| Chip: | nRF52833 |
| SDK: | nRF Connect SDK v1.7.0 |
| Project: | Sample light_ctrl of Bluetooth mesh |
| Compiler: | gcc v9.2.1 |
| Cmake: | v3.20.5 |
| west: |
v0.11.1
My objective is to be able to update the application firmware via "Over The Air".
I tried to compile the project according to "fota-upgrades" and with some errors.
I don't know how to solve this problem. It would be fine to get some assistance. Thank you.
Building light_ctrl
west build --build-dir d:\workspace\nordic\ncs\v1.7.0\nrf\samples\bluetooth\mesh\light_ctrl\build_nrf52833dk_nrf52833 d:\workspace\nordic\ncs\v1.7.0\nrf\samples\bluetooth\mesh\light_ctrl
[0/1] Re-running CMake...
Including boilerplate (Zephyr base (cached)): D:/workspace/nordic/ncs/v1.7.0/zephyr/cmake/app/boilerplate.cmake
-- Application: D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl
-- Zephyr version: 2.6.99 (D:/workspace/nordic/ncs/v1.7.0/zephyr), build: v2.6.99-ncs1
-- Found west (found suitable version "0.11.1", minimum required is "0.7.1")
-- Board: nrf52833dk_nrf52833
-- Cache files will be written to: D:/workspace/nordic/ncs/v1.7.0/zephyr/.cache
-- Found dtc: D:/workspace/nordic/ncs/v1.7.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (d:/workspace/nordic/ncs/v1.7.0/toolchain/opt)
-- Found BOARD.dts: D:/workspace/nordic/ncs/v1.7.0/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833.dts
-- Generated zephyr.dts: D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/zephyr/dts.cmake
Parsing D:/workspace/nordic/ncs/v1.7.0/zephyr/Kconfig
Loaded configuration 'D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/zephyr/.config'
No change to configuration in 'D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/zephyr/.config'
Kconfig header saved to 'D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/zephyr/include/generated/autoconf.h'
-- Application: D:/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/zephyr
=== child image mcuboot - begin ===
Including boilerplate (Zephyr base): D:/workspace/nordic/ncs/v1.7.0/zephyr/cmake/app/boilerplate.cmake
-- Found Python3: D:/workspace/nordic/ncs/v1.7.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found toolchain: gnuarmemb (D:/workspace/nordic/ncs/v1.7.0/toolchain/opt)
-- Found devicetree overlay: D:/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/mcuboot/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/mcuboot/zephyr/dts.cmake
Parsing D:/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'D:/workspace/nordic/ncs/v1.7.0/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833_defconfig'
Merged configuration 'D:/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'D:/workspace/nordic/ncs/v1.7.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Configuration saved to 'D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/mcuboot/zephyr/.config'
Kconfig header saved to 'D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/mcuboot/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: D:/workspace/nordic/ncs/v1.7.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
MCUBoot bootloader key file: D:/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/mcuboot
=== child image mcuboot - end ===
CMake Warning at D:\workspace\nordic\ncs\v1.7.0\nrf\modules\mcuboot\CMakeLists.txt:204 (message):
--- WARNING: Using default MCUBoot key, it should not ---
--- be used for production. ---
CMake Warning at D:\workspace\nordic\ncs\v1.7.0\zephyr\CMakeLists.txt:1612 (message):
-- Configuring done
-- Generating done
[1/262] Creating directories for 'mcuboot_subimage'
[2/262] No download step for 'mcuboot_subimage'
[3/262] No update step for 'mcuboot_subimage'
[4/262] No patch step for 'mcuboot_subimage'
[5/262] No configure step for 'mcuboot_subimage'
[5/262] Performing build step for 'mcuboot_subimage'
[1/252] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[2/252] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[3/252] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[4/252] Generating include/generated/driver-validation.h
[5/252] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[6/252] Generating include/generated/offsets.h
[7/252] Generating linker_zephyr_prebuilt.cmd
[8/252] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[9/252] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[10/252] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[11/252] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[12/252] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[13/252] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[14/252] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[15/252] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[16/252] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[17/252] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[18/252] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[19/252] Building C object zephyr/CMakeFiles/zephyr.dir/D_/workspace/nordic/ncs/v1.7.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[20/252] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
[21/252] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[22/252] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[23/252] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[24/252] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[25/252] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[26/252] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[27/252] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[28/252] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[29/252] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[30/252] Linking C static library zephyr\arch\common\libisr_tables.a
[31/252] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[32/252] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[33/252] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[34/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[35/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[36/252] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[37/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[38/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[39/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[40/252] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[41/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[42/252] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[43/252] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[44/252] Linking C static library zephyr\arch\common\libarch__common.a
[45/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[46/252] Linking C static library zephyr\lib\posix\liblib__posix.a
[47/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[48/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[49/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[50/252] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[51/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[52/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[53/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[54/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[55/252] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[56/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[57/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[58/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[59/252] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[60/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[61/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[62/252] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
[63/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[64/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[65/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[66/252] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[67/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[68/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[69/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[70/252] Linking C static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
