DFU for external BLE Sensor
  I have a current project that is based on the nRf52840.  This project acts both as a peripheral and a central.  I have a need to update the firmware on a remote BLE sensor using DFU, i.e., I need to do exactly what the nRfConnect application does when it updates a peripheral firmware via DFU.  My thought was to use the nRf52840 dongle and develop this code on my PC and then port it to my embedded system.  I also thought the best starting point would be the source code for the nRfConnect application which I would port it but I see from user comments that nordic did not release the source code for this.  Is it possible to get this source code or is there another example that demonstrates what I need to accomplish?
Thanks!
  • Hi Dave,
    Are you sure you need to create a new project for this? Normally it's sufficient to just change the board file (Using the SDK with other boards) in addition to maybe updating some of the global pre-processor defines. Anyway. The code in nrf_queue.c should become enabled as long as NRF_QUEUE_ENABLED==1. Maybe it's being defined as '0' elsewhere in your project?
    Vidar
      I did the DFU via SMP project on the Dev kit to get it working.  I now have to move that code to our real project that has many other things in it.  Unfortunately our project was based on an SDK that did not contain the BLE GATT QUEUE.  I copied the /ble/nrf_ble_gq directory from the 17.01 SDK to our project to add the BLE GAT QUEUE.  Then I added the following to the skd_config.h file:
    // <e> NRF_QUEUE_ENABLED - nrf_queue - Queue module
    #ifndef NRF_QUEUE_ENABLED
    #define NRF_QUEUE_ENABLED 1
    // <o> NRF_BLE_GQ_BLE_OBSERVER_PRIO
    // <i> Priority with which BLE events are dispatched to the GATT Queue module.
    #ifndef NRF_BLE_GQ_BLE_OBSERVER_PRIO
    #define NRF_BLE_GQ_BLE_OBSERVER_PRIO 1
    // <e> NRF_BLE_GQ_ENABLED - nrf_ble_gq - BLE GATT Queue Module
    #ifndef NRF_BLE_GQ_ENABLED
    #define NRF_BLE_GQ_ENABLED 1
    // <o> NRF_BLE_GQ_DATAPOOL_ELEMENT_SIZE - Default size of a single element in the pool of memory objects.
    #ifndef NRF_BLE_GQ_DATAPOOL_ELEMENT_SIZE
    #define NRF_BLE_GQ_DATAPOOL_ELEMENT_SIZE 20
    // <o> NRF_BLE_GQ_DATAPOOL_ELEMENT_COUNT - Default number of elements in the pool of memory objects.
    #ifndef NRF_BLE_GQ_DATAPOOL_ELEMENT_COUNT
    #define NRF_BLE_GQ_DATAPOOL_ELEMENT_COUNT 8
    // <o> NRF_BLE_GQ_GATTC_WRITE_MAX_DATA_LEN - Maximal size of the data inside GATTC write request (in bytes).
    #ifndef NRF_BLE_GQ_GATTC_WRITE_MAX_DATA_LEN
    #define NRF_BLE_GQ_GATTC_WRITE_MAX_DATA_LEN 2
    // <o> NRF_BLE_GQ_GATTS_HVX_MAX_DATA_LEN - Maximal size of the data inside GATTC notification or indication request (in bytes).
