USB Composite not showing data after a confirmation on sending
Hey Team,
I was playing around with the composite example, and added in my own class a  and used the mouse class to implement it while changing it to suit what i have
orgianlly to output to EP3 and removing the subclass_boot/ setting it to be a generic device from a mouse device.
on pressing a button, i set a bunch of the 'buttons' to 1 and then organise it into the report buffer and send as like the other examples do. I get no error and it goes go through but looking at the device in test mode no data seems to trigger on.
Not sure what im missing.
Main changes:
 * @brief Initializer of interface descriptor for HID mouse class.
 * @param interface_number Interface number.
#define APP_USBD_HID_GAMEPAD_INTERFACE_DSC(interface_number)      \
        APP_USBD_HID_INTERFACE_DSC(interface_number,            \
                                   1,                           \
                                   APP_USBD_HID_SUBCLASS_NONE ,  \
                                   APP_USBD_HID_PROTO_GENERIC )
 * @brief Global definition macro of app_usbd_hid_mouse_t class.
 * @param instance_name     Name of global instance.
 * @param interface_number  Unique interface number.
 * @param endpoint          Input endpoint (@ref nrf_drv_usbd_ep_t).
 * @param user_ev_handler   User event handler (optional).
 * @param subclass_boot     Subclass boot (@ref app_usbd_hid_subclass_t).
 * @code
   APP_USBD_HID_MOUSE_GLOBAL_DEF(my_awesome_mouse, 0, NRF_DRV_USBD_EPIN1, 3, NULL);
 * @endcode
  //static uint8_t const CONCAT_2(name,  _data)[] = fuck bcnt
     /*typedef struct {
    size_t                size;
    app_usbd_descriptor_t type;
    uint8_t const * const p_data;
    } app_usbd_hid_subclass_desc_t; */
#define APP_USBD_HID_GAMEPAD_GLOBAL_DEF(instance_name,                                                  \
                                       interface_number,                                                \
                                       endpoint,                                                        \
                                       user_ev_handler,                                                 \
                                       subclass_boot)                                                   \
    APP_USBD_HID_GENERIC_SUBCLASS_REPORT_DESC(gamepad_desc, APP_USBD_HID_GAMEPAD_REPORT_DSC(196));      \
    static const app_usbd_hid_subclass_desc_t * gamepad_descs[] = {&gamepad_desc};                      \
    APP_USBD_HID_GAMEPAD_GLOBAL_DEF_INTERNAL(instance_name,                                             \
                                              interface_number,                                         \
                                              endpoint,                                                 \
                                              user_ev_handler,                                          \
                                              subclass_boot)
#ifdef DOXYGEN
 * @brief HID mouse class instance type.
 * @ref APP_USBD_CLASS_TYPEDEF
typedef struct { } app_usbd_hid_gamepad_t;
#else
// other examples have the config at 0,endpoiint number
/*lint -save -e10 -e26 -e123 -e505 */
APP_USBD_CLASS_TYPEDEF(app_usbd_hid_gamepad,                      \
            APP_USBD_HID_GAMEPAD_CONFIG(0, NRF_DRV_USBD_EPIN1),   \
            APP_USBD_HID_GAMEPAD_INSTANCE_SPECIFIC_DEC,           \
            APP_USBD_HID_GAMEPAD_DATA_SPECIFIC_DEC                \
/*lint -restore*/
// @brief Specific class constant data for HID gamepad class.
//@brief Specific class data for HID gamepad class.
 * @brief Global HID GAMEPAD instance  AT EP1 (use to be at 3, swapped mouse and controller around)
APP_USBD_HID_GAMEPAD_GLOBAL_DEF(m_app_hid_gamepad,                //@param instance_name     Name of global instance.
                                APP_USBD_INTERFACE_GAMEPAD,       //@param interface_number  Unique interface number.
                                NRF_DRV_USBD_EPIN1,               //@param endpoint          Input endpoint (@ref nrf_drv_usbd_ep_t).
                                hid_gamepad_user_ev_handler,      //@param user_ev_handler   User event handler (optional).
                                APP_USBD_HID_SUBCLASS_NONE        //@param subclass_boot     Subclass boot (@ref app_usbd_hid_subclass_t).
