then uart_event_handler is called, which in turn calls app_error_handler_bare. Depending on the breakpoints I use, app_error_handler_bare receives an error code of either 0x00000004 or 0x0000000c, which according to nrf_error.h correspond to "No Memory for operation" and "Data size exceeds limit" respectively.
    Ah I see. I'll read up on that, thanks.
  • If I enable the DEBUG flag, app_error_handler function is called. It has an error code, a p_file_name and line_num, how can I interpret the hexadecimal value of p_file_name to locate the error?