    #ifndef NRF_BLE_GQ_GATTS_HVX_MAX_DATA_LEN
    #define NRF_BLE_GQ_GATTS_HVX_MAX_DATA_LEN 16
    To me this looks like all that should be required but I am getting a compile error that I can't figure out.  I tried searching online for others having this issue but I have been unable to find anything, can you help with this.  The code that is generating the error is:
    NRF_BLE_GQ_DEF(m_ble_gatt_queue, /**< BLE GATT Queue instance. */
    NRF_SDH_BLE_CENTRAL_LINK_COUNT,
    NRF_BLE_GQ_QUEUE_SIZE);
    Building ‘SkyHub’ from solution ‘Solution ‘SkyHub’’ in configuration ‘Release’
    Preprocessing file_transfer.c
    Preprocessing packet_processing.c
    Preprocessing pc_uart_interface.c
    Preprocessing mobile_app_interface.c
    Preprocessing sky_dfu.c
    Preprocessing skybitz_app.c
    Preprocessing int_flash.c
    Preprocessing mx25flash_spi.c
    Preprocessing spi_flash.c
    Preprocessing skycam_ota.c
    Preprocessing con_controller.c
    Compiling ‘file_transfer.c’
    Compiling ‘packet_processing.c’
    Compiling ‘pc_uart_interface.c’
    Preprocessing rtc_timer.c
    Compiling ‘mobile_app_interface.c’
    Compiling ‘sky_dfu.c’
    Compiling ‘mx25flash_spi.c’
    Compiling ‘int_flash.c’
    Compiling ‘skybitz_app.c’
    unknown type name 'm_ble_gatt_queuereq_queue'
    expected declaration specifiers or '...' before numeric constant
    expected declaration specifiers or '...' before 'NRF_QUEUE_MODE_NO_OVERFLOW'
    'm_ble_gatt_queuereq_queue' undeclared here (not in a function); did you mean 'm_ble_gatt_queuepurge_queue'?
    conversion from 'unsigned int' to 'unsigned char' changes value from '4022250974' to '222' [-Woverflow]
    Compiling ‘spi_flash.c’
    Compiling ‘skycam_ota.c’
    Compiling ‘con_controller.c’
    Compiling ‘rtc_timer.c’
    Build failed
    Dave Patton
      I forgot to mention that the file that gets the compile error contains these header includes>
    #include "../../nRF_Includes/queue/nrf_queue.h"
    #include "../../nRF_Includes/nrf_ble_gq/nrf_ble_gq.h"
    I would have expected these headers to resolve the compile issues but they did not.
  • Nevermind, I solved it.  My project has a queue dir that contained the QUEUE files nrf_queue.h and nrf_queue.c from the earlier SDK.  I copied those files from the 17.1SDK and the code now builds.
    Dave
    I am having 2 very weird problems, one seems like it may be compiler related.  The other one I am clueless about.  I will explain both below.
    *************************    PROBLEM #1    ********************************
    See the code below:
    BLE_NUS_C_DEF(m_ble_nus_c);
    uint32_t ble_nus_c_init(ble_nus_c_t * p_ble_nus_c, ble_nus_c_init_t * p_ble_nus_c_init)
        uint32_t      err_code;
        ble_uuid_t    uart_uuid;
        ble_uuid128_t nus_base_uuid = NUS_BASE_UUID;
        VERIFY_PARAM_NOT_NULL(p_ble_nus_c);
        VERIFY_PARAM_NOT_NULL(p_ble_nus_c_init);
        err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_ble_nus_c->uuid_type);
        VERIFY_SUCCESS(err_code);
        uart_uuid.type = p_ble_nus_c->uuid_type;
        uart_uuid.uuid = BLE_UUID_NUS_SERVICE;
        p_ble_nus_c->conn_handle           = (uint16_t)0x1111;
        p_ble_nus_c->conn_handle           = BLE_CONN_HANDLE_INVALID;
        p_ble_nus_c->evt_handler           = p_ble_nus_c_init->evt_handler;
        p_ble_nus_c->handles.nus_tx_handle = (uint16_t)0x2222;
        p_ble_nus_c->handles.nus_tx_handle = BLE_GATT_HANDLE_INVALID;
        p_ble_nus_c->handles.nus_status_handle = BLE_GATT_HANDLE_INVALID;
        p_ble_nus_c->handles.nus_buffer_handle = BLE_GATT_HANDLE_INVALID;
        p_ble_nus_c->handles.nus_rx_handle = BLE_GATT_HANDLE_INVALID;
    	print_trace("ble_nus_c_init(1) p_ble_nus_c->conn_handle: %d", p_ble_nus_c->conn_handle);
        err_code = ble_db_discovery_evt_register(&uart_uuid);
    	print_trace("ble_nus_c_init(2) p_ble_nus_c->conn_handle: %d", p_ble_nus_c->conn_handle);
    	return err_code;
    /**@brief Function for initializing the Nordic UART Service (NUS) client. */
    static void nus_c_init(void)//FA191118
    	ret_code_t  err_code;
    	ble_nus_c_init_t init;
    	init.evt_handler = ble_nus_c_evt_handler;
    	err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    void main(void)
        nus_c_init();
    What is happening is that when I run this line of code:  p_ble_nus_c->conn_handle = (uint16_t)0x1111; it does not set the conn_handle to 0x1111, it sets it to 0x0011 and also sets part of the nus_tx_handle when this instruction is executed.  I have attached a screen shot of the debugger showing this.