APP_USBD_DUMMY_GLOBAL_DEF(m_app_gamepad_dummy, APP_USBD_INTERFACE_GAMEPAD);
Code is attached and the class is in the same folders as the other classes
5658.files.rar
Test showing on pc, no lights showup:
Serial log:
The oldest data was removed. Continue...
li:~$ [1;37m[12D[J[1;31mLogs dropped (1)[0m
<info> app: hid_gamepad_feed_descriptors
[1;32muart_cli:~$ [1;37m[12D[J[1;31mLogs dropped (1)[0m
[1;32muarart_cli:~$ [1;37m[12D[J<info> app: hid_gamepad_feed_descriptors
[1;32muart_cli:~$ [1;37m[12D[J<info> app: hid_gamepad_feed_descriptors
[1;32muart_cli:~$ [1;37m[12D[J<info> app: SENDING NEW USB DATA
[1;32muart_cli:~$ [1;37m[12D[J<info> app: transfer in progress
[1;32muart_cli:~$ [1;37m[12D[J<info> app: sending button press 0
[1;32muart_cli:~$ [1;37m[12D[J<info> app: APP_USBD_HID_USER_EVT_IN_REPORT_DONE
[1;32muart_cli:~$ [1;37m[12D[J<info> app: sending button press 1
    Can you take a look at this example and use it as a basis for adding your gamepad descriptor?
    https://github.com/too1/nrf52-usbd-custom-hid-ep
    Kenneth
  • Hey, thanks for the page. unforutantly thats confused me a tad bit more.
    If anything i would think the fault would lie within the descriptors function your examples use as i havnt modified them at all (hid_gamepad_feed_descriptors). Although in the example you offered the descriptors are layered out nicely. one think im having a hard time understanding is what value i would be writing to through the protothreads ie:
    static bool hid_gamepad_feed_descriptors(app_usbd_class_descriptor_ctx_t  * p_ctx,
                                             app_usbd_class_inst_t const      * p_inst,
                                             uint8_t                          * p_buff,
                                             size_t                             max_size)
     NRF_LOG_INFO("hid_gamepad_feed_descriptors");
        static uint8_t ifaces   = 0;
        ifaces = app_usbd_class_iface_count_get(p_inst);
     NRF_LOG_INFO("Number of ifaces are %d",ifaces);
        app_usbd_hid_gamepad_t const * p_gamepad = hid_gamepad_get(p_inst);
        APP_USBD_CLASS_DESCRIPTOR_BEGIN(p_ctx, p_buff, max_size);
        static uint8_t i = 0;
        for (i = 0; i < ifaces; i++)
            /* INTERFACE DESCRIPTOR */
            //Offset	Field                   Size                      Value                     Description
            //  0           bLength                   1                       Number              Size of Descriptor in Bytes
            APP_USBD_CLASS_DESCRIPTOR_WRITE(0x09); // bLength
            //  1          bDescriptionType           1                       Constant                  DescriptorType
            APP_USBD_CLASS_DESCRIPTOR_WRITE(APP_USBD_DESCRIPTOR_INTERFACE); // bDescriptorType = Interface
            static app_usbd_class_iface_conf_t const * p_cur_iface = NULL;
            p_cur_iface = app_usbd_class_iface_get(p_inst, i);
            APP_USBD_CLASS_DESCRIPTOR_WRITE(app_usbd_class_iface_number_get(p_cur_iface));            // bInterfaceNumber
            APP_USBD_CLASS_DESCRIPTOR_WRITE(0x00);                                                    // bAlternateSetting
            APP_USBD_CLASS_DESCRIPTOR_WRITE(app_usbd_class_iface_ep_count_get(p_cur_iface));          // bNumEndpoints
            APP_USBD_CLASS_DESCRIPTOR_WRITE(APP_USBD_HID_CLASS);                                      // bInterfaceClass = HID  // unable to find an alternative
            APP_USBD_CLASS_DESCRIPTOR_WRITE(p_gamepad->specific.inst.hid_inst.subclass_boot);         // bInterfaceSubclass (Boot Interface)
            APP_USBD_CLASS_DESCRIPTOR_WRITE(p_gamepad->specific.inst.hid_inst.protocol);              // bInterfaceProtocol
            APP_USBD_CLASS_DESCRIPTOR_WRITE(0x00);                                                    // iInterface
            /* HID DESCRIPTOR */
            //  1         bDescriptorType             1                       Constant            Device Descriptor (0x01)
            APP_USBD_CLASS_DESCRIPTOR_WRITE(APP_USBD_HID_DESCRIPTOR_HID);                             // bDescriptorType = HID
            //  2           bcdUSB                    2                         BCD             USB Specification Number which device complies too.
