i ran nRF Coap Client and it worked pretty well.
I am working with nRF9160 DK.
Now, I want to add DTLS to this example to secure the data.
Can someone please help me or is there any tutorials on how to do that?
Cedric
Cedric
The problem appears to be the destination, which is 0.0.0.0. Which server/IP address are you trying to connect to? What is CONFIG_SERVER_ADRESS defined as?
CONFIG_SERVER_ADRESS is "californium.eclipseprojects.io" and the IP address is 35.185.40.182
ced27 said:CONFIG_SERVER_ADRESS is "californium.eclipseprojects.io" and the IP address is 35.185.40.182
In your case, CONFIG_SERVER_ADDRESS has to be the IP address since you can’t use the actual address of the server as an input argument to inet_pton (right now probably the function won’t return 1).
But anyway, my recommendation would be to use getaddrinfo for CONFIG_SERVER_ADDRESS, as demonstrated in the CoAP Client sample.
Markus
here is what i got:
2021-10-25T08:20:25.195Z INFO Application data folder: C:\Users\tcheced\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor 2021-10-25T08:20:25.236Z DEBUG App pc-nrfconnect-linkmonitor v1.1.10 official 2021-10-25T08:20:25.236Z DEBUG App path: C:\Users\tcheced\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor 2021-10-25T08:20:25.236Z DEBUG nRFConnect 3.7.1, required by the app is (^3.6.0) 2021-10-25T08:20:25.236Z DEBUG nRFConnect path: C:\Users\tcheced\AppData\Local\Programs\nrfconnect\resources\app.asar 2021-10-25T08:20:25.236Z DEBUG HomeDir: C:\Users\tcheced 2021-10-25T08:20:25.237Z DEBUG TmpDir: C:\Users\tcheced\AppData\Local\Temp 2021-10-25T08:20:25.248Z VERBOSE Could not fetch serial number for serial port at COM3 2021-10-25T08:20:27.603Z INFO Modem port is opened 2021-10-25T08:20:32.404Z DEBUG modem << *** Booting Zephyr OS build v2.6.0-rc1-ncs1 *** 2021-10-25T08:20:32.433Z DEBUG modem << Startet..... 2021-10-25T08:20:32.688Z DEBUG modem << PSM-Modus aktiviert 2021-10-25T08:20:32.693Z DEBUG modem << Verbindung zum LTE-Netz wird hergestellt 2021-10-25T08:20:32.696Z DEBUG modem << Das kann ein paar Minuten dauern.. 2021-10-25T08:20:32.823Z DEBUG modem << Mit LTE-Netz verbunden 2021-10-25T08:20:33.994Z DEBUG modem << +CEREG: 2,"63AE","01A3F802",7 2021-10-25T08:20:34.020Z DEBUG modem << LTE veränderte Zelle: Zelle ID: 27523074, Tracking area: 25518 2021-10-25T08:20:34.031Z DEBUG modem << Active LTE Modus: LTE-M 2021-10-25T08:20:34.032Z DEBUG modem << +CSCON: 1 2021-10-25T08:20:34.035Z DEBUG modem << RRC Modus: verbunden 2021-10-25T08:20:36.847Z DEBUG modem << +CEREG: 5,"63AE","01A3F802",7,,,"00000000","11100000" 2021-10-25T08:20:36.856Z DEBUG modem << Netwerkregistrierungsstatus: verbunden mit Roaming 2021-10-25T08:20:36.864Z DEBUG modem << IPv4 Address found 35.185.40.182 2021-10-25T08:20:36.868Z DEBUG modem << PSM-Parameter update: TAU: -1, Active time: 0 2021-10-25T08:20:37.391Z DEBUG modem << Verbindung fehlgeschlagen: error 95 2021-10-25T08:20:37.396Z DEBUG modem << Keine Verbindung zum Server möglich
Any idea of what the problem may be?
ced27 said:Any idea of what the problem may be?
Have you updated the modem and server with a Pre-shared Key (PSK)?
Hi Markus,
i haven't done it from the Californium server side yet. Is there may be any tutorials on how i may it? And eventually how i may run a host on the californium server?
Any idea will help
thanks
