I have an https connection (sending json) that works fine when the response is less 2k. But for responses (from the server) that are over 2048 bytes, recv returns 0 bytes. :(
nrf9160
1.5.1 SDK
https/TLS
nrf9160
1.5.1 SDK
https/TLS
The modem has a known TLS limitation of 2kB secure socket buffer size, documented in the modem FW release notes:
*** Limitations
- TLS/DTLS
- Up to three simultaneous TLS/DTLS connections are possible. It is recommended to free the
modem resources by closing unused network sockets.
- Maximum server certificate chain size has a limit of 4kB.
- Server certificate expiry time is not verified.
- pkcs#8 is not supported.
- Absolute maximum number of supported credentials is 32. The actual amount depends on size of
credentials as memory area reserved for credentials may be a limiting factor as well.
- DTLS supports PSK authentication only.
- 2kB secure socket buffer size.
Øyvind
Thank you for the quick response!