            APP_USBD_CLASS_DESCRIPTOR_WRITE(LSB_16(APP_USBD_HID_BCD_VER));                            // bcdHID LSB
            APP_USBD_CLASS_DESCRIPTOR_WRITE(MSB_16(APP_USBD_HID_BCD_VER));                            // bcdHID MSB
            APP_USBD_CLASS_DESCRIPTOR_WRITE(APP_USBD_HID_COUNTRY_NOT_SUPPORTED);                      // bCountryCode
            APP_USBD_CLASS_DESCRIPTOR_WRITE(hid_gamepad_get_class_descriptors_count(p_inst));         // bNumDescriptors
            static uint8_t class_desc_cnt = 0;
            class_desc_cnt = hid_gamepad_get_class_descriptors_count(p_inst);
            static uint8_t  j              = 0;
            static uint16_t class_desc_len = 0;
            for (j = 0; j < class_desc_cnt; j++)
                APP_USBD_CLASS_DESCRIPTOR_WRITE(hid_gamepad_get_class_descriptors_type(p_inst, j));   // bDescriptorType
                class_desc_len = hid_gamepad_get_class_descriptors_length(p_inst, j);
                APP_USBD_CLASS_DESCRIPTOR_WRITE(LSB_16(class_desc_len));                              // wDescriptorLength LSB
                APP_USBD_CLASS_DESCRIPTOR_WRITE(MSB_16(class_desc_len));                              // wDescriptorLength MSB
            static uint8_t endpoints = 0;
            endpoints = app_usbd_class_iface_ep_count_get(p_cur_iface);
            for (j = 0; j < endpoints; j++)
                /* ENDPOINT DESCRIPTOR */
                APP_USBD_CLASS_DESCRIPTOR_WRITE(0x07);                                                // bLength
                APP_USBD_CLASS_DESCRIPTOR_WRITE(APP_USBD_DESCRIPTOR_ENDPOINT);                        // bDescriptorType = Endpoint
                static app_usbd_class_ep_conf_t const * p_cur_ep = NULL;
                p_cur_ep = app_usbd_class_iface_ep_get(p_cur_iface, j);
                APP_USBD_CLASS_DESCRIPTOR_WRITE(app_usbd_class_ep_address_get(p_cur_ep));             // bEndpointAddress
                APP_USBD_CLASS_DESCRIPTOR_WRITE(APP_USBD_DESCRIPTOR_EP_ATTR_TYPE_INTERRUPT);          // bmAttributes
                APP_USBD_CLASS_DESCRIPTOR_WRITE(LSB_16(NRF_DRV_USBD_EPSIZE));                         // wMaxPacketSize LSB
                APP_USBD_CLASS_DESCRIPTOR_WRITE(MSB_16(NRF_DRV_USBD_EPSIZE));                         // wMaxPacketSize MSB
                APP_USBD_CLASS_DESCRIPTOR_WRITE(p_gamepad->specific.inst.hid_inst.p_ep_interval[j]);  // bInterval
        APP_USBD_CLASS_DESCRIPTOR_END();
    Then comparing the examples setup:
    /** Maximum size of the packed transfered by EP0 */
    #define EP0_MAXPACKETSIZE NRF_DRV_USBD_EPSIZE
    /** Device descriptor */
    #define USBD_DEVICE_DESCRIPTOR \
        0x12,                        /* bLength | size of descriptor                                                  */\
        0x01,                        /* bDescriptorType | descriptor type                                             */\
        0x00, 0x02,                  /* bcdUSB | USB spec release (ver 2.0)                                           */\
        0x00,                        /* bDeviceClass ¦ class code (each interface specifies class information)        */\
        0x00,                        /* bDeviceSubClass ¦ device sub-class (must be set to 0 because class code is 0) */\
        0x00,                        /* bDeviceProtocol | device protocol (no class specific protocol)                */\
        EP0_MAXPACKETSIZE,           /* bMaxPacketSize0 | maximum packet size (64 bytes)                              */\
        0x15, 0x19,                  /* vendor ID  (0x1915 Nordic)                                                    */\
        0x0B, 0x52,                  /* product ID (0x520B nRF52 HID mouse on nrf_drv)                                */\
        0x01, 0x01,                  /* bcdDevice | final device release number in BCD Format                         */\
        USBD_STRING_MANUFACTURER_IX, /* iManufacturer | index of manufacturer string                                  */\
