Easy ways to debug BLE connectivity issues
Are there any convenient ways to debug BLE connectivity issues? I have the service up and running but the connection on nRFConnect App doesn't quite go through: it remains stuck on "Connecting" state.
It was working all fine until of a sudden and I can't seem to figure out what went wrong
  • I meant the iPhone's system settings, not the nRF Connect's setting. If you go to the settings in which you can administer apps and permissions, etc. there should be an option to clear the app data and cache.
    have you tried it yourself? I know you don't have an iPhone but it'd have been worth a try at least, cause I can't seem to find any option to delete the cache.
    Ah, my mistake - it seems my described approach was a little too android-y.
    My colleague confirm this, and tells me that the way to make sure that an apps cache is cleared in iOS is as described in this article in the Reinstall apps to clear cache section. Could you confirm that you did not use the Offload App option when you reinstalled the application last?
    Karl
  • I think the smart approach would be to first trying it on your end, and see whether you're successful in doing so. As mentioned earlier, I CANNOT see a clear cache option for the nRF Connect App (as the article talks about third-party apps which isn't the same for ALL the apps including nRF Connect). And as mentioned earlier too, I have tried deleting the app and reinstalling TO NO AVAIL. I tried it again and the same result.
    Please provide a helpful response regarding this. This seems to be getting dragged for a bit now...
    Thanks
    Part of the issue here is that I am unable to reproduce the behavior you describe on my end, which diminishes the value of debugging actions taken on my end - since I have no idea if the steps I take resolve the issue on your end.
    I have discussed this with multiple colleagues as well, and none of them have seen or heard about the behavior you describe, unfortunately.
    I know this, and I hear you. I only asked you to confirm that you did not do so using the Offload Apps option when you did the reinstallation, as this would mean that the iOS device could keep app data.
    As mentioned I have already reported this to our nRF Connect for iOS developers, and I will update you as soon as I hear anything back from them on this issue. Unfortunately, I can not say anything about when this will be.
    Karl
  • Isn't it possible to set the priority of the issue you assigned to the iOS team? sure I don't want it resolved overnight but at least some idea as to whether the bug actually exists or some input from the corresponding team?
