Hi guys,
I am trying to get the PWM rocking. Everything works, but as soon as I define a nrfx_pwm_handler_t in the nrfx_pwm_init, my system crashes with the following error:
[00:00:00.345,001] <err> os: >>> ZEPHYR FATAL ERROR 1: Unhandled interrupt on CPU 0 [00:00:00.345,031] <err> os: Current thread: 0x20000178 (idle 00) [00:00:00.582,702] <err> fatal_error: Resetting system
What am I missing? Here is the full code:
#include <nrfx_pwm.h>
#include <devicetree.h>
#include <device.h>
#define LED0_NODE DT_ALIAS(led0)
#define LED_PIN DT_GPIO_PIN(LED0_NODE, gpios)
void pwmHandler(nrfx_pwm_evt_type_t event_type, void * p_context) {
printk("handler!\n");
void main(void) {
static nrfx_pwm_t m_pwm0 = NRFX_PWM_INSTANCE(0);
uint32_t err_code;
nrfx_pwm_config_t const config0 = {
.output_pins =
LED_PIN | NRFX_PWM_PIN_INVERTED,
NRFX_PWM_PIN_NOT_USED,
.irq_priority = 7,
.base_clock = NRF_PWM_CLK_125kHz,
.count_mode = NRF_PWM_MODE_UP,
.top_value = 1000,
.load_mode = NRF_PWM_LOAD_COMMON,
.step_mode = NRF_PWM_STEP_AUTO
err_code = nrfx_pwm_init(&m_pwm0, &config0, pwmHandler, NULL);
if (!err_code)
printk("NRF PWM could not be initialized: %d\n", err_code);
static nrf_pwm_values_common_t seq_values[] = {
0, 1000
nrf_pwm_sequence_t const seq = {
.values.p_common = seq_values,
.length = NRF_PWM_VALUES_LENGTH(seq_values),
.repeats = 0,
.end_delay = 0
nrfx_pwm_simple_playback(&m_pwm0, &seq, 1, NRFX_PWM_FLAG_LOOP);
void simplePwmExample(uint8_t pin) {
// see https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v15.0.0%2Fhardware_driver_pwm.html
// low power PWM for LED blinking
uint32_t err_code;
.output_pins =
pin | NRFX_PWM_PIN_INVERTED, // channel 0
NRFX_PWM_PIN_NOT_USED, // channel 1
NRFX_PWM_PIN_NOT_USED, // channel 2
NRFX_PWM_PIN_NOT_USED, // channel 3
.irq_priority = 7,
.top_value = 1000,
err_code = nrfx_pwm_init(&m_pwm0, &config0, NULL, NULL);
if (!err_code)
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1000
.repeats = 0,
.end_delay = 0
while (true) {
k_msleep(10000);
