SES configuration for zephyr sample demos
Hello Sir/Madam,
I followed the steps of the link https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/gs_assistant.html#getting-started-assistant to set up the environment to test the demo project by SES.
The project is imported with the following settings.
This is a sample project from zephyr. Generally, if generating "Unix Makefile" by cmake, zephyr could configure which component to be included in the sample. For example, I could disable the SEGGER_RTT part (not compiled into the firmware) by the command "make menuconfig".
Does SES for nRF provide similar functionality?
And I also want to change the compiler to clang. I do not find the responding choice from the project option. Does SES for nRF support this feature? If so, how to change it to clang?
Thanks for your help.
    Yes. You can get the same functionality from Project -> Configure nRF Connect SDK Project...
    Clang is not supported.
    PS: I see from the screenshot that you are using master and not a release. I recommend that you stick with 1.7.0 which is the latest release, instead of using master.