[71/252] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[72/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[73/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[74/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[75/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[76/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[77/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[78/252] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[79/252] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[80/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[81/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[82/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
[83/252] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[84/252] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[85/252] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[86/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[87/252] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[88/252] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[89/252] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[90/252] Generating zephyr/autogen-pubkey.c
[91/252] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/clock_control_nrf.c.obj
[92/252] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
[93/252] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[94/252] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[95/252] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[96/252] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/workspace/nordic/ncs/v1.7.0/modules/hal/nordic/nrfx/mdk/system_nrf52833.c.obj
[97/252] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
[98/252] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_acl.c.obj
[99/252] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[100/252] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
[101/252] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/39dda041b5094d905c1bcadd48dd39ed/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[102/252] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[103/252] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/39dda041b5094d905c1bcadd48dd39ed/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
[104/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
[105/252] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/8691d2783c11c28460ffe73d668963a1/mcuboot/boot/bootutil/src/bootutil_public.c.obj
[106/252] Building C object CMakeFiles/app.dir/keys.c.obj
[107/252] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
[108/252] Building C object CMakeFiles/app.dir/main.c.obj
[109/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
[110/252] Building C object CMakeFiles/app.dir/os.c.obj
[111/252] Linking C static library zephyr\libzephyr.a
[112/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
[113/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
[114/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
[115/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
[116/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
[117/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
[118/252] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
[119/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
[120/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
[121/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
[122/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
[123/252] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
[124/252] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[125/252] Linking C static library modules\nrf\lib\fprotect\lib..__nrf__lib__fprotect.a
[126/252] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[127/252] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
[128/252] Building C object CMakeFiles/app.dir/D_/workspace/nordic/ncs/v1.7.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
[129/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/aesni.c.obj
[130/252] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/39dda041b5094d905c1bcadd48dd39ed/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
[131/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/arc4.c.obj
[132/252] Linking C static library modules\mcuboot\boot\bootutil\zephyr\libmcuboot_util.a
[133/252] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[134/252] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[135/252] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/39dda041b5094d905c1bcadd48dd39ed/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[136/252] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/39dda041b5094d905c1bcadd48dd39ed/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[137/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/base64.c.obj
[138/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/aes.c.obj
[139/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/asn1write.c.obj
[140/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/zephyr_init.c.obj
[141/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/aria.c.obj
[142/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/chacha20.c.obj
[143/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ccm.c.obj
[144/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/certs.c.obj
[145/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/asn1parse.c.obj
[146/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/blowfish.c.obj
[147/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/camellia.c.obj
[148/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/chachapoly.c.obj
[149/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ctr_drbg.c.obj
[150/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/cmac.c.obj
[151/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/cipher_wrap.c.obj
[152/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/des.c.obj
[153/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/debug.c.obj
[154/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ecdh.c.obj
[155/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/dhm.c.obj
[156/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/bignum.c.obj
[157/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/cipher.c.obj
[158/252] Linking C static library app\libapp.a
[159/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ecjpake.c.obj
[160/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ecp_curves.c.obj
[161/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ecdsa.c.obj
[162/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ecp.c.obj
[163/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/hmac_drbg.c.obj
[164/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/entropy.c.obj
[165/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/error.c.obj
[166/252] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[167/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/havege.c.obj
[168/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/entropy_poll.c.obj
[169/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/net_sockets.c.obj
[170/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/gcm.c.obj
[171/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/hkdf.c.obj
[172/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/md5.c.obj
[173/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/md2.c.obj
[174/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/pk_wrap.c.obj
[175/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/memory_buffer_alloc.c.obj
[176/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/md4.c.obj
[177/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/nist_kw.c.obj
