DFU for external BLE Sensor
  I have a current project that is based on the nRf52840.  This project acts both as a peripheral and a central.  I have a need to update the firmware on a remote BLE sensor using DFU, i.e., I need to do exactly what the nRfConnect application does when it updates a peripheral firmware via DFU.  My thought was to use the nRf52840 dongle and develop this code on my PC and then port it to my embedded system.  I also thought the best starting point would be the source code for the nRfConnect application which I would port it but I see from user comments that nordic did not release the source code for this.  Is it possible to get this source code or is there another example that demonstrates what I need to accomplish?
Thanks!
      I figured it out and just had my first successful Image Upload!  I actually discovered "adb" which is android debug and set that up which allowed me to capture EVERYTHING that nRfConnect was sending while it was doing a firmware update of the sensor.  Then I used looked at the capture file with the Wireshark application which allowed me to see the raw bytes that were being sent.  Once I had that I was able to figure it out.  Really there is literally no decent documentation ANYWHERE that describes the DFU vis SMP process on a byte level which is what is needed if you are developing a solution from scratch.
    Anyway, I wanted to thank you again for the help that you gave me, without that I would still be struggling.
    Many Thanks,
    Dave Patton
  • Excellent! I did not even think of using debug logs from the phone. My plan was to try to log the data from the DFU target. I didn't get that far though. Not sure if I would have been able to log the data fast enough either.
    I will report the missing documentation as a feature request. Hopefully we can add it so others who are developing their own DFU clients in the future do not have to reverse engineer the protocol like you had to.
    Thanks for the update.
    Vidar
    There is one piece of information that I have been unable to figure out.  The first block of data in the upload contains the entire image length and a "sha" field.  Below is a real example of the data in both binary and the "json" representation of the cbor data.  I need to know exactly what the "sha" is and how to calculate it so I can include the "sha" with my uploads.
    Binary data = SMPHeader|CBOR_Data packet: 020000f400010001bf646461746158d53db8f3960000000000020000fca5070000000000011b0100860e536100000000ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff636c656e1a0007a8936373686143525249636f666600ff
    SMPHeader: 020000f400010001
    CBOR_Data: bf646461746158d53db8f3960000000000020000fca5070000000000011b0100860e536100000000ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff636c656e1a0007a8936373686143525249636f666600ff
    cbor json: {"data": h'3DB8F3960000000000020000FCA5070000000000011B0100860E536100000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF', "len": 501907, "sha": h'525249', "off": 0}
    Dave Patton
  • Hi Dave,
    It's the sha-256 digest of your signed image, but only the first 3 bytes of it: https://github.com/zephyrproject-rtos/mcumgr/blob/master/cmd/img_mgmt/src/img_mgmt.c#L493-L501
    The easiest way to get the digest (is placed in the image trailer) is to use the imgtool and run imgtool verify <signed_image>
    Vidar
  • Hi, I am trying to move this code into my non-dev board project and for this file nrf_queue.c this is at the top of the file.
    #if NRF_MODULE_ENABLED(NRF_QUEUE)
    This currently is false so none of the code in this file is active.  I added this to my sdk_config.h
    // <e> NRF_QUEUE_ENABLED - nrf_queue - Queue module
    #ifndef NRF_QUEUE_ENABLED
    #define NRF_QUEUE_ENABLED 1
    // <q> NRF_QUEUE_CLI_CMDS - Enable CLI commands specific to the module
    however, that did not enable the code in nrf_queue.c.  How can I enable this code?
    Thanks
    Dave
