How to add IS_SRVC_CHANGED_CHARACT_PRESENT to app
I'm running into issues where iOS is caching the handles. I found out that I need to set IS_SRVC_CHANGED_CHARACT_PRESENT to 1.
But where should I do that? In sdk_config.h?
The solution contains no references to this define, so how does setting it change anything for my application? Or is there more I need to add to add the service changed char?
Thanks in advance.
Remco Poelstra
    iOS will cache your attribute table in case you do not use bonding and the service changed characteristic is missing.
    Unfortunately not all projects has all setting sin the sdk_config file. But you should be able to find this in sdk_config In many projects:
    #ifndef NRF_SDH_BLE_SERVICE_CHANGED
    #define NRF_SDH_BLE_SERVICE_CHANGED 0
    , i.e. The ANCS client.and others. There is also an option to handle service changed notification in PM for bonded devices. To use that you need to enable:
    #ifndef PM_SERVICE_CHANGED_ENABLED
    #define PM_SERVICE_CHANGED_ENABLED 0
  • Thanks! I had missed that the define was renamed somewhere/sometime.
    This is is readily available in my sdk_config.h and works like a charm.
