Module: nRF52810
SDK: 14.2
Softdevice: S132 v5.1.0
I modified the serial dfu bootloader exemple to use the SPI slave 0 instead of the UART to communicate between the host MCU and the nRF chip.
Everything works fine when i keep the debug messages on with the NRF_LOG_ENABLE define set to 1.
When i try to run my code with NRF_LOG_ENABLE set to 0 the nRF chip doesn't respond to SPI transaction anymore..
I suspect the wait_for_event() function below called after bootloader initialization:
static void wait_for_event()
while (true)
app_sched_execute();
if (!NRF_LOG_PROCESS())
#ifdef BLE_STACK_SUPPORT_REQD
(void)sd_app_evt_wait();
#else
__WFE();
When i remove the __WFE() call or run in debug with probe attached the code runs OK and the MCU get the SPI response.
What can i do to have the SPIS interruption triggered even after a WFE call ?
