get RSSI on nRF52840 with NCS
I'm working on NCS 1.6.1.
I'd like to confirm if my method to get the RSSI is correct.
i test with a sample "peripheral_uart"
after BT connected, i printk the (NRF_RADIO->RSSISAMPLE)
the result like:
42
40
46
39
is it the correct RSSI? (then just to add a minus, -42, -40, ,,,)
  • Hi instead of reading it directly from the RADIO register, it is highly recommended to use sdc_hci_cmd_sp_read_rssi API from the nrfx library that is also available with the NCS
    you might need to enable the below features in config
    CONFIG_BT_CTLR_ADVANCED_FEATURES=y
    CONFIG_BT_CTLR_CONN_RSSI=y
  • it seems hard to trace out how to feed parameter, what is the handle?
    typedef __PACKED_STRUCT
    uint16_t handle;
    } sdc_hci_cmd_sp_read_rssi_t;
    do you have a example of how to call the sdc_hci_cmd_sp_read_rssi ?
  • It is the connection handle as mentioned in the documentation for that API
     * For an LE transport, a Connection_Handle is used as the Handle command
     * parameter and return parameter. The meaning of the RSSI metric is an
     * absolute receiver signal strength value in dBm to ±6 dB accuracy. If the RSSI
     * cannot be read, the RSSI metric shall be set to 127.