        USBD_STRING_PRODUCT_IX,      /* iProduct | index of product string                                            */\
        USBD_STRING_SERIAL_IX,       /* iSerialNumber | Serial Number string                                          */\
        0x01                         /* bNumConfigurations | number of configurations                                 */
    /** Configuration descriptor */
    #define DEVICE_SELF_POWERED 1
    #define REMOTE_WU           1
    #define USBD_CONFIG_DESCRIPTOR_SIZE   9
    #define USBD_CONFIG_DESCRIPTOR_FULL_SIZE   (9 + (9 + 9 + 7) + (9 + 9 + 7 + 7)) // 66
    #define USBD_CONFIG_DESCRIPTOR  \
        0x09,         /* bLength | length of descriptor                                             */\
        0x02,         /* bDescriptorType | descriptor type (CONFIGURATION)                          */\
        USBD_CONFIG_DESCRIPTOR_FULL_SIZE, 0x00,    /* wTotalLength | total length of descriptor(s)  */\
        0x02,         /* bNumInterfaces                                                             */\
        0x01,         /* bConfigurationValue                                                        */\
        0x00,         /* index of string Configuration | configuration string index (not supported) */\
        0x80| (((DEVICE_SELF_POWERED) ? 1U:0U)<<6) | (((REMOTE_WU) ? 1U:0U)<<5), /* bmAttributes    */\
        49            /* maximum power in steps of 2mA (98mA)                                       */
    #define USBD_INTERFACE0_DESCRIPTOR  \
        0x09,         /* bLength        */\
        0x04,         /* bDescriptorType | descriptor type (INTERFACE)                                    */\
        0x00,         /* bInterfaceNumber        */\
        0x00,         /* bAlternateSetting        */\
        0x01,         /* bNumEndpoints | number of endpoints (1)                                          */\
        0x03,         /* bInterfaceClass | interface class (3..defined by USB spec: HID)                  */\
        0x00,         /* bInterfaceSubClass |interface sub-class (0.. no boot interface)                  */\
        0x02,         /* bInterfaceProtocol | interface protocol (1..defined by USB spec: mouse)          */\
        0x00          /* interface string index (not supported)      */
     * HID Table must normally be between Interface and EndPoint Descriptor
     * as written in HID spec§7.1 but it doesn't work with OSR2.1
    #define USBD_HID0_DESCRIPTOR  \
        0x09,         /* bLength | length of descriptor (9 bytes)                    */\
        0x21,         /* bHIDDescriptor | descriptor type (HID)                      */\
        0x11, 0x01,   /* HID wBcdHID | Spec version 01.11                            */\
        0x00,         /* bCountryCode | HW Target country                            */\
        0x01,         /* bNumDescriptors | Number of HID class descriptors to follow */\
        0x22,         /* bDescriptorType | Report descriptor type is 0x22 (report)   */\
        (uint8_t)(USBD_MOUSE_REPORT_DESCRIPTOR_SIZE),      /* Total length of Report descr., low byte */ \
        (uint8_t)(USBD_MOUSE_REPORT_DESCRIPTOR_SIZE / 256) /* Total length of Report descr., high byte */
    #define USBD_ENDPOINT1_DESCRIPTOR  \
        0x07,         /* bLength | length of descriptor (7 bytes)                                     */\
        0x05,         /* bDescriptorType | descriptor type (ENDPOINT)                                 */\
        0x81,         /* bEndpointAddress | endpoint address (IN endpoint, endpoint 1)                */\
        0x03,         /* bmAttributes | endpoint attributes (interrupt)                               */\
        0x08,0x00,    /* bMaxPacketSizeLowByte,bMaxPacketSizeHighByte | maximum packet size (8 bytes) */\
        0x08          /* bInterval | polling interval (10ms)                                          */
    #define USBD_INTERFACE1_DESCRIPTOR  \
        0x01,         /* bInterfaceNumber        */\
