Include labels/variables for nCS
With reference to Case ID:278209, I wanted to include a driver file, for which I was suggested to add the label/variable "zephyr_library_include_directories(.)" in my CMakeLists.txt.
So with the label/variable "zephyr_library_include_directories(.)" I can include most of the zephyr driver files which is fine.
My query is, in SDK there are plenty of files other than zephyr driver files, so what are the various available labels like "zephyr_library_include_directories(.)" that I can add to my CMakeLists.txt to include other nCS files...?
For example:
1. To include files from the path nCS\v1.7.0\modules\hal\nordic\nrfx\drivers\include, what is the label/variable to be added in CMakeLists.txt..?
2. To include files from nCS\v1.7.0\nrf\subsys\bluetooth\mesh, what is the label/variable to be added in CMakeLists.txt..?
3.  To include files from nCS\v1.7.0\zephyr\include\bluetooth, what is the label/variable to be added in CMakeLists.txt..?
  • Hey again Ubaid!
    For all of the cases you mentioned, it is done using configurations, not by adding more paths on CMakeLists.txt.
    1. Add the config CONFIG_NRFX_GPIOTE=y so that you can use #include <nrfx_gpiote.h> in main.c. Take a look here.
    2. Add Mesh configs such as CONFIG_BT_MESH=y
    3. Add bluetooth configs such as CONFIG_BT=y
    For all drivers that are already a part of Zephyr you simply add configurations and include a headerfile, then everything will be ready for you to use the API. I would recommend that you go through this NCS tutorial, everything is explained there.
    Elfving
  • Hello ,
    Thanks for the info, I understand about the configurations and menuconfigs, I was just looking at a way to include a file (which is not included by configurations), in a newly user defined file.
    For example:
    In some file "Sample_file.c", I want to: #include "nCS/v1.7.0/modules/hal/nordic/nrfx/hal/nrf_clock.h"
    So instead of having such a long include path in the include definition, how can i just add as #include "nrf_clock.h" and configure the build system to find the file..?
    Like in above case by including zephyr_library_include_directories(.) I am able to easily navigate to zephyr drivers files.!
    So i just want to know various available labels like zephyr_library_include_directories.
    To make CMakeLists add any given folder to the path you can use zephyr_include_directories(C:/Users/ ...), and maneuver your way to the files you want. If you want a smaller path name there as well, you can use environment variables, like we have done in several of our samples. For instance $ENV{ZEPHYR_BASE} would take you to your zephyr folder. I see that $PWD takes you to your NCS version, that might be useful to you.
    Though with the example you provided you can simply use #include <hal/nrf_clock.h> in your file, as the nrfx config adds the nrfx folder to the path.
    When it comes to other arguments similar to zephyr_include_directories I am a little uncertain, as I haven't found myself needing much more. There is a list of them here though.
    Was this what you were looking for, or am I misunderstanding you?
    Elfving