    This started happening after I pulled the SMP implementation from the dev board project to our real project.  Our real project was based on a SDK that did not contain the GAT QUEUE stuff, i.e., nrf_ble_gq.c and nrf_ble_gq.h.  I therefore copied these file from the 17.1SDK into our real project.  I then had to replace the nrf_queue.c and nrf_queue.h in our real project with the files from the 17.1SDK to get the project to build.  The SMP service stuff is now working in our real project.
    *************************    PROBLEM #2    ********************************
    I can no longer initialize the watchdog.  Here is the code:
    static void watchdog_init(void)
    	uint32_t err_code = NRF_SUCCESS;
    	//Configure WDT.
    	nrf_drv_wdt_config_t config = NRF_DRV_WDT_DEAFULT_CONFIG;
    	err_code = nrf_drv_wdt_init(&config, wdt_event_handler);
    	err_code = nrf_drv_wdt_channel_alloc(&m_channel_id);
    	nrf_drv_wdt_enable();
        watchdog_init();
    It is crashing inside watchdog_init() at this line:  err_code = nrf_drv_wdt_init(&config, wdt_event_handler);
    Look at this line:  nrf_drv_wdt_config_t config = NRF_DRV_WDT_DEAFULT_CONFIG;
    Below is a Debug Watch showing the values:
    When I single step through the functions I get to the function below
    nrfx_err_t nrfx_wdt_init(nrfx_wdt_config_t const * p_config,
                             nrfx_wdt_event_handler_t  wdt_event_handler)
        NRFX_ASSERT(p_config);
        nrfx_err_t err_code;
    #if !NRFX_CHECK(NRFX_WDT_CONFIG_NO_IRQ)
        NRFX_ASSERT(wdt_event_handler != NULL);
        m_wdt_event_handler = wdt_event_handler;
    #else
        NRFX_ASSERT(wdt_event_handler == NULL);
        (void)wdt_event_handler;
        if (m_state == NRFX_DRV_STATE_UNINITIALIZED)
            m_state = NRFX_DRV_STATE_INITIALIZED;
            err_code = NRFX_ERROR_INVALID_STATE;
            NRFX_LOG_WARNING("Function: %s, error code: %s.",
                             __func__,
                             NRFX_LOG_ERROR_STRING_GET(err_code));
            return err_code;
        nrf_wdt_behaviour_set(p_config->behaviour);
        nrf_wdt_reload_value_set((p_config->reload_value * 32768) / 1000);
        NRFX_IRQ_PRIORITY_SET(WDT_IRQn, p_config->interrupt_priority);
        NRFX_IRQ_ENABLE(WDT_IRQn);
        err_code = NRFX_SUCCESS;
        NRFX_LOG_INFO("Function: %s, error code: %s.", __func__, NRFX_LOG_ERROR_STRING_GET(err_code));
        return err_code;
    I set a breakpoint at this line:  NRFX_IRQ_PRIORITY_SET(WDT_IRQn, p_config->interrupt_priority);
    And then look at the p_config variable which should be filled with NRF_DRV_WDT_DEAFULT_CONFIG but it is not.  I have attached a debug screen showing this below.
    If after entering the nrfx_wdt_init function I stop at a breakpoint and  adjust the p_config  data values to be those of NRF_DRV_WDT_DEAFULT_CONFIG Before NRFX_IRQ_PRIORITY_SET(WDT_IRQn, p_config->interrupt_priority); is called then I do not get a crash.   This is similar to the first problem, the compiler seems like it is messing things up.
    I am guessing that this may have been caused by adding in the SMP stuff to our real project since it did not happen prior to that.  I have been beating my head against a wall all day trying to make sense of this.  I am really hoping that you have some ideas.
    Dave Patton