        0x02,         /* bNumEndpoints | number of endpoints (2)                                          */\
        0x00,         /* bInterfaceProtocol | interface protocol (1..defined by USB spec: mouse)          */\
    #define USBD_HID1_DESCRIPTOR  \
        (uint8_t)(USBD_CUSTOM_REPORT_DESCRIPTOR_SIZE),      /* Total length of Report descr., low byte */ \
        (uint8_t)(USBD_CUSTOM_REPORT_DESCRIPTOR_SIZE / 256) /* Total length of Report descr., high byte */
    #define USBD_ENDPOINT2_DESCRIPTOR  \
        0x82,         /* bEndpointAddress | endpoint address (IN endpoint, endpoint 2)                */\
        0x40,0x00,    /* bMaxPacketSizeLowByte,bMaxPacketSizeHighByte | maximum packet size (64 bytes) */\
    #define USBD_ENDPOINT2_OUT_DESCRIPTOR  \
        0x02,         /* bEndpointAddress | endpoint address (OUT endpoint, endpoint 2)                */\
    im currently trying to make sense of how things are sorted out from the app_usbd_core.c file
    regarding
    #define APP_USBD_CORE_DEVICE_DESCRIPTOR  {                                                               \
       .bLength = sizeof(app_usbd_descriptor_device_t),    /* descriptor size */                             \
       .bDescriptorType = APP_USBD_DESCRIPTOR_DEVICE,      /* descriptor type */                             \
       .bcdUSB = APP_USBD_BCD_VER_MAKE(2,0,0),             /* USB BCD version: 2.0 */                        \
       .bDeviceClass = 0,                                  /* device class: 0 - specified by interface */    \
       .bDeviceSubClass = 0,                               /* device subclass: 0 - specified by interface */ \
       .bDeviceProtocol = 0,                               /* device protocol: 0 - specified by interface */ \
       .bMaxPacketSize0 = NRF_DRV_USBD_EPSIZE,             /* endpoint size: fixed to: NRF_DRV_USBD_EPSIZE*/ \
       .idVendor = APP_USBD_VID,                           /* Vendor ID*/                                    \
       .idProduct = APP_USBD_PID,                          /* Product ID*/                                   \
       .bcdDevice = APP_USBD_BCD_VER_MAKE(                 /* Device version BCD */                          \
           APP_USBD_DEVICE_VER_MAJOR,        \
           APP_USBD_DEVICE_VER_MINOR,        \
           APP_USBD_DEVICE_VER_SUB),        \
       .iManufacturer = APP_USBD_STRING_ID_MANUFACTURER,   /* String ID: manufacturer */                     \
       .iProduct = APP_USBD_STRING_ID_PRODUCT,             /* String ID: product */                          \
       .iSerialNumber = APP_USBD_STRING_ID_SERIAL,         /* String ID: serial */                           \
       .bNumConfigurations = 1                             /* Fixed value: only one configuration supported*/\
    #define APP_USBD_CORE_CONFIGURATION_DESCRIPTOR {                                        \
        .bLength = sizeof(app_usbd_descriptor_configuration_t),                             \
        .bDescriptorType = APP_USBD_DESCRIPTOR_CONFIGURATION,                               \
        .wTotalLength = 0,          /*Calculated dynamically*/                              \
        .bNumInterfaces = 0,        /*Calculated dynamically*/                              \
        .bConfigurationValue = 1,   /*Value passed to set configuration*/                   \
        .iConfiguration = APP_USBD_STRING_ID_CONFIGURATION,        /*Configuration ID*/     \
        .bmAttributes = APP_USBD_DESCRIPTOR_CONFIGURATION_ATTRIBUTE_ALWAYS_SET_MASK |       \
                        ((APP_USBD_CONFIG_SELF_POWERED) ?                                   \
                            APP_USBD_DESCRIPTOR_CONFIGURATION_ATTRIBUTE_SELF_POWERED_MASK   \
                            0),                                                             \
        .bMaxPower = APP_USBD_POWER_MAKE(APP_USBD_CONFIG_MAX_POWER),                        \
    am i on the right path regarding this being the issue ?
    i also noticed changing the endpoint of my setup to 0 kills it.
