I'm working on a custom board with a nRF52840 and a Micron NOR Flash MT25QU128ABA8E12-0SIT (https://www.micron.com/products/nor-flash/serial-nor-flash/part-catalog/mt25qu128aba8e12-0sit)
I copied code from the QSPI example in SDK17.1.0, after verifying that it worked on the PCA10056 board.
Here's a snippet of the relevant code
#include <stdio.h> #include <string.h> #include <stdlib.h> #include "boards.h" #include "app_util_platform.h" #include "app_error.h" #include "boards.h" #include "nrf_drv_qspi.h" #include "nrf_delay.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" #include "main_memory.h" #define QSPI_STD_CMD_WRSR 0x01 #define QSPI_STD_CMD_RSTEN 0x66 #define QSPI_STD_CMD_RST 0x99 #define QSPI_TEST_DATA_SIZE 256 #define WAIT_FOR_PERIPH() do { \ while (!m_finished) {} \ m_finished = false; \ } while (0) static volatile bool m_finished = false; static uint8_t m_buffer_tx[QSPI_TEST_DATA_SIZE]; static uint8_t m_buffer_rx[QSPI_TEST_DATA_SIZE]; static void qspi_handler(nrf_drv_qspi_evt_t event, void * p_context); static void configure_memory(void); void main_memory_setup(void){ } void main_memory_start(void){ } void main_memory_tests(void) { uint32_t i; uint32_t err_code; err_code = NRF_LOG_INIT(NULL); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("" "QSPI write and read example using 24bit addressing mode"); srand(0); for (i = 0; i < QSPI_TEST_DATA_SIZE; ++i) { m_buffer_tx[i] = (uint8_t)rand(); } nrf_drv_qspi_config_t config = NRF_DRV_QSPI_DEFAULT_CONFIG; err_code = nrf_drv_qspi_init(&config, qspi_handler, NULL); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("QSPI example started."); }
I checked multiple times that all the GPIO pins are properly defined, as below
//QSPI #define BSP_QSPI_CSN_PIN P0_18 #define BSP_QSPI_SCK_PIN P0_19 #define BSP_QSPI_IO0_PIN P0_21 #define BSP_QSPI_IO1_PIN P0_22 #define BSP_QSPI_IO2_PIN P0_23 #define BSP_QSPI_IO3_PIN P1_00
And I copied the relevant sections from the example's sdk_config.h
As soon as I call nrf_drv_qspi_init(&config, qspi_handler, NULL);, I get an APP_ERROR_CHECK of a timeout.
Everything I read, implies a physical connection problem on the board between the nRF52 and the QSPI NOR Flash. But following the traces, everything looks as it should be. I could assume a poor BGA soldering or other chip-specific problem, but it happens on 5 different boards, so I can rule that out.
I cannot use the logic analyzer, given it's a multilayer board and the QSPI chip is a BGA form factor (not saying i cannot be done, just that I don't have the tools/skills to do it).
I looked at everything I could think of (pin drive strength, etc) and tried different clock cycles and configs (i.e. QSPI_CONFIG_READOC 2), but nothing makes a difference
I'm obviously missing something, possibly in the timing of the Micron part we are using. I could understand if the code failed when trying to read or write to the NOR, but in the case fails at init, which seems to imply a pretty major problem
Any suggestions on what to try next? What am I missing?
EDIT: i just noticed that the board designer has used P0.18 as CS, and CS can be defined as nRESET. I managed to read the voltage on the QSPI_CSN (P0.18), and it's always stuck high. I found a ticket mentioning removing CONFIG_GPIO_AS_PINRESET, which I did, but doesn't seem to make any differenbce even after forcing a clean rebuild
Any idea why P0.18 is stuck high (assuming it's not a hardware problem, but the board layout seems ok, and it happens on multiple boards)