[178/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/padlock.c.obj
[179/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/pk.c.obj
[180/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/pkcs11.c.obj
[181/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/md.c.obj
[182/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/oid.c.obj
[183/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/pkparse.c.obj
[184/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/pkcs12.c.obj
[185/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/pkwrite.c.obj
[186/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/pem.c.obj
[187/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/pkcs5.c.obj
[188/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/psa_crypto.c.obj
[189/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/psa_crypto_se.c.obj
[190/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/platform.c.obj
[191/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/poly1305.c.obj
[192/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/psa_crypto_storage.c.obj
[193/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/psa_crypto_ecp.c.obj
[194/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/psa_crypto_client.c.obj
[195/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/39dda041b5094d905c1bcadd48dd39ed/crypto/mbedtls/mbedtls/library/psa_crypto_slot_management.c.obj
[196/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/platform_util.c.obj
[197/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/39dda041b5094d905c1bcadd48dd39ed/crypto/mbedtls/mbedtls/library/psa_crypto_driver_wrappers.c.obj
[198/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/psa_crypto_rsa.c.obj
[199/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ssl_cli.c.obj
[200/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/psa_its_file.c.obj
[201/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ssl_ciphersuites.c.obj
[202/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ripemd160.c.obj
[203/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/rsa_internal.c.obj
[204/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/sha1.c.obj
[205/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/sha512.c.obj
[206/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ssl_cache.c.obj
[207/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ssl_ticket.c.obj
[208/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ssl_tls.c.obj
[209/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/sha256.c.obj
[210/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ssl_msg.c.obj
[211/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/timing.c.obj
[212/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/threading.c.obj
[213/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ssl_cookie.c.obj
[214/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ssl_tls13_keys.c.obj
[215/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/ssl_srv.c.obj
[216/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/version.c.obj
[217/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/x509_create.c.obj
[218/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/rsa.c.obj
[219/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/x509.c.obj
[220/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/version_features.c.obj
[221/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/x509_csr.c.obj
[222/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/x509write_crt.c.obj
[223/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/x509_crl.c.obj
[224/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/x509_crt.c.obj
[225/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/xtea.c.obj
[226/252] Building C object modules/segger/CMakeFiles/modules__segger.dir/D_/workspace/nordic/ncs/v1.7.0/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
[227/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[228/252] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
[229/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[230/252] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/D_/workspace/nordic/ncs/v1.7.0/modules/crypto/mbedtls/mbedtls/library/x509write_csr.c.obj
[231/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[232/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[233/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[234/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[235/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[236/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[237/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[238/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[239/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[240/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[241/252] Linking C static library modules\segger\libmodules__segger.a
[242/252] Linking C static library modules\mbedtls\libmodules__mbedtls.a
[243/252] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[244/252] Linking C static library zephyr\kernel\libkernel.a
[245/252] Linking C executable zephyr\zephyr_prebuilt.elf
[246/252] Generating linker.cmd
[247/252] Generating isr_tables.c, isrList.bin
[248/252] Generating dev_handles.c
[249/252] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[250/252] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[251/252] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[252/252] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 33260 B 48 KB 67.67%
SRAM: 23808 B 128 KB 18.16%
IDT_LIST: 0 GB 2 KB 0.00%
[247/262] Linking C executable zephyr\zephyr_prebuilt.elf
FAILED: zephyr/zephyr_prebuilt.elf zephyr/zephyr_prebuilt.map
cmd.exe /C "cd . && D:\workspace\nordic\ncs\v1.7.0\toolchain\opt\bin\arm-none-eabi-gcc.exe zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr\zephyr_prebuilt.elf -Wl,-T zephyr/linker_zephyr_prebuilt.cmd -Wl,-Map=D:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/zephyr/zephyr_prebuilt.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a zephyr/subsys/bluetooth/mesh/libsubsys__bluetooth__mesh.a zephyr/subsys/net/libsubsys__net.a zephyr/subsys/random/libsubsys__random.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/pwm/libdrivers__pwm.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/entropy/libdrivers__entropy.a modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a modules/nrf/subsys/bluetooth/mesh/lib..__nrf__subsys__bluetooth__mesh.a modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/segger/libmodules__segger.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"d:/workspace/nordic/ncs/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v7e-m/nofp" -LD:/workspace/nordic/ncs/v1.7.0/nrf/samples/bluetooth/mesh/light_ctrl/build_nrf52833dk_nrf52833/zephyr -lgcc zephyr/arch/common/libisr_tables.a -mcpu=cortex-m4 -mthumb -mabi=aapcs -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -no-pie -Wl,-X -Wl,-N -Wl,--orphan-handling=warn D:/workspace/nordic/ncs/v1.7.0/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a D:/workspace/nordic/ncs/v1.7.0/nrfxlib/softdevice_controller/lib/cortex-m4/soft-float/libsoftdevice_controller_multirole.a && cmd.exe /C "cd /D D:\workspace\nordic\ncs\v1.7.0\nrf\samples\bluetooth\mesh\light_ctrl\build_nrf52833dk_nrf52833\zephyr && D:\workspace\nordic\ncs\v1.7.0\toolchain\opt\bin\cmake.exe -E echo ""
d:/workspace/nordic/ncs/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr\zephyr_prebuilt.elf section `text' will not fit in region `FLASH'
d:/workspace/nordic/ncs/v1.7.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 41880 bytes
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'd:\workspace\nordic\ncs\v1.7.0\toolchain\opt\bin\cmake.EXE' --build 'd:\workspace\nordic\ncs\v1.7.0\nrf\samples\bluetooth\mesh\light_ctrl\build_nrf52833dk_nrf52833'
The terminal process terminated with exit code: 1.