  • A better question might be
    1) From looking at how it's setup the feeddescriptors doesnt seem to be something i would need to modify
    as it looks as if its pulling alot of data from other locations. Although it then has missing values from the
     app_usbd_descriptor_configuration_t and app_usbd_descriptor_iface_t..
    2) is my process for sending data out correct ? im trying to understand where my problem lies as it shows up nicely on the device manager but no data updates.
    so i would initially think these an issue with the endpoint
    and maybe how i used those define functions that those other two examples used, but since those two work fine and have different sized reports but the same setup for the feeddescriptors function im kind of at a loss with what i may of missed.
  • Information for device nRF52 USB HID composite GAMEPAD (VID=0x1915 PID=0x520B):
    Connection Information:
    Device current bus speed: FullSpeed
    Device supports USB 1.1 specification
    Device supports USB 2.0 specification
    Device address: 0x0008
    Current configuration value: 0x01
    Number of open pipes: 1
    Device Descriptor:
    0x12	bLength
    0x01	bDescriptorType
    0x0200	bcdUSB
    0x00	bDeviceClass
    0x00	bDeviceSubClass
    0x00	bDeviceProtocol
    0x40	bMaxPacketSize0   (64 bytes)
    0x1915	idVendor
    0x520B	idProduct
    0x0100	bcdDevice
    0x01	iManufacturer   "Nordic Semiconductor"
    0x02	iProduct        "nRF52 USB HID composite GAMEPAD"
    0x03	iSerialNumber   "000000000000"
    0x01	bNumConfigurations
    Configuration Descriptor:
    0x09	bLength
    0x02	bDescriptorType
    0x0022	wTotalLength   (34 bytes)
    0x01	bNumInterfaces
    0x01	bConfigurationValue
    0x04	iConfiguration   "Default configuration"
    0xE0	bmAttributes   (Self-powered Device, Remote-Wakeup)
    0x32	bMaxPower      (100 mA)
    Interface Descriptor:
    0x09	bLength
    0x04	bDescriptorType
    0x00	bInterfaceNumber
    0x00	bAlternateSetting
    0x01	bNumEndPoints
    0x03	bInterfaceClass      (Human Interface Device Class)
    0x00	bInterfaceSubClass
    0x00	bInterfaceProtocol
    0x00	iInterface
    HID Descriptor:
    0x09	bLength
    0x21	bDescriptorType
    0x0111	bcdHID
    0x00	bCountryCode
    0x01	bNumDescriptors
    0x22	bDescriptorType   (Report descriptor)
    0x00BC	bDescriptorLength
    Endpoint Descriptor:
    0x07	bLength
    0x05	bDescriptorType
    0x81	bEndpointAddress  (IN endpoint 1)
    0x03	bmAttributes      (Transfer: Interrupt / Synch: None / Usage: Data)
    0x0040	wMaxPacketSize    (1 x 64 bytes)
    0x01	bInterval         (1 frames)
    Microsoft OS Descriptor is not available. Error code: 0x0000001F
    String Descriptor Table
    Index  LANGID  String
    0x00   0x0000  0x0409
    0x01   0x0409  "Nordic Semiconductor"
    0x02   0x0409  "nRF52 USB HID composite GAMEPAD"
    0x03   0x0409  "000000000000"
    0x04   0x0409  "Default configuration"
    Connection path for device:
    USB xHCI Compliant Host Controller
    Root Hub
    Generic USB Hub
    nRF52 USB HID composite GAMEPAD (VID=0x1915 PID=0x520B) Port: 4
    Running on: Windows 10 or greater (Build Version 19041)
    Brought to you by TDD v2.17.0, Feb 23 2021, 14:04:02
    attached  a description dumper of the device
  • Found out the report was the issue. i shouldnt of trusted the setup. !!
